Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Can feel cold air coming out of bottom of freezer but it is not cold inside
Cold air coming from bottom of refrigerator. Freezer and Refrigerator are not getting cold.
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Do you see ice buildup on the back of the freezer wall about half way down?
Posted on Dec 28, 2013
  • 116 Answers
SOURCE: Whirlpool Refrigerator or freezer Doesnot cool
Typically with this model it is either the defrost timer or the defrost thermostat which has stopped working. In short your refrigerator is not cycling through its normal defrost cycle every 8 to 10 hours.
The temporary fix to the manually defrost the freezer section by unplugging the unit overnight or gently heating the back for the freezer with a hair dryer until all of the ice is gone. The frost will gradually build up again until the problem reoccurs (usually 1 to 2 weeks)
Most of the testing to confirm the fault requires a multimeter for testing electrical circuits.
The problem shows behind the back wall of the freezer. There will be thick frost build up on the silver element. (do not chip it off since any damage to the silver coils can result in a huge repair bill. On one side of the silver coil assembly there is a component that is designed to open when the heater gets hot enough. This part is about the size of a stack of 6 quarters and typically has a blue end coating on one end. The other end is silver in colour and should be clipped on or near the heating element. It will have 2 wires coming out of the blue end.
If this part is defective then it will have to be replaced. by cutting a splicing a new one in. Be sure to unplug the fridge before replacing it.
The heater and timer are simply unplugged and replaced with a new part is defective.
There are 3 main components that can give issues; the timer, the thermostat and the heater. All 3 should be checked to confirm the fault.
Posted on Aug 06, 2008
SOURCE: the refrigerator isn't getting cold
the refrigerator part isn't getting cold. it was working but now its just room temperature inside. the freezer part works fine.
Posted on Jul 03, 2009
  • 396 Answers
SOURCE: refrigerator section not getting cold - air vents
Evaporator fan may not be running. This fan distributes cold air throughout the freezer and to the refrigerator. The fan is likely located behind an access plate at the top of the freezer. If it's running, you should be able to hear it. If you can't hear it, open the access plate and look at it. If it's not turning, you will likely have to replace the fan motor.
Posted on Oct 20, 2009
heatman101
  • 43501 Answers
SOURCE: Bottom Freezer is cold top Refrigerator not
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 04, 2010
heatman101
  • 43501 Answers
SOURCE: Refrigerator is not getting cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 27, 2010
I have an Amana side by side refrigerator. Last night I noticed water running from underneath and the ice cream in the freezer melting. I found dog hair clogging a vent and cleaned it. This morning the...
usually when the bottomof the freezer is cold and the top isn't it's the evap fan motor isn't working and all the cold air sits at the bottom.when you open the freezer door you should hear the fan running inside the freezer,also tried to look up your model but it didn't come up.open the fridge door,look up on the right and hear the cieling and you'll see a tag with the model and serial numbers,i just need the model number and i can help you better
Jan 30, 2011 | Amana ARSE66MB Side by Side Refrigerator
Freezer is cold, refrigerator is warm. sounds
check the fan from the freezer side if its not running /possible frozen or jammed will cause the refridge side to be warm the fan blows the freezer air into the fridge side to cool their is also a damper or duct control which can build up if no blockage or debris test fan for power if power than test fan it self if not running than repair or replace as necessary
Apr 09, 2010 | Amana BC21V1W Bottom Freezer Refrigerator
Freezer gets cold, upper refrigerator does not. Looks like there is an opening for cold air to come into the refrigerator, it isn't blocked. Air just isn't rising from freezer to fridge.
you have bad fan motor,located behind freezer wall,accessible from the front inside freezer,lots of disassembly required-awkward repair,but worth it
Mar 06, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge doesn't work but freezer does
This is a most common problem it can be only due to how you're setting the two controls, you may think one is for the freezer and one is for the fridge,in a sence it can be true but in fact it is not. The bottom part we call the refrigerator is only a empty box and the cooling is coming from the top freezer through a hole covered by a slid which can wide open or close the hole . And this control they call freezer control and when you set this freezer control to the coldest accuraly you are closeing the hole and not letting too much cold air coming down to the refrigerator , now you've a very cold freezer but a warmer refrigerator so if you want a colder refrigerator you've to wide open the slid and letting more cold air coming from the freezer.You can try out this by putting your hand over the air outlet in the refrigerator and then turn the freezer control, and you'll feel the cool air coming stronger or weaker by truning the freezer control.This is what I would do first before going in to check the defrost cycle . Hope this help, have a nice day God Bless.
Jul 30, 2009 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerator not cold/Freezer cold.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Jul 03, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
It's likely the door was inadvertently left open, and the cold air passages from the freezer have built up enough ice that the cold air from the freezer has no way to enter the refrigerator. Check the cealing of the refrigerator. If you can see or feel ice in the passages between the freezer and fridge, you can probably solve the problem by finding a safe temporary home for your food, and leaving the refrigerator unplugged overnight.
May 25, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Wont get cold
check to see if there is excessive frost build up inside of the freezer on the back panel. If so you may have a defrost problem or your fan motor in the freezer may be bad. Open the drawer to the freezer and see if the fan comes on when you push the light switch. What brand is this unit?
Apr 01, 2009 | Refrigerators
Kitchenaid refrigerator w/bottom freezer french doors
please check the air flow to the refrigerator side. it could be a stuck damper motor or damper thermostat. if the fan inside the freezer is running, you should be able to feel cold air coming out off the vents in the refrigerator side. you might have to press the button light switch on the panels to run the fan.
Feb 19, 2008 | KitchenAid Architect KBFA25ERSS Stainless...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
