Question about Sony KV-36FV26 TV
Wrong model number listed in my original question
Welcomejee - you just helped me with problem of Sony tv but model number on original problem was wrong. I have a KDF-E55A20, not a KV36FV26. You gave me the replacement bulb # for the KV model as XL-2200U. My manual says the bulb for the KDF model is XL-2200....is there a difference? And finding them on the web, alot of them state they are New, Genuine parts, vs. buying them from Sony direct. They are quite a bit cheaper than Sony, but need to know correct part do I get the 2200U or just the 2200? Sincerely appreciate your help! Dana Mueller
    President:
  • Sony Master
  • 1,779 Answers
We use Philips or Osram for all lamps since there's only a couple and Sony is not one of them.
The Philips Bulb only is PHI 388 ( P22h1 xl2200 ) if I were working on your set, that's the bulb I would order. The cost will be between $99.00 and $145.00 depending who you order it from.
Posted on May 18, 2009
  • 10,594 Answers
I gave you exact and correct lamp part number of KDF-E55A20 and explained in previous reply that there is no difference between XL-2200 and XL-2200U lamp. both are same, first on came with new TV and second one is its replacement number.
KV-36FV26 is CRT TV and has no lamp inside.
  • Shahid Electronics
    Shahid Electronics May 18, 2009
    regarding price issue, I would recommend to buy Sony lamp from Sony accessories store and avoid aftermarket / cheap lamp for TV safety.
I have a 55" Sony Rear Projection TV and when I turn on he TV I hear the voices but it takes the picture about 30 minutes to come on? The bulb was replaced less than years ago
First is the model listed here does not use a bulb, it has 3 picture tubes. What is actual model number as I think wrong one is listed here.
Dec 20, 2012 | Sony KP-51HW40 51" Rear Projection...
Sony trinitron number is kv20fv12 what is the number for a remote controller for this tv
The original remote control number to this set is {RM - Y198}. If you buy its original one, contact the nearest authorized service center for Sony. The universal remote control codes for Sony Brand Tvs are: 0128 0013 0002 0071 0380
If you wish to buy a universal remote control, check whether there is these codes with its code list. The code list will be attached with every universal remote control pack. Make sure there are these codes with it.
In my opinion, it will be best to buy its original one. Original is Original, and Universal is Universal!!
Oct 27, 2012 | Sony FD Trinitron WEGA KV-34HS420 34" TV
How to fix a sony flat scrren tv when the is a line in the middle
This model indicated should not be able to do that---a line left to right in most conventional sets is a vertical circuit problem--is it possible you have listed the wrong brand or MODEL number?
May 17, 2012 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Need Replacement Front Panel
The Sony KV-36FS100 listed as the model number here DOES NOT HAVE A PANEL--uses a picture tube---if another model/brand let me know.
As far as the broken buttons---they may be available as a unit or not depending on the age of the set.
Getting an original remote would allow you to do without those--if you do not have the original remote (or it does not work) GOOGLE THE MODEL NUMBER OF THE SET WITH "remote" to locate a replacement.
Mar 24, 2012 | Sony KV-36FS100 36" TV
JUST FOR WELCOMEJEE How easy is it to replace the lamp on a sony 50 wega ? I dont have the exact model but if you could give me a rough idea
Lamp replacement is very easy in Sony TV, unplug tv from wlll socket, let cool down for half an hour, check at left side of tv, you will see lamp door, open it to see another safety door, unlock it and slide it out, there you will see lamp, pull it out and put new lamp, and put safety door, lock it and then lamp cover.
Plug back tv in and turn it On.
Thanks.
Aug 21, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Timer/standy light ison and screen is blank when
When did you replaced lamp last time in your Sony KDF-42WE655 tv?
It sounds lamp got weak, unable to fire up and need to be replaced.
Let me know your findings to help you out.
Thanks.
Mar 14, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Conversion alighnment is way off, do not have the original reote
no model number = no help, can`t look up anything if we don`t have model number to look up, please re-post
Jul 03, 2009 | Sony Televison & Video
Sony handycam LCD problem
1-864-761-11(FP185)
Part no.of flexible cable of DCR=HC21
Jun 09, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
Sony KV-36FV26 TV Logo
337 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
