Question about Maytag MDB7100AWB Dishwasher
Model number W10532762A WILL not start
I have maytag dishwasher model number W10532762A less thna 3 months old. The disher washer will not run when we push the start button. The canel cycle runs fine but disherwasher will not start.
5 Suggested Answers
SOURCE: Maytag dishwasher won't start
"unlock" the machine by pressing on '3' and holding for a few seconds. Thats what it says on the back of my dishwasher which is the exact same model.
Posted on Oct 28, 2008
localwonder
  • 6784 Answers
SOURCE: Maytag Dishwasher Leak
HI. this is a inlet assembly issue. The water inlet valve can be identified by the water hoses connected to it. One hose will lead from the valve to the pump/motor assembly in the center of the dishwasher. Check that the hoses are securely connected to the valve and that there are no kinks in the hoses which could restrict water flow. There are two wires (four, if it has two solenoids) connected to the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. If your valve has two solenoids, test the second one in the same way as the first.
If the solenoid is working properly, but water leaks through the valve even when the dishwasher is off, then the valve itself is the problem. Debris may be preventing the valve from closing. If the valve cannot be cleaned, it will have to be replaced. The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
***(((NOTE-- It i possible that the valve housing has cracked as well. make sure that the hoses are connected properly during your testing. If there are no hose issues, this will be a defective valve assembly)))
Posted on Sep 12, 2009
SOURCE: 1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
Posted on Dec 19, 2009
SOURCE: my maytag 200 quiet series dishwasher has a button
The control panel has bee locked. Press and hold the heated dry button for 3 seconds until the light next to the lock "3" button goes off. This feature is to prevent small children from starting it. Locking the controls works the same way, hold the heated dry button for 3 seconds will turn it back on.
Posted on Jan 15, 2010
Model MDB7749AWB. Why does it stop mid-cycle?
Defective washer control board is the most common fault.
Mar 15, 2017 | Maytag Dishwashers
Regarding Maytag Dishwasher, model # mdb4651aww3. Most of the lights on the control panel will not light up. You can't change cycles or set the delay timer etc. You can hit the start button and it runs a...
I have same problem with my Maytag. Had a repair guy come out and he said it's the 'controller card', not the button touchpanel. The controller card is $127 and not in stock and there's a 'several month wait'. I'm not going to wait, going to buy something used for less than the price of a new controller card. Maytag's quality has really deteriorated in the past few years. They used to have a 5yr warranty on pretty much everything - now it's only 1yr. (and of course, mine failed just a few weeks after the 1 yr time.
Jul 25, 2010 | Maytag 24 in. MDB4651A Built-in Dishwasher
Maytag Quiet Series dishwasher won't start
Sounds like you have a bad Control Board
http://www.partstore.com/Part/Maytag/Maytag/MDB6600AWW/Maytag/Maytag/99003160/New.aspx
But with the price it cost, you might be better off buying a new dishwasher, preferably a different brand, cause that washer has some bad reviews
Oct 12, 2009 | Dishwashers
Maytag model # MDB9601AWB - when the cycle is selected; door is closed; the machine fills up and shuts off - the cycle does not run. Water remains in the bottom resevoir but does not run. we have attempted...
has it ever worked.. sounds like a wire could have been pulled off the motor...if only 6 months old... call a service company the is factory it will be covered under WTY
Sep 20, 2009 | Maytag Dishwashers
Dishwasher only runs for 21 minute cycle
I bought and replaced the control board in the door. $145 CAD it took 5 min saved myself $300
May 07, 2009 | Dishwashers
Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Dec 23, 2008 | Maytag MDB7100AWB Dishwasher
Indesit dishwasher DI 450 stops after 10 mins
my disher washer dls 535 starts programme then lights 2 and 3 start flashing and does not work
Nov 19, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Maytag dishwasher shuts off during cycles
thats what it soundslike to me here aoart number which is the entire assy w/both switches included 99002254 retails for about $25
Nov 05, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Oct 05, 2008 | Maytag MDBH945AWW / MDBH945AWQ /...
Maytag MDB7100AWB Dishwasher Logo
352 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
