Question about Gateway Smart Rg Sr500n Adsl2 4 Port W/ Wifi
Cannot connect a wireless printer to smart sr500n router
Wireless printer not connecting with wireless network
tjt3
  • 44 Answers
SOURCE: Belkin 54g Wireless connection problem.
This is more of an explanation then a solution, but to best explain what to do I have to first explain why this is happening. When you add security to a wireless router or ap you add extra envelopes to the packets of info being transferred, adding encryption to that makes it much slower because the ap has to encode all packets coming to you and un-encode all packets being sent to the Internet. In our time this happens very quickly, but in computer time I just described a lifetime. In addition if your signal is not 100% you might have packet loss "more slow down". Now the answer, in your ap setup pages you can setup wireless security, set this to Mac address authenication and add the mac addresses of all the network cards that have access to this ap. This is by far the fastest methiod of secure data transfer.
Hope this was some help...
Tim
Posted on Mar 25, 2009
  • 10406 Answers
SOURCE: Belkin Wireless G Router causes loss of internet connection
Does your router have one LED lamp for each "wired" port?
If so, does unplugging the Ethernet-cable (the one that connects to your desktop PC) cause the lamp to go off?
Does reconnecting that cable cause the lamp to go on?
Also, on your desktop computer, there could be a lamp right beside where the Ethernet-cable connects into your computer.
Again, disconnect the cable, and reconnect the cable, to see if that lamp goes off/on.
Have you tried a different cable?
Do *NOT* connect your desktop computer to the 'WAN' port on the router -- connect it to any of the "LAN" ports.
Posted on Apr 23, 2009
SOURCE: Can't connect DSi with same security as comps
hello, yes i had the same problem, but i had it with many other computers, the way i solved it was going into the router settings and click the "restore default settings" then turned the router off for 15 seconds (for a fresh reboot) then when i had to set everything up again i got all my computers on the router and im able to add more without running into that same problem once again, or for a simpler solution try disconnecting the wireless on the computers and replugging them in.... that works sometimes as well
Posted on May 01, 2009
  • 10406 Answers
SOURCE: Trying to connect a wired network wirelessly to a router
No. You'll need to run a "cross-over" Ethernet cable from one of the "LAN" ports on the "downstairs" router, connecting to the "WAN" port on another router that you will need to buy, and place "upstairs", and connect the 4 devices to the 4 "LAN" ports.
Or, run a long "straight-through" Ethernet cable from your DSL-modem (or cable-modem) that is "downstairs", and move your wireless router "upstairs", and connect the 4 devices to the router's "LAN" ports.
Your laptop "downstairs" should still be able to connect (wirelessly) to the wireless-router that is "upstairs".
Posted on Sep 16, 2009
Testimonial: "Very clear instructions."
jbutler9
  • 132 Answers
SOURCE: Cannot connect to wireless printer, pc is connected to 54g direct
You will have to either add the printer through the Add printer Wizard and do a search for a newtork printer
Your best bet would be to install the Software that came with your HP printer on your laptop...at some point you should be given options to find and connect to a network printer.
Don;t forget to Rate/Vote
Posted on Apr 24, 2010
How to connect to linksys wrt1900ACS router?
If you scroll to the network settings on your brother printer, you will see that you can navigate to the option where you select your wireless network and then input your password.
You could also select the WPS option on your printer and router to connect them without the use of your router password if you prefer.
Apr 17, 2016 | Brother MFC Office Equipment & Supplies
What is a wps button?
Wi-Fi Protected Setup (WPS)
It is a network security standard that allow users to easily secure a wireless home network, and connect wireless client devices (iPads, smart phones, etc.) to it, without accessing the router configuration screens, and without the wireless network security key/passphrase/password.
Mar 18, 2016 | Canon Pixma Mx922 - Multifunction Fax /...
How do I find out my wifi password?
In Windows 7 Open Network and sharing center, on the left
click Manage Wireless Networks, right click your network and click properties, in the box that pops up click the security tab, check the box that says show characters and you should be able to see your password. Good luck!
Aug 08, 2013 | Gateway Smart Rg Sr500n Adsl2 4 Port W/...
How do I connect my HP 8250 Wirelessly? I have a router and a Linksys wireless-B adapter.
Make sure your router is set to accept Wireless-B connections...most aren't. Log into your router and setup wireless, using an SSID and security. Then connect with your laptop and you're good to go.
Mar 12, 2011 | HP - HP Photosmart 8250 printer
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
Good day to all. I have a problem of my NETGEARWPN824V3
To access the Smart Wizard installation and configuration program on your router:
  1. Connect your router to a computer by plugging one end of an Ethernet Cable into any of the four LAN ports on the back of your router.
  2. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  3. To install your router, simply click on the "Setup Wizard" link at the top of the left-hand navigation menu once you are logged into your router.
Configuring Smart Wizard for WEP encryption:
  1. Click Start then go to All programs. Look for NETGEAR wireless adapter folder then select the NETGEAR Smart Wizard.
  2. NETGEAR Smart Wizard wireless utility should appear on your desktop screen.
  3. Click on the Networks Tab. This will automatically scan for all the available wireless network within your proximity.
  4. Select the SSID of the wireless network that you want to connect, then hit the Connect button.
  5. On the Settings tab, click WEP under the Security option then select Enter Key Manually.
    Note: If the network key consists of 10 characters, set it to 64 Bits. If the network key consists of 26 characters, set it to 128 Bits.
  6. Type the 10 or 26 characters (Hexa decimal) keys on the space provided.
  7. In the Profiles field, assign a name to help you remember this wireless network settings in the future, then click Save Profile.
  8. Click on Apply to validate the settings.
  9. Once connected wirelessly, go to About tab and check for an IP address.
Configuring Smart Wizard for WPA encryption:
  1. Click Start then go to All Programs. Look for NETGEAR wireless adapter folder then select the NETGEAR Smart Wizard.
  3. Click on the Networks Tab. This will automatically scan for all the available wireless networks within your proximity.
  4. Select the SSID of the wireless network that you want to connect, then hit Connect button.
  5. On the Settings tab, select WPA under the Security option.
  6. Type the WPA password/passphrase inside the empty field next to the WPA drop down menu.
Best of luck and have a happy and safe 4th of July weekend!
Jul 02, 2010 | NetGear RangeMax WPN824 Router
EPC smart book cannot conect to internet
make sure that your wireless network card is turned on. reinstall your wireless network card driver. if nothing happened, consult your manufacturer. possible defective wireless network card. you can also test your router by using other computer if that computer can connect to your wireless router. if yes, then the problem is your computer. if not, then problem is your router. hope this helps.
Apr 01, 2010 | Computers & Internet
I have a sony vaio laptop running xp sp2 connected wirelessly to an HP C4385 printer. I can't get it to print in this wireless mode and I can't get a response from the printer when I put the printers IP...
I suggest you network the printer and access it through the wireless access point.
Also, I do not mean to insult your computer smarts, but if you do not have a driver installed, you will not be able to talk to the printer at all.
Aug 14, 2008 | Computers & Internet
Gateway Smart Rg Sr500n Adsl2 4 Port W/ Wifi Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
