Question about Leviton Hardware & Accessories
Leviton vtp24 does not work after power outage
Does not work after power outage
Samsung Microwave Oven SMH7159 No Power
The power outage may have been accompanied with a power surge. That can happen with lightning strikes, or if a large inductor (electric motor or equivalent) happened to be on the same power line at the time of the outage. There's a good chance a surge took out the control panel.
Aug 06, 2016 | Samsung Microwave Ovens
Tip
Wii won't turn on after a power outage.
Hey, recently had a power outage and now your Wii won't turn on?
Well unless your Wii is completely fried from the storm then this should work (It has for me every time I have had an outage).
After you find out it's not getting power then just unplug the power cable from the wall and from the Wii. Normally I unplug it for about 12-24 hours then you go plug it back into the wall, plug it back into the Wii, look at the power button and if it is red/orange then it has been fixed and you should never have a problem with it again unless you keep it plugged in during a thunderstorm/power outage!
This has happened to me about 8 times and this method worked every single time!
on Jan 26, 2010 | Video Game Consoles & Games
Model RB215LABP reset temperature display after power outage
Samsung Blinking Dash/Line Error Code List - Parts Dr
https://partsdr.com/blog/samsung-blinking-dashline-error-code-list/
Jul 16, 2011 - Indicate Error when the temperature sensed by Refrigerator sensor is .... My model required holding the super freeze and super cool buttons, but it worked! ... My display said S and E after a power outage I pressed energy .... I had that 5 E error code after a brief power outage... thank you for the resetting ...
Samsung Refrigerator Troubleshooting Self Diagnostics ...
www.appliancerepairlesson.com/.../samsung-refrigerator-troubleshooting...
Apr 13, 2011 - and then I also noticed that the display buttons for the temperature is not working. ..... We have tried to reset the refrigerator with no luck. ..... I had a power outage yesterday and my Samsung Fridge RSG257 now shows an 88 .... I haveModel# RF268ABRS, this thing quit cooling/freezing after we lost power.
Error Codes / Messages / Blinking
Dec 22, 2015 | Samsung Refrigerators
After power outage sound bar will not turn back on
Power supply problems may have occurred as a result of the power outage .... check power supply with a power meter .... see if its outputting ... then check connection to the computer to make sure output is working
Jan 22, 2014 | Computers & Internet
Vizia VPT 24 - LCD not working, switch not working after power outage
faulty switch ? faulty breaker ? loose connection ?
get an electrician to test the circuit.
Dec 23, 2013 | Leviton Vizia + VP00R-7LZ Accessory Dimmer...
Locator Light not working on leviton 6633-pl
6633-pl is single-pole and 3-way dimmer made for max 600 watt incandescent or halogen load. This dimmer does not work for CFL or inductive loads such as motor.
I have no idea what a 'locator light' is?? Do you mean the LED indicator that shows when power is connected?
Troubleshoot section of manual does not show any solution for LED malfunction.
Contact Leviton for email tech support:
http://www.leviton.com/OA_HTML/SectionDisplay.jsp?section=37619&minisite=10251
Aug 03, 2012 | Leviton Decora Light Dimmer Switch
I misplaced my instructions for my timer and need to re-set it after a power outage. Can you please send me the instructions? Thanks.
Question posted under Intermatic ST01C, but Timer is not 100% identified since ST01C is battery powered, and should not lose programming or stop working with ordinary power outage.
Most digital timers have a battery or capacitor back-up for power outage.
Add a comment with description of timer buttons, or open link below to see most brands of in-wall timer.
Open following link for to identify Intermatic ST01C and Ei600 and download instructions:
http://waterheatertimer.org/ST01C-program.html#battery
ST01C timer has a battery backup. Power outage will NOT cause battery-powered display to fail, but power outage and power surge can cause any electronic timer to fail.
So either the battery went dead, or power surge ruined timer, or you don't have ST01C timer.
If ST01c display is not showing, then replace battery and then reprogram current time -or- manually re-set timer and then reprogram timer.
Sep 03, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I have a Woods Decora time we use on our bathroom vent fan. It is preset for 5-10-15-30 minutes. It now runs for 5-10-15-30 SECONDS! How can I fix it?
There are no repairs for electronic wall timers.
Timers have 1 year warranty against defects in workmanship. This sounds like the case here.
Try timer on different circuit and see if same malfunction appears.
Woods is rated for 1/4 HP and will handle bath fan, so load does not sound like a problem.
Timer worked before, so wiring is correct.
Power outages can knock out timers when the power turns on again and timer is exposed to surge.
View countdown timers:
Electronic Leviton 6200 series and Leviton LTB series are more robust than Woods.
Mechanical rotary-type timers have no electronics, and last many years without problems.
Buy locally: GE countdown timers are sold at Home Depot. Advantage of store-bought timer is hassle-free warranty: buy new timer and return defect timer in new package.
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 26, 2011 | Woods 59007 Decora Style 3015105 Minute...
Hardware & Accessories Logo
66 people viewed this question
Top Leviton Hardware & Accessories Experts
Hippy_dd
Gene Haynes
Are you a Leviton Hardware and Accessory Expert? Answer questions, earn points and help others
