Question about Fisher Price Ocean Wonders Cradle Swing
Swing speed dial does not work - Fisher Price Ocean Wonders Cradle Swing
  • tiana karst
    tiana karst Mar 07, 2014
    I have the same problem. The swing stays at the same (very slow) pace.
No speed is displayed when the trigger is pulled and aimed at the baseball. Just mph and the radar icon. It has new batteries. What could be causing it not to detect speed.
You can add up to 25 miles an hour and more to your swing speed by taking advantage of your hidden, built-in swing speed multiplier. The top pros have always taken advantage of their hidden swing speed multiplier. It's why they drive the ball 280-300 yards The average golfer does not know he has a swing speed multiplier built into his own body-and drives the ball 210-220.
What is the swing speed multiplier built into every golfer? And how does it affect swing speed? It is a hidden lever system that multiplies any increase in hip speed 25 times.
Jun 30, 2015 | Bushnell Velocity Radar Gun Speed...
My speedometer goes up and down , and my radio goes on and off
The speedometer can fluctuate rapidly under normal driving conditions when the car's speed changes abruptly, but sometimes the needle can start swinging around the dial without any fluctuation in speed. If the hairspring comes loose or breaks, it can't hold the speed cup in place, and the result is a fluctuation in the dial. In electrical speedometers, if the circuit that counts the magnetic pulses fails, it can cause the speedometer read-out to vary from the actual speed and to shoot upward or downward without notice. If a speed sensor in the automatic transmission starts to malfunction, it can affect the speedometer and cause fluctuations. In these instances, either the speedometer or the sensor needs replacement.
Sep 26, 2013 | Cars & Trucks
Mobile not turning
Hi, do you have the mobile function turned on? When you're looking at the controls, the mobile is controlled by the dial on the bottom right; if it is set to either mobile (the four arrows chasing each other around in a circle) or mobile and lights (the four arrows below the image of the light) then the mobile should turn on when you turn the main swing dial to either stationary (the circle with another circle inside it) or to any of the "on" settings (any of the filled-in circles after that).
If the mobile isn't turning on but everything else is working, you probably have a bad mobile motor inside the swing that will need to be replaced. Taking it to a repair shop might be expensive -- you can sometimes find used swings on eBay for cheap and harvest the parts you need from one of them.
Dec 11, 2010 | Fisher Price Ocean Wonders Cradle Swing
The shutter speeds on my Horizon Perfekt do not change when i adjust the dial.
The shutter speed is controlled by the width of the slit exposing the film. So, the lens will swing at the same speed when set at 1/500 or 1/60 (White setting), therefore it appears on the outside that the shutter speed has not changed. The swing has only 2 speeds, White fast, Yellow slow, selected by the switch on the left beside the rewind knob.
To confirm that the width of the slit is changing (actual shutter speed), open the back and fire the shutter on Yellow 2 (half second), you will see the slit is fully open as the lens swings. Next try Yellow 8, you will see the slit is less than half open, so it exposes the film for a shorter time by having a narrower slit , not faster swing.
This is the same principle in many cameras with curtain shutter.
I hope this answers your question.
Oct 13, 2010 | Horizon Perfekt Film Camera
How to set a speed dial and delate old speed dial no
Just figured this out (though a lot of people seem to have tried giving an answer without seeing if it works.
Setting speed dial numbers doesn't allow you to choose one for the voice mailbox. Go to Messages -> Voice Mailbox Number (option 12). There you can change the number.
May 21, 2009 | Nokia 1100
I have a KENWOOD electronic mixer (about 10 years old)
AFTER TALKING TO KENWOOD'S REPAIR SHOP ON THE PHONE, THEY SAID THEY WOULD HAVE TO OPEN UP THE WHOLE MIXER TO REPALCE THE SPEED DIAL ---WHICH WOULD COST NEARLY AS MUCH AS BUYING A NEW MIXER...TYPICAL.
IN ANY CASE THE PROBLEM WAS DUE TO THE POOR DESIGN OF THE INTERCONNECTION BETWEEN THE SPEED DIAL AND THE NYLON WHEEL THAT INTERFACES WITH IT. IN MY CASE, AND MOST LIKELY IN MANY OTHERS, THE PLASTIC PART OF THE INSIDE OF THE SPEED DIAL DEVELOPED STRESS FRACTURES AND EVENTUALLY CRACKED OFF COMPLETELY SO THAT THE SPEED DIAL WOULD SIMPLY SPIN AND HAVE NO EFFECT ON THE MOTOR EITHER TO START OR STOP IT OR INCREASE OR DECREASE THE SPEED.
IT WAS FAIRLY EASY TO SEE THE PROBLEM ONCE YOU REMOVE THE TWO SCREWS THAT CONNECT THE MOTOR TO THE METAL SWING ARM. THAT WILL ALLOW THE MOTOR TO DROP DOWN ABOUT A CENTIMETER OR HALF AN INCH.
TO FIX THE PROBLEM IT IS SIMPLY A MATTER OF FIGURING OUT _- HOW TO GET THE INSIDE OF THE SPEED DIAL TO RECONNECT TO THE NYLON DISC FROM THE MOTOR!
I DECIDED TO FIRST: USE A REGULAR HOUSE HOLD SEWING PIN (TWO OF THEM ONE FOR EACH SIDE OF THE WHEEL ASSEMBLY) TO SERVE AS A TYPE OF "PIN" TO SECURE THE TWO OBJECTS TOGETHER.
HEAT UP THE PIN UNTIL IT IS RED HOT!! AND USING SOME NEEDLE-NOSE PLYERS BEGIN TO PUSH THE PIN THRU THE PLASTIC (OF THE SPEED DIAL) AND FINALLY INTO THE NYLON DISK BELOW IT. IT MAY TAKE SEVERAL ATTEMPTS TO BURN THE SMALL HOLE BUT ONCE IT IS DONE A FINAL HEATED PIN OR VERY SMALL NAIL IS PUSHED THRU AND ALLOWED TO COOL THUS BECOMING STUCK!! DO THIS FOR BOTH SIDES IF YOU HAVE COME THIS FAR YOU WILL KNOW WHAT I MEAN.
NEXT I FILLED THE SURROUNDING WHOLE NEXT TO THE PIN AND ON BOTH SIDES WITH A VERY , VERY GOOD 2 PART EPOXY GLUE.. (TAKE YOUR TIME IT MAY TAKE SEVERAL HOURS TO FINISH IT BECAUSE YOU NEED TO USE THE TIME TO DO SEVERAL LAYERS OF EPOXY TO DRY.. THAT WILL HOLD THE SPEED DIAL LIKE A ROCK AND WILL BE BETTER THAN THE ORIGINAL !! AND BEST OF ALL IT SAVES THE MIXER AND DIDNT COST MUCH AT ALL!!
IN A NUT SHELL THE PINS FORM THE SAME FUNCTION AS REINFORCING RODS IN CEMENT TO HOLD IT TOGETHER ALSO GIVING THE EPOXY SOMETHING TO BIND TO !!
Mar 19, 2009 | Kenwood Food Mixers
Speed dial not working
Maybe because the speed dial service is not on.
Click.
Menu -> Settings -> Cal Settings -> Speed Dial -> On.
then try.
Nov 14, 2007 | Nokia 6030 Cellular Phone
I have done it. I have found a way to chance the speed dial settings on my Samsung D900i.
The following instructions work for my phone but I cannot guarantee they will work for everyone else.
YOU WILL NEED A PEN AND PAPER.
Press Menu > select Phonebook > Speed dial (4) >Select
You should see names assigned to the numbers.
Decide which speed dial number you want to change e.g. 2 Mum Mobile (remember the name)
Press Back > Contact list (1) Select
Type in/go down to that name e.g. Mum Mobile (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > choose Yes > Back > Speed dial (4)
You should now see that Mum Mobile has been replaced with a big number 2. This means that speed dial number 2 is un-assigned.
Press Back > Contact list (1) > Select
Decide who you want to be assigned to speed dial 2 (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > Yes (HERE IS THE WEIRD THING)
Press Back > Create contact (2) > SIM (2) >Select
Type back in the name and number of person you have just deleted > Save > Back > Speed dial (4)
You should see that Speed dial 2 is now the person of your choice.
HOW COOL IS THAT!!!!!!!!!!
Press Back > Create Contact (2) > Select > SIM (2) > Select
Type in Mum Mobile and Number (THE FIRST NUMBER YOU WROTE DOWN) > Save.
That is it, repeat the instructions until you have all the speed dials of your choice.
Hope this helps the many frustrated D900i users out there.
Aug 31, 2007 | Samsung SGH-D900 Cellular Phone
Fisher Price Ocean Wonders Cradle Swing Logo
59 people viewed this question
Top Fisher Price Baby Gear Experts
romney2012
Lyle Siemens
Lyle Siemens
Josh Whitehead
Josh Whitehead
Are you a Fisher Price Baby Gear Expert? Answer questions, earn points and help others
