Question about Goldstar LG LW1804ER Window Air Conditioner
Looking for LG Single Packaged Air Conditioner Model KK-C3608H00
What causes a packaged air conditioner/heating unit made by lg to blow cool air on high heat
It sounds like your heat kit isn't large enough for the cfm's provided by the air handler. Or you may have lost a heat strip or two
Feb 10, 2017 | LG Heating & Cooling
I have an LG hotel ac/heat ptac unit. It is showing a code of FP what does this mean?
I'm pretty sure the FP code means freeze protection engaged. It prevents the outside coil from freezing
Feb 19, 2015 | LG LP076HD3A Packaged Terminal Air...
Sanyo stw1525c2 packaged terminal unit I am
All available parts are discontinued. Troll for another used parts unit online like craigslist
Sep 26, 2013 | Sanyo 18KS52 Air Conditioner
Packaged Air Conditioner?
This WEB site will assist you in calculating the size of the AC unit.
http://www.airmerchants.com/whatsize.html
Dec 03, 2012 | Intertherm Heating & Cooling
I AM LOOKING TO BUYI AN AIR CONDITIONER / HEATER LIKE THEY HAVE IN HOTELS. WHERE MAY I FIND THEM
It sounds like what you are looking for is a Packaged Terminal Heat pump go to this site http://www.hvacdistribution.com. They also sale units like the one you have pictured(through the wall air conditioner).If you want to shop around then search for the first one and then through the wall with heat or a heatpump.
Nov 12, 2010 | Emerson Quiet Kool 5JV53 Air Conditioner
KINDLY SEND WIRING DIAGRAM OF DIAKIN PACKAGED ROOF TOP AIR CONDITIONER MODEL UAT08KAY-1
Hi; Call California number 1-310-769-0105 This is from what I can find to be correct.Also make sure You have the exact model and serial numbers. You can find the wiring diagram usually on the inside cover of the electric compartment covers...alpharome416
Feb 10, 2010 | Dometic Rooftop RV Air Conditioner
Goldstar LG LW1804ER Window Air Conditioner Logo
195 people viewed this question
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
