Sharp aquos instructions
TV just says failed to receive broadcast ( E202)
  • Televison & ... Master
  • 9,639 Answers
That means the channel is active but but there is a problem with the delivery by the broadcaster, not a defective TV.
Posted on Jan 06, 2014
5 Suggested Answers
bbl242003
  • 1637 Answers
SOURCE: my sharp aquos tv wasn't
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me. Last, check your input setting to pop the tv set back over to where it used to be.
Posted on Jan 16, 2011
  • 8 Answers
SOURCE: Turned on set....screen all black except a dark blue rectangle in center which reads:Failed to receive broadcast [E202]
That message is presented when a selected digital channel is too weak to decode. Let us hope that something was accidentally changed:
Is the channel legitimate?
Is the antenna/cable still connected (to the Digital input)?
Go into menu - setup - channel setup. Is the selection of either cable or air channels correct for your situation?
Use menu - setup - Antenna Setup-DIGITAL to examine the signal strength. Is there nothing at all, or is it just a question of strength?
Odds favor a change in channel setup that you would not have made intentionally, or a simple physical problem (input cable, etc.). Start from scratch, and check the settings and connections you originally made. Hopefully it will be simple and cheap!
Posted on May 22, 2009
SOURCE: 37 inch Sharp Aquos. "Failed to receive Broadcast [E202]"
This is basically a message for no signal on the tv, make sure the tv itself is on the correct input for the type of cable used. The inputs are labled by numbers on the back of the tv. The input can be changed by the button on the side panel of the tv.
Posted on Aug 23, 2009
micromatikal
  • 2777 Answers
SOURCE: Failed to receive broadcast E202 Sharp
What do you mean exactly when you say "failed to receive broadcast"? Does it not get a signal of any sort? What about from DVDs, do you have a DVD player attached, does that work? Did it used to work just fine with regular TV signal?
Thanks, let me know more and I can definitely help!
Tim
Posted on Sep 29, 2010
Comcast tv failed receive broadcast e202
Check the input cable to the TIVO is is firmly connected at both ends?
Dec 16, 2013 | Tivo Televison & Video
Failed to received broadcast E202. what's wrong?
It means that the tv doesn't gets the correct signal from the cable or the antenna - check them.
Oct 07, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I dont want to use cable. I plugged a rabbit antenna and i get the message "Failed to receive broadcast (E202)
you need a antenna with digital capabilities.you can generally find them cheap and make sure tv is set on antenna instead of cable.
Jun 28, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Error Code E202, no picture, Sharp Aquos LC-45GD1E
Ur tv is not getting a broadcast signal,or ur tv cable or free air signal not getting from air antena,cables or dishes signals,or strong enough comming through.Get a better antena,like a digital antena,or a roof antena for better free air signal,cables or telicoms signals check ur boxes,push the power button OFF/ON to reboot it,to get signal back.
Apr 05, 2010 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Broadcast fail to show (E202)
U just take ur tv original remote just turn to channel 3?Why is ur cable service connected to channel 3?The proper way to connect to cable service is get the pay cable connected.Take ur original tv remote.Push Menu on ur remote,go to SET UP go down the CH Setup,pick cable,than scan for all the pay cables channels you pay for.
Mar 31, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
May 22, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquos HDTV Failed to receive broadcast
I too have this issue I beleive what is happening is the integrated tuner is not locking on to the channel because of a weak signal and then sending that error message . I am going to replace the cable from the splitter to this tv and see what happens. I have another new tv just installed from that splitter and it has all chanels. Remember to RE- run the locate all channels after anything is done to the cable splitter etc.
Mar 29, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquos LC-52D64U LCD-52 wdscrn tht won't scan in digital...
Seeing that you have a superior brand and not getting channels is a bummer. It may have to do with the setting, make sure you're set to cable rather antenna and then do a rescan. Btw, often times channels from an over the antenna is much clearer than from cable because cable tv has to compress the signal. If you're high in the air like the top floor of a building a cheap $10 will pull in great free digital channels. It helps to experiment and read the troubleshooting guide in your manual.
Dec 03, 2008 | Sharp Aqous LC-26D5U Television
Aug 13, 2008 | Sharp Aqous LC-26D5U Television
Televison & Video Logo
518 people viewed this question
Top Televison & Video Experts
Electro Med Services...
