Question about Hobart D340-6007 Mixer
Hobart D340 runs holding on switch in
D340 Mixer only runs if you hold the on swich in. Changed timer didn't help
  • 49 Answers
SOURCE: old man needs help with hobart 30 q mixer
it has to be torn apart to change grease and it is grease do not put oil in it. but it all is done from top under cover is the top of transmision the round cover comes of and all shafts need to be removed and I sugest a new main shaft seal and hub seal while your at it.
Posted on Dec 29, 2008
  • 1214 Answers
SOURCE: Hobart H600 wont shut off
Sounds like the side switch is the latching switch for the circuit, and you are right about it's operation. I strongly suspect where the wire comes off that slide switch and goes to the coil, there would be 2 wires at that connection, where the other one leads to one side of the start switch.
Looking forward to your reply. It will be easier to email the schematic that you come up with to me. Be sure and tell the the starter manufacturer that is installed as well.
stewartswitch@yahoo.com
Posted on Feb 15, 2009
bigg t
  • 640 Answers
SOURCE: will only stay running if you hold the "on" button down
Look in the bottom back of the pedestal,you will see a cover,remove the cover a contactor start switch and relay will be in there.I suspect the relay is bad,if you dont see a relay its a older unit.What is the ml #? You can find it on the data plate on the b ack.
Posted on Feb 17, 2009
bigg t
  • 640 Answers
SOURCE: hobart D300T mixer oil change.
Call your local hobart branch and tell them you need grease for a d300 mixer.Yes this mixer uses grease now.If it's older they used oil but is no longer available.
Posted on Mar 16, 2009
tooltech75
  • 80 Answers
SOURCE: wiring diagram for a Hobart D340 40qt mixer
i read in the manual that the wiring diagram is located on the inside of the top cover. check it out..
good luck
Posted on Oct 08, 2009
How come my Hobart d340 mixer is only running on high speed
Because either the low speed windings or low speed control is kaput.
Mar 03, 2016 | Hobart Food Mixers
Hobart L800 will not stay on unless you hold start buuton
If it has a bowl guard on it then it could be the bowl height switch or the side switch on the contactor. If it does not have a bowl guard then it is more than likely the contactor side switch.Check www.hobartservice.com for your local Hobart office.
Mar 15, 2011 | Hobart D340-6007 Mixer
Hobart D340 mixer will not hit 3rd gear
Check that the gear on the shaft that the clutch gear engages with does nort have a sheared key.
Feb 12, 2010 | Hobart D340-6007 Mixer
The dough hook wont cone off.
Got a hold of Hobart company and resolved the problem.
Jan 06, 2010 | Hobart D340-6009 Mixer
Wiring diagram for a Hobart D340 40qt mixer
good luck
Oct 08, 2009 | Hobart D340-6009 Mixer
Will only stay running if you hold the "on" button down
Feb 13, 2009 | Hobart D340-6009 Mixer
We have an old hobart mixer,when we turn it on it won't go into gear,,can't get any gear to work
you do not say what model mixer you have but more than likely the shifter yoke is faulty
Jan 04, 2009 | Hobart D340-6007 Mixer
Hobart L-800 Mixer is rotating in the wrong direction
Doesnt matter,just switch any 2 power wires.
Aug 29, 2008 | Hobart D340-6007 Mixer
On/off switch
if the mixer is pretty old then the timer is bad.If its a newer unit the timer or the bowl height sensor is bad.
Jul 01, 2008 | Hobart A200 Stand Mixer
Hobart 60 quart mixer
the motor protection board is doing its job.you should only use 1st speed to mix pizza dough.im a hobart technician and service these mixers all the time.let me know
Jan 27, 2008 | Hobart D340-6007 Mixer
Hobart D340-6007 Mixer Logo
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
