Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE Profile range - Digital display went blank when the surface burner was turned on
I have a GE Profile range - model PGB918SEM4SS. It is about 2 1/2 years old. I have been having an issue occur on and off for a couple months. Occasionally when I would turn on the surface burner the digital display time would go out and needed to be reset. Then recently the display went fully blank when the surface burner was turned on. I was told the Oven Range Control was going out and needed to be replaced. I ordered a GE Stove Oven Range Control Glass Touch WB27K10176. In the mean time I was able to get the digital display to come back on by unplugging the power cord and then plugging back in. The new Control unit arrived. I installed it and it seemed to work just fine. Then I turned on the surface burner, and you guessed it, the digital display went out. I cannot get it to come back even by unplugging and plugging back in. Now what?
    New Friend:
  • 3 Answers
Hi
Mercedes NEC device can learn an extra key to ALL MB MOTOROLLA AND HAVANA AMAZONAS PALERMO... EIS with black or chrome key Version57
Device can repair any CORRUPTED key data VIA INFRA RED
Device can repair the old 204 steering lock or program a new steering even if the old ESL in not exist
Device works by infra red Much and much functions will be valid to all our customers
Price 7000 Euro you can visit our website to watch the you tube video
(Limited quantity only)
http://youtu.be/0Ce4z8JY-go
•Mercedes W204 - ELV
•Mercedes C W204
•Mercedes CL W216
•Mercedes A W168
•Mercedes G W463
•Mercedes GL W254
•Mercedes GLK X 204 - ELV
•Mercedes GLK X 204
•Mercedes ML W164
•Mercedes W 207 - ELV
•Mercedes W 212 - ELV
•Mercedes W207
•Mercedes W212
•Mercedes G W463 (MOPF)
•Mercedes W221
•Mercedes SL R230
•Mercedes SLK R171
•Mercedes Sprinter
•Mercedes Vaneo W414
•Mercedes Viano W639
•Mercedes R W251
•Mercedes Vito W639
Posted on Dec 28, 2013
fridgetech
  • 473 Answers
SOURCE: burner will not turn off
I will need the complete model #. There should be a sticker near the bottom front behind the drawer. Can't use the # that is on the owners manual.
Posted on Oct 09, 2007
  • 213 Answers
SOURCE: ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Posted on Nov 21, 2007
rickzilla
  • 706 Answers
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Posted on Sep 01, 2008
SOURCE: GE Spectra range
I just moved into a new apartment and my stove wasn't working properly. After reading the very helpful information posted by kd3ke, I decided to turn off the breaker to my stove, take off the back covering, and check out what was back there. I was experiencing the same problem as posted.... the burner light, oven light and clock were all working however, the burners did not get hot nor did the oven. After taking off the back panel, the cord did have just as he stated, a black, white, and red wire however the plug attatching to the stove did not have cordinating colors. It was just a grey cord with 3 copper wire heads. It seemed to me that the cord was twisted and therefore everything was backwards. Since I was relying on his post, that would explain why the stove still did have some power, just not all, because the voltagages were wrong. I flipped the three cord wires, reconnected them to the stove and then plugged it in and turned on the breaker... everything works now!!! :) I don't know if this will help anyone else since it may not be the same problem if your stove was working properly previously, but it fixed the problem for me since I had just moved in.
Posted on May 24, 2009
SOURCE: GE Profile Electric Stove, no heat, looks like it needs a reset
my oven doesent work and my key pad is locked
Posted on Sep 05, 2009
Stupidly caused oven to short out and blow breaker and after resetting breaker, nothing works at all.
Tracey recheck that the breaker is reset properly,you may have blown the digital display/control board. In which case a tech. will have to diagnose and repair.
Apr 13, 2016 | GE Profile JDP46 Electric Kitchen Range
Oven digital display does not work after an electrical surge
You may want to put in a claim against the power company, a spike may have burned out the control board
Apr 29, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 Gas Range Clock Display frozen with only an "8"
This happened to me.  I just unplugged it and plugged it back in.  It worked!
Dec 03, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE JBP64 Radiant Range - won't work
This is a very strange one, and you don't say how old this unit is or how long you have had problems with it, but most likely you have a poor electrical connection. Turn the breaker off and unplug the range. Remove the cover over the receptacle you just pulled the plug from and check all the electrical connections. If all OK, check the electrical connections where the cord attaches to the range. If still OK, inspect additional range and household wiring to range, including the connections right on the circuit breaker.
Aug 31, 2008 | GE Spectra JBP78 Electric Kitchen Range
Ge profile gas range
  What do you mean by the surface burners coming on.  This is a gas range,  correct?  Do you mean that the flame comes on?  Or does the spark come on and they don't light?
  Does the oven come on?
Oct 18, 2007 | GE Profile Spectra JGBP85 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
221 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
