Question about Frigidaire PLEF398AC Electric Kitchen Range
Burner on ranger is off
Turn off range but burner still on
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
Top burner or the oven burner?
Posted on Dec 28, 2013
My DCS range burners with electric start.
Very likely the spark module. All four are supposed to click when one is turned on, however they are supposed to stop when the burner ignites. Replace the module and test. Good Luck, Appliance Specialists
Jan 03, 2010 | DCS 36-6-1 Gas Kitchen Range
When I turn on a burner, all the other burners click like they are trying to turn on as well. The clicking is continuous and really annoying! Thanks for your help! Tammie
Anytime you turn on a gas range all burners click for safety reasons. If a knob has been turned by mistake the gas lights to prevent gas from escaping into the room. If you turn the control knob past the LITE position after the burner lights you should be OK and stop the clicking. If the clicking continues regardless you have a defective ignitor switch that must be replaced.
Aug 26, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Oven lights, but temp does not get above 100
The gas burner is broken. There is an upper burner and a lower burner. In-order for both burners to turn on, both must be working to let the gas turn on. If one burner element is out the oven wont get hot just warm.
Apr 29, 2009 | Maytag 30" Self-Cleaning Slide-In Gas...
What to do when one of the burners on the ranges do not turn on
HI the tap to the burner could be blocked might need greasing or the jets in the burner are blocked or the injector is blocked or the control switch is split and is turning on ths tap spindle
Feb 27, 2009 | Viking VGRC485-6 Gas Kitchen Range
Kenmore gas range
hi Clogged burners are a very common problem with gas ranges because foods spilled on the burners block the gas ports and prevent ignition. On some gas ranges you can remove the top ring of the burner to expose the ports. Here's how to clean a burner:
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
Nov 06, 2008 | Kenmore 75022 / 75024 / 75029 Gas Kitchen...
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Gas range top burners too hot
Get the installation manual for your range, and find the part on adjusting the low heat for the burners. On my Whirlpool, I found there is an adjustment screw inside the control knob shaft of each burner. The manual says turn the burner on low, remove the knob, then turn this screw until the flames are 1/4" high. Super-easy, it took me 5 minutes to do. I am sure all ranges have similar adjustments, might be in different locations - check the manual.
Feb 05, 2008 | Kitchen Ranges
Gas kitchen range
Most problems with gas ranges have to do with the flame--either it isn't quite right or it's nonexistent. Most new gas ranges have "electronic ignition," a spark igniter that starts the flame as gas flows through the burners. If, when you turn on a burner, it fails to spark but you hear sparking at other burners, the igniter or the burner switch probably needs replacement by an appliance repairperson. If your range has a pilot light, be sure the pilot light is lit.
Jan 18, 2006 | Crosley CE35100AA Electric Kitchen Range
Frigidaire PLEF398AC Electric Kitchen Range Logo
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
