Question about KitchenAid Food Processors
Kichenaid Handle Spring Mechanism
Kitchenaid KFP1333 - The food processor wasn't turning on when the bowl was installed - switch worked to turn on motor - culprit was the little black extrusion in the handle that presses the motor switch. Even with the top on, the plastic extrusion wasn't extending far enough to turn the motor switch on. I took apart the handle to see if something was hanging up the mechanism. There's a piece with springs on either, however, that piece fell off and so did the springs - before I had a chance to see what position they were in. So I just need to know how to position the springs to make the mechanism work correctly. I'm guessing that's all that needs to be done, but this is like a Rube Goldberg machine where all these pieces are in place just to turn on a simple switch. REALLY? Do all these pieces need to work together in a complex manner just to insure the switch is turned on??
  • 3 Answers
MOIN PRINCE
Posted on Dec 28, 2013
2 Suggested Answers
xalint1
  • 150 Answers
SOURCE: The plastic ? bowl of the processor is stuck
With the food processor I have it will not allow you to remove the bowl unless the top is off.Try take the top off or putting it on.Then remove it from the processor.
Posted on Sep 22, 2008
Cannot turn the lid on to kitchenaid food processor
It sounds like you need a new working bowl. It is not uncommon for that safety switch mechanism to fail inside the handle.
Jan 29, 2013 | KitchenAid KFP500 Ultra Power Food...
Food processor not working
check cover safety tab possible broken or faulty switch
Aug 29, 2017 | KitchenAid KFP740 Food Processor
My kitchenaid processor is not working
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. I am thinking this is an issue of assembly because the light is on, so the unit is definitely getting power.
Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
Jul 29, 2009 | KitchenAid KFP715 7 Cups Food Processor
Need to clean inside of handle on KitchenAid food processor
The plastic for the work bowl / handle is molded and one piece and cannot be disassembled. My best recommendation is to call Kitchenaid customer service to see what recommendations they have. Within one year warranty, they may replace the work bowl at no cost.
Their toll-free number is: 1-800-541-6390.
Jun 28, 2009 | KitchenAid KFP750 Food Processor
KitchenAid Food Processor 770 won't run
I am assuming the unit is getting power. The "power" LED should be lit up on the front of the unit.
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. Proper assembly is below:
If this has not resolve the issue, please ensure the outlet is receiving power.
If the unit is still not functioning, take a close look at the bottom of the work bowl where it meets to the motor base. The work bowl, when locked in, depressed a gray plastic peg. This is the safety mechanism. You may trying depressing this peg on your own with a pencil. If this activates the motor, this may indicate your work bowl is no longer seating correctly.
Also check the work bowl handle to make sure nothing is cracked. There is a plastic assembly in the handle that acts as a second safety feature.
If either of these things seems to be the culprit, I would suggest seeking a new work bowl or work bowl lid to correct the issue.
Jun 18, 2009 | KitchenAid KFP670 Ultra Power Food...
On the KitchenAid 3 cup Chef's Chopper, How do you lock the blade so I can turn on the chopper?
The Kitchenaid food choppers have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing work bowl, work bowl lid, and blade.
Dec 29, 2008 | KitchenAid KFC3100 Chef's Chopper Food...
Bowl handle doesn't make connection
I had this problem, I finally stuffed a tiny piece of tin foil into the hole the spring is supposed to go into to activate the machine. It works, but it is always on, even if the bowl is not locked into place so I have to be careful. I just store it unplugged.
Nov 16, 2008 | KitchenAid KFP750 Food Processor
Sep 22, 2008 | KitchenAid KFP670 Ultra Power Food...
My food processer does not work
I had the exact same problem. The red light came on when I hit the "On" button, but nothing happened. Then I noticed that when the lid is locked into place, a small pin in the handle goes into a small hole in the base. I took a wooden chopstick and poked it in this hole in the base, and the unit started running. I put the bowl and lid back on the unit and locked them into place, and this time the unit ran just fine. Yeah! I will remember this the next time my unit won't run even though I know that I've properly locked down the bowl and lid. Good luck!
Oct 11, 2007 | KitchenAid KFP750 Food Processor
Food Processors Logo
187 people viewed this question
Top KitchenAid Food Processors Experts
Shehu Pro
Shehu Pro
Ted Maxwell
ray gallant
Are you a KitchenAid Food Processor Expert? Answer questions, earn points and help others
