Question about Sony Playstation 3 (PS3) Console
PS3 will not accept disc
The motor is not pulling the disc in as it should. The only way I can get working is to force the disc in and power the console on and off.
  • 23 Answers
SOURCE: my ps3 wont stay on
This sounds like an over heating issue. Do any fans come on when you first start up the system?
Posted on Sep 14, 2008
SOURCE: cd drive won't pull disc into console
Do you have a warranty? If you do, go to the place where you got it and have them check the inside. You may have a broken gear. That could be why it does not take in the disc or eject it. =D
Posted on Mar 25, 2009
SOURCE: PS3 wont read any discs
i had the same problem m8,need to contact sony careline and ask for a reconditioned one,lot of problems with the 60 gig,im on my 3rd one now,ended up gettin it insured for 5 quid a month so if it goes again i can get another recon,think you need to be under your years warranty so hope you are and still have receipt or some other proof of purchase,hope this helps
Posted on Apr 12, 2009
  • 12 Answers
SOURCE: My PS3 won't read any discs. The PS3 accepts the
it could be "Blu Ray Drive Failure", and you'll find it's more common than you think. its best to take it back to the shop were u got it from if still under warrenty or ring sony customer care . they might either replace the part or replace the console .
Posted on Mar 21, 2010
  • 277 Answers
SOURCE: When the ps3 turns on the blue light saying a disc
The most common reason for the game not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your game including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your game going again!.
Good luck.
Posted on Aug 20, 2010
Disc Stuck In 60G Console
  • Press the "Eject" button on the PlayStation 3 console and hold it for at least 10 seconds; if your PS3 has the "force eject" feature included it will eject the disc regardless of whether the console is frozen or not. Turn off the console and turn it back on before inserting new discs.
  • Unplug the power cord and any other cords from the PS3 console if the "force eject" feature does not work and you own a PS3 Slim. Turn the console upside down so that you have access to the bottom of the console.
  • Locate the small compartment door on the bottom of the console. Remove the door by pulling it up and off the console; a blue screw and a small hole should be visible inside the compartment.
  • Insert a Phillips-head screwdriver into the hole. Turn the screwdriver in a counterclockwise direction to manually eject the disc. Once the disc is removed, replace the compartment door and turn the PS3 console back to its correct position before reconnecting the power cable and any other cables you previously removed.
  • Jan 29, 2012 | Sony Playstation 3 (PS3) Console
    Game disc dosent pop up and when click on stuff it freezes
  • 1
  • 2
  • 3
  • 4
    Im unable to install disc in drive
    I have seen several suggestions at the playstation*com PS3 forums in the past, such as:
    | Zr0_C00L wrote:Try turning it off from the back,
    | then hold the eject button while you flip the back
    | power switch back on. Worked for my buddies
    | when his died (good thing too, it was my game
    | in there!)
    | i too did the same thing and it worked for me.
    This one with multiple discs jammed it sounds like it may apply to you:
    "If anyone is having any problems, this is what worked for me. What is more amazing is that my son somehow managed to force 3 discs into that tiny slot...no idea how he pulled that one off.
    So after two hours, a pair of tweezers, a fork, and a butterknife, I decided to try one last thing before giving up. I put the PS3 on its nose, disc tray down, held the eject button while it was on, and pushed a disc in and out of the drive. This caused whatever was in there to finally 'catch' as the drive had been trying to force everything out. After 2-3 minutes of play, a disc finally poked out. I pulled what i thought was one and two discs came out. I set it back down flat, tried to put a cheap DVD in (didn't want to test it with a $60 game) and it seemed something was still in there. I hit eject and out came the third disc. I put the DVD in reluctantly and the PS3 took it and loaded it right up. Unbelievable. After all this abuse, it's apparent these things are built like tanks."
    You gotta love children.
    Hope that helps.
    Comments: Oh, one more thing I remembered to try before you ship it off to Sony or open it up. Touch the eject button on the PLAYSTATION 3 system front for 10 seconds or longer to force the disc to eject. After removing and before reinserting a disc into the PLAYSTATION 3, turn off the system, and then turn on the system again to resume use.
    Mar 19, 2010 | Sony Playstation 3 (PS3) Console
    Playstation wont take any disc it'l eject but not insert
    i have seen this before... there is a little eye inside the ps3 bluray drive that senses when a disc enters and starts turning wheels with rubber feet on them to pull the disc in. when that eye goes bad for what ever reason the only way to get it to accept discs is to force it in slightly and it will spread the acceptance arms and pull it in. if it will not eject the disc correctly then the drive has been disassembled and needs to be reseated until it function right.
    the acceptance eye is fairly cheap to buy online but can be a pain to replace if you dont know what you are doing.
    Mar 07, 2010 | Sony Playstation 3 (PS3) Console
    PS3 will not accept discs
    sounds like a product fault, is it still within warranty? id have that sent off and checked
    or are there some kind of settings, one of the settings may be interfering with it accepting discs
    what discs are you trying to use? if you are using genuine PS3 dics and even DVD movies wont be accepted then there must be a fault in the system somewhere
    also, how long have you had it? less than a year and theres definitely a problem
    i'll be honest, i aint a Playstation Guru, but this is what im thinking it may be, i may be wrong, if i am then dont hesitate to pull me up i am willing to learn ;)
    Jan 16, 2010 | Sony Playstation 3 (PS3) Console
    My son has put two discs in ps3 and cant get either out now
    I researched this problem since my twin 2 1/2 year old sons decided that my PS3 was hungry and needed a steady diet of 3 discs all at once. On a similar discussion board, someone discussed using butter knives to pinch the discs (one on top and one on bottom) and pull them out. This worked to perfection! Just be sure to pull the power cable from the back of your PS3 prior to sticking any objects (i.e. metal knives) into the front of it.
    Nov 28, 2009 | Sony Playstation 3 (PS3) Console
    My cousole will not accept games, any ideas, when i try to load a game it will not pull the disc in.
    Your loading tray mechanism sensor or motor is malfunctioned or just plane broke.
    Nov 06, 2009 | Sony Playstation 3 (PS3) Console
    Ps3 not accepting/'sucking in' discs
    I have the same problem. Sony told me that it is a piece of the track gets stuck on the motor shaft and then the motor cant turn to "**** in" discs or spit them out.
    Apr 12, 2009 | Sony Playstation 3 (PS3) Console
    Have to force game in ps3
    ...this is normal, it's not a problem.
    Jan 21, 2009 | Sony Playstation 3 (PS3) Console
    Wont accept disc
    Try this....after a lot of frustration and research, what i found on the internet for this problem was usless. I tried holding down the eject button for 15 seconds to reset the disc drive, still it would'nt accept the disc. As i literally picked up the phone to ring sony, as the ps3 was on standby i pressed the eject button multiple times and heard 2 beeps each time, still the system stayed on standby. After that i then tried just putting the disc in as normal as its on standby and the system booted automatically and accepted my disc. I hope this helps others, as mine now works perfectly.
    (PSN ID is Burnsy333)
    Jan 04, 2009 | Sony Playstation 3 (PS3) Console
    Sony Playstation 3 (PS3) Console Logo
    18 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    shaun taylor
    marley mcelhinney
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
