Question about Sunbeam Heritage 2346 Stand Mixer
Motor for turntable
I am looking for the turntable motor for a sunbeam Mixmaster heritage # 2347. Any ideas on where to find one? It has a bad bearing/bushing.
How to disassemble mixmaster heritage series model 2351
try the following sites
www.eserviceinfo.com/equipment_type/model###
www.freeproductmanual.com/manufactures_name/model###
www.info.com/manuals
www.s-manuals.com/manufactures_name/model###
at the browser type the following information
sunbeam disassemble procedures for make/model ###
you could look at www.youtube.com/disassembling mixmaster model 2351
Mar 31, 2015 | Sunbeam Food Mixers
Will not mix
if the motor isnt making a noise then it could be the brushes in the motor that are worn.. or it could be the fuze in the plug have you tried a new one in there
Apr 06, 2014 | Sunbeam 2347 MixMaster Heritage Series...
My Sunbeam mixmaster junior model-jc is smelling when it runs
the smell will be burning insulation on the windings of the motor probably from the brushes being too short and arcing on the armature thereby overheating the motor. suggest you take it to an appliance repair shop for quote on repairs.
Jun 17, 2013 | Sunbeam 2346 Heritage MixMaster Series...
How can i get a replacement manual for the sunbeam mixmaster heritage series 2347
You can download the manual from the manufacturer's web site at
http://www.sunbeam.com/Manuals/MANUALS/002347-030-000_43_32347182.PDF
Feb 25, 2011 | Sunbeam Heritage 2346 Stand Mixer
Beaters won't turn bowl still does turn
I just took mine apart for this same issue. What i found was the plastic beater drive gears have been stripped by the motor worm gear. I am currently looking for these parts to replace them.
Dec 28, 2010 | Sunbeam 2346 Heritage MixMaster Series...
Vintage Sunbeam Mixmaster MXG makes a strange noise and has a burning smell when operating. Is there anyway I can fix this?
the motor is burning out at the coil you can send it into a electric motor re winder but it could be expensive look them up in your local directory
Jul 04, 2010 | Sunbeam 2346 Heritage MixMaster Series...
Hello, I have sunbeam mixer model #2360 and had one large and one small turntable. I lost the large turntable and am unable to locate a site to purchase another one. Can you please help? Thanks, so much!
Sunbeam 2386 Sunbeam 2386 MixMaster Series 275 Watts Stand Mixer. Overall User Rating. 3.0. out of 5 ... 2386 Reviews & Articles. Sunbeam - Small Appliance Parts ... retrevo.com/s/Sunbeam-2386-review-manual/id/952ci071/t/1-2
Good luck_Ned_
Nov 03, 2009 | Sunbeam 2386 MixMaster Series Stand Mixer
Sunbeam Mixmaster Heritage Series Model 2350 speed problem
The speed control on the back is simply a variable resistance potentiometer, the same thing that controls the volume on older amplifiers. The output current to the motor is supplied by the printed circuit board in the bottom of the unit. This allows gradual increases in speed to avoid over-torquing the motor on speedup. Even the poshy-posh-posh mixers do this.
At least it still works. The most common problem is the cheap plastic drive gears that strip out with a mild cookie dough, this jams the beaters together and requires burial-at-dumpster.
Dec 14, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam mixmaster heritage series
http://www.repairclinic.comThis is a helpful website with an 800 number and they are good about helping with the fix.
You probably have to replace worn gears and or bearings.
Feb 20, 2008 | Sunbeam 2370 MixMaster Series Stand Mixer
Sunbeam Heritage 2346 Stand Mixer Logo
44 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
