Question about Speed Queen AWN432 Washer
Green grease on washing model awm 372 3062 over 10 years old ?
Green grease left on washing after wash doesnt seem to be any noise coming from her
    Novelist:
    Scholar:
  • 124 Answers
Sorry to say but the water seal between the outer tub and the gearbox has failed and need to be replaced. Not an easy task and should only tackled by an skilled DIY persons. Repair kit and water seals are easily available from the manufacturer. Removing the center nut is a big challenge due to corrosion, soap residue and it requires a special socket.
Posted on May 12, 2014
My 4 year old roper washer leaves grease on clothes. On spin cycle the machine makes a screaching noise, and the clothes don't spin dry.
Possible that the belt is slipping and also there is some issue with the agitator as the gaps within seems to bring up the dirt or grease mix to the clothes.
So it is important to remove the panel and check the play on the belt, replace if the play is high and check if the agitator bearings are worn out. If so the agitator assembly must be taken out and checked.
Dec 09, 2011 | Washing Machines
The washing machine is very noisey when on the spin cycle. It makes a clunking noise. It is a new problem and the washing machine is a couple of years old, so it is not something simple like the pins left...
Please shut off the unit, remove the power and then using a good inspection lamp look into the back side/ underside of the washer.
manually turn to see if there is noise, this can come from faulty belts, motor, bearings on motor or the main agitator shaft assembly or even if the drum is out of sync due to poor suspension and support. If so remove and overhaul the unit. a bit of oil or grease can solve in many cases.
Also look for any foreign objects on the drum.
Jun 14, 2011 | LG Washing Machines
F&P washing machine leaking from the bottom of the tub. I have checked the pump and inlets they are all good. It is an Intuitiuve Eco model about 5 years old. The leak seems to be coming the centre...
The seal has gone, you need to replace the seal and bearings and also the shaft as the seal wears into the shaft.. The leak would have started out as brown in colour, then as the grease is washed out of the bearings, the fluid will run clear, then the bearings will start to make a noise when the machine is doing the spin cycle.
Not an easy job to do, hardest part is fitting the seal properly without tearing the lip on the shaft where it drives the agitator. There is a cover available to do so, but only at autherised repair shops.
Apr 29, 2011 | Washing Machines
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
Hi, my AWM 1200 is 9yrs old but still washes and
Your machine most probably has had water in the spin bearing. The seal has worn and allowed water to rust the ball bearings which are no longer smooth...Hence the noise! A fairly major job which could also need a new shaft and inner drum. Get quotes, but be prepaired. Too much detergent can also speed up seal failure......Good luck....Nomess
May 13, 2010 | Washing Machines
Draining water from washing machine
Filter is normally down r/h side of machine it unscrews anti clockwise..Good luck
Oct 10, 2009 | Whirlpool AWM6100 Front Load Washer
HI, I am having a lot of trouble with my front loader which is only about 4 years old. It seems to become very unbalanced during the coloured wash setting (even with a small load) - and yet is perfectly...
check teco coil on the back of the motor, it may have come loose'its about inch round thing it gives power to the the speed control module circuit board thats why its tumbleing too fast.bye Eamonn Ireland
Jun 11, 2008 | Whirlpool Washing Machines
Noisy Bosch dishwasher SHU43C05UC
your main wash motor is faulty it must be replaced.
May 05, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Oil and noise coming from my washing machine
i would think that the bearings have gone,spiin empty tub by hand and a rumbling noise will confirm also removing the rear cabinet will probably reveal a trail of rusty water down the outer tub.the answer is new shaft £40 and a bearing kit £22 your husband should be able to try it af as you say he is mechanically minded
Dec 19, 2006 | Zanussi FJS1225W Front Load Washer
Speed Queen AWN432 Washer Logo
85 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
