Question about Crock Pots & Slow Cookers
Manual for kitchen living high speed blending and mixing system
I did not get a manual in box, looking for instructions, suggestions, how to clean
Tip
West Bend Kitchen Appliances Parts and Manuals
<p>Many people are buying and using <b>West Bend Kitchen Appliances</b>. Just like anything that gets used hard these appliances do break or accidents happen, which require you to look for parts to replace the broken pieces. Also many people will loose or throw away their <b>West Bend Manuals. </b> <br /> <p><br /> <br /> <p>If you need to find parts for your <b>West Bend slow cooker</b>, <b>West Bend coffee maker</b>, <b>West Bend Blender, West Bend popcorn maker, West Bend breadmakers, West Bend rice cooker/steamer, West Bend griddles/skillets/grills, </b>and<b> West Bend toasters/ovens </b>the best place to go is <a href="http://www.westbend.com/">www.westbend.com</a>.<br /> <p><br /> <br /> <p>When you get to the West Bend website you will see that you can move across the top tabs and see the different appliances in the drop down menus. You can also do a search for your model number is you know what what it is. The model number on most small appliances is on the bottom. Carefully turn it over or pick it up to see the model number.<br /> <p><br /> <br /> <p>If you click on an appliance then you can see under the picture the words replacements parts and instruction manual. Click on the words and you will then go directly to the replacements parts or the instruction manual. You can also go directly to the support tab at the top. There you will also have links to replacement parts, user manuals, frequently asked questions, product registration, warranty, where to buy, and contact information.<br /> <p><br /> <br /> <p>The website is very user friendly and contains a ton of information about West Bend kitchen appliances. After looking through many website, this is the very first place that you want to go and check out for all of your <b>West Bend kitchen appliance problems</b>. Most of the questions or needs that you have with the West Bend products will be solved right there.<br /> <p><br /> <br /> <p><br /> <br />
on Feb 08, 2011 | Crock Pots & Slow Cookers
3 lights blinking on my sccpvc709-s
Someone suggested there is moisture under the pot. Use hair dryer to dry it up.
Other suggestion is if you press both the (Low/High/Warm) AND the (Off) buttons at the same time, the controls will revert to the proper state
The instruction manual does not say anything. But you can find the Crock Pot number to call.
http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-crock-pot-Site/Sites-crock-pot-Library/default/v1397907098387/documents/instruction-manuals/SCCPVC709-S_43_38491059.PDF
Apr 20, 2014 | Crock Pots & Slow Cookers
Manual for kitchen/living electric pressure cooker
Could I get a PDF copy of the Kitchen Living Pressure Cooker manual? I have lost mine.
Thanks!
Debby
Jan 05, 2014 | Crock Pots & Slow Cookers
What is the temperature of low setting and high setting where can I get an instructions for Model KC271B
The manual is available here: http://www.sharkclean.com/manual/KC271B_REV_0804B.pdf . The high and low settings are more like those of a microwave rather than a direct temperature setting. On high, the slow cooker uses full power (35 watts). On low it uses 1/2 power.
I hope this helps.
(In one place it says 34 watts. In another it's 340 watts.)
Jul 01, 2011 | Bravetti KC281HB 8-Quart Slow Cooker
I need a instruction manual for a rival automatic
The manual is available from http://kitchen.manualsonline.com/manuals/mfg/rival_1/4450.html
Jul 20, 2010 | Rival Automatic Steamer/Rice Cooker 4450...
We too have the same cooker and no instruction manual!
Please send me a instruction & cook book please . FROM: MEARIE BOUDREAU PO.BOX 124 L ARDOISE CB NS B0E1S0 THANKS AGAIN. E MAIL @ marieboudreau21@yahoo.ca
Jul 12, 2009 | Breville SLC70XL 5.3-Quart
Chef's mark countertop convection oven Model #KA-6106 owner's manual
Hi hope you still visit this site...I own this convection oven and have the manuel...It is 37 pages,but cooking with this thing...It is important to remember to pre heat every time (IT never says how long)...and RULE 2 almost always use the low rack...The  High rack is for cooking two dishes at once..#3  small things or spices can get blown into the fan...so they need to cook on the top part of the high rack...I could copy my booklet and send it to you,but you are still going to have to learn to cook with it and adjust everything...It will heat up your kitchen some,also...Gets very hot...But the clean up is pretty easy. Mine has a wash cycle in it...Occasionally I unscrew the screen and clean it up if it has become soiled...I think it is the same thing as Mr T's Flavorwave.altho ours does not say infared.  Ya'll can email me at runshelley@yahoo.com...ANd you can see MrT's at www.thane.com and click on flavorwave oven turbo?? SURE looks like ours???
Jul 11, 2008 | Crock Pots & Slow Cookers
Crock Pots & Slow Cookers Logo
286 people viewed this question
Top Crock Pots & Slow Cookers Experts
tsalagi152
charles
Irene Tulloch
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
