Question about GE Refrigerators
Managemylife com cannot find cam closure for freezer door
    Top Expert:
  • GE Master
  • 9,472 Answers
What is the model number??
Posted on Dec 28, 2013
Testimonial: "Mod. # TPS24PBDA-BS"
Samsung side by side refrigerator: freezer will not stop running
I have a 3 door samsung frigerator i need to know how to set the temp and make the ice work .
Dec 10, 2012 | managemylife.com
Amana SZDE27MPE
check the gasket fist if it's ok check the closure.there's a door closure on the bottom of the door and hinge that wears out and needs to be replaced,is the fridge door when closed side by side lower than the freezer door?it's plastic,here's a picture
http://www.repairclinic.com/PartDetail/Closing-Cam/R0181181/1035
part number R0181181 but call your local parts store and give them your model and p number or manufactures number and they will sell you the correct part,on some kits they give you the cams,shims and new screws,as for the drip pan overflowing,this is most likely from the warm air getting into the fridge melting out the frost on the coil or ice,usually when this happens the air ducts freeze up and the fridge section gets warm because the dold air from the freezer can't blow over into the fridge side because the air ducts are filled with ice,shut down the machine or unplug it,remove everything from the door,remove the top screws and then tilt out the door and lift up,put the door on it's side and change out the cams,it's usually a 5/16 inch screw holding them in place and then put it back together,while you have the door out check the gasket,any rips or anything change it out.hope this helps and good luck.
Aug 27, 2012 | Amana Refrigerators
Right side door does not close unless you push it closed with your hand
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on.
Part 11 on this diagram is your door closer http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170924&diagram_id=1335988#d1335988
Nov 06, 2009 | Maytag MFD2560HES Bottom Freezer French...
French door refrig..right door pops open when left door is closed
i would check the door closure, uderthe refrig door , sort of a "cam" style washer the wants to have the door close.. part number 67003638. $5 for the part
Nov 28, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Freezer Door wont shut
two things i would check. first would be an obstruction in the freezer compartment. ice bin perhaps. second would be the black plastic door cams that are to help close the door. Each door has two and they are at the bottom. one on the actual hinge and one on the bottom of the door itself.
Oct 24, 2008 | Hotpoint (HSM25IFTSA) Side by Side...
Freezer door pops open.
normal operation actually, gaskets are designed to seal door closed not to hold them closed, first off check the items on the shelves make sure nothing stick to far out preventing good closing.next the refrig should be tilted slightly back. to aid in the doors swinging closed( the should close automatically form 45 degrees.)ok for them to "pop" open so long as they close back shut. this works on top freezers and bottomr freezer refigs, sidex sides use a differnet system of closing, if htats the case look into replacing door closures(cams) located under hte door assy
Mar 04, 2008 | Refrigerators
Kitchen aid superba side by side doors slam
sounds like a door closure is broken on refrig door, a 2 part door closure(cam). look under door where sits on hinge, freezer door should have as well(use for comparison as to broken or not)
Feb 17, 2008 | KitchenAid Superba Architect KSCS25INSS...
Right Hand door swings open too fast
On the bottom of the door there is a part called a door closure kit.It operates like a cam. There are high and low points on the part that aid in the opening and closing of the doors. Do-it yourselfer project.
Nov 10, 2007 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
