Question about Sewing Machines
How to thread needle - Sewing Machines
    Champion:
  • 276 Answers
What make and model machine have you?
Posted on Feb 19, 2014
Singer 3825 upper thread keeps breaking
You might have an old needle. Most sewing experts recommend changing the needle between each project. As the needle ages the eye of the needle becomes rough and cuts the thread.
Alternatively, you might be using the wrong needle. Depending on the thickness of your fabric and the type of thread you are using you should adjust your needle type. There are needles for denim and needles for metallic threads.
When I have chronic problems like this I rethread both my upper and lower thread and that usually resolves the problem.
Dec 08, 2014 | Singer Sewing Machines
Top thread is breaking on Janome 6600P
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Jan 16, 2013 | Sewing Machines
When sewing thread keeps breaking and comes out of the needle
keep longer thread tails before you begin to sew and make sure
the thread tails are pulled behind the needle before you start sewing
Jan 08, 2013 | Yamata Sewing Machines
My thread keeps breaking. bobbin thread seems to be alright, have changed thread, needle.
Dec 16, 2012 | Kenmore 19606 Computerized Sewing Machine
Janome 1600 thread shred and breakage
could be a bad section of the thread
check for burrs around the needle plate area and also in the bobbin
area and on the thread guide close to the needle.
Dec 09, 2012 | Sewing Machines
Juki DDL 227 top needle keeps breaking
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Oct 08, 2012 | Juki Sewing Machines
The thread is kinking and braking at the needle's eye opening and skipping.
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Sep 15, 2012 | Juki Sewing Machines
Top thread breaking especially when machine in reverse.
try this
The machine is not threaded correctly--rethread the machine
The thread tension is to tight--reduce the thread tension (lower number)
The thread is to thick for the needle--select a larger needle
The needle is not inserted correctly--remove needle & reinsert the needle (flat side toward the back)
The thread could be wound around the spool pin
The needle is damaged--replace
Some needles & thread are not compatible--try this
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Nov 03, 2010 | Singer 8280 Mechanical Sewing Machine
I am sewing a quilt and my needle is in the right place but it keeps breaking. Please help. Also, the thread break often.
here are something you might check
upper thread breaks
1.top tension to tight
2.thread to thick or to fine for needle
3.needle not inserted correctly
4.thread caught on something-spool pin, tension area
5.needle damaged
6.needle thread is not threaded properly
Needle breaks
wrong size needle for fabric
also check for lint & pieces of broke needle under the needle plate
also the bobbin case area -take the bobbin & case out & check for pieces of broke needle
here is a tip about needle & thread
Oct 21, 2010 | Husqvarna Designer I
Thread breaking on Simplicity Denim Star
Hi, when your thread breaks or frays right before in goes through the eye of the needle:
  1. Change your needle - after awhile, the eye can wear down and cause your thread to break or fray, eventhough it looks like the thread isn't even going through the needle. When you change your needle, make sure to install a needle that is compatible with the thread you are using (see below).
  2. If your thread still frays or breaks, make sure you've threaded your machine correctly. Most machines have a hook or bar right above the needle that your thread need to pass thru before you put the thread thru the eye of your needle. Sometimes that spot above the needle is really hard to get to, and sometimes the thread slips out. Always a good idea to double check. If you are still having problems, the needle you are using is probably the wrong size.
There are lots of needles on the market, and lots of threads. You need to make sure your needle is compatible with the thread you use for each project.
The most common needles are size 80 and 90 universal needles, which are fine for most sewing projects. But if you are using a specialty thread, you need to use a needle that is designed to work with that particular thread. For example, top stitching needles have a larger eye than a universal needle, because top stitching thread is thicker than sewing thread. The same is true for metallic thread - needles made for metallic thread an eye designed to allow the thread to pass thru without fraying. Further, if you using fine thread, you need a small needle.
FYI - unfortunately, thread sizes do not correspond directly with needle sizes. Small needle numbers indicate a needle with a small eye. But the smaller the thread size, the larger the thread. For example, size 50 thread is very fine and would usually be used with a size 70 needle. Size 30 thread is fairly thick and would probably be used with a size 90 top stitch needle.
Hope this helps, and remember, you should always change your needle after about 10 hours of sewing, no matter what size needle you are using. If you have more questions, please post again. Thanks, Ginny
Dec 16, 2008 | Simplicity American Denim SA1100...
Sewing Machines Logo
12 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
