Question about CF86 Code Card GM-Chevy Nova RS
Where to buy a solenoid for a 1988 3.8 hino RB 145rear engine
The engine won't start I can hear aloud clicking noise from the rear of the 7 mtr bus it just winds over and over but won't start
    New Friend:
Where to buy another remote keypad for my 2007HHR? And how much does it cost?
Posted on Dec 29, 2013
I'm looking for a workshop manual for a hino HO7C engine
Book mark http:/trove.nla.go. /version/232649771 or go through national libary of Australia book published by tokyo: hino motors Ltd 1988-1989 ps you can buy this online good luck colin
Jun 16, 2017 | Cars & Trucks
How do I find wiring diagram for 1988 Hino Rainbow Ch160A bus.experts advice would be appreciated.
hino schematics are found in the hino workshop manual for the vehicle
as the schematics is vehicle specific, you most likely will have to either get the manual or see if the service dealer will give you a copy from the manual
Jan 13, 2017 | Cars & Trucks
How will I fix my Toyota Hino SO5C engine,when I cranked the engine,it cranks but never starts?
first thing is to run the fault codes to determine where the fault could be
it may be a simple flat battery in the fob key that is not signalling the immobilizer system or air in the fuel system if diesel or the fuel shut off solenoid not working
Oct 11, 2015 | Toyota Cars & Trucks
Self greaser fault on 1988 hino rainbow bus
I am sorry that I can not help you, I do not know what a Rainbow Bus is but make sure you have a clean passages to allow the Automatic Lubrication to work.
Apr 15, 2013 | Cars & Trucks
I have a 1988 bass tracker ingnition switch won't
Hello cainld04,
Sounds Like The Start Solenoid Is Not Working.
When You Turn The Key To Start You Should Hear A Click ,If Not Solenoid Is Probably Bad,If Yes Then Starter Needs Service.
Hope This Helps.
Gordon
May 10, 2012 | Bass Pro Boating
I have a 1988 911 3.2 Carrera that sometimes doesn't start. Won't even turn over. Usually after I have driven somewhere and it's sit for an hour or more. There is a very, very, slight click...
I would start with the solenoid as usually when they go bad all you hear is a click when you go to engage the starter and then the starter doesn't rollover the engine.
Apr 24, 2017 | Cars & Trucks
1988 honda shadow vt1100, wont start, put new battery, new starter solenoid, new brushes in starter, solenoid clicks when I go to start it but nothing happens, fuses are fine. What is happening?
Hi, sounds like you are getting insuficiant power getting to the starter, assuming you have checked the engine turns over freely and is not seized, the switch circuit you have proved is working (as the clicking noise at the solenoide indicates this) as the solenoide switches the battery power to the starter motor, i ask myself if either the battery is suffiantly charged, or the leads from the battery to the solenoide/starter motor and earth leads are making good contact,
At the solenoide join together the both leads bypassing the solenoide using a pair of insulated pliers and the engine should turn over if the battery contains 12-14 volts, this can be done either with the ignition switch in the on/off position when ignition is off the engine will turn but will not start
Sep 04, 2011 | 1988 Honda VT 1100 C Shadow
My car wont start but my battery is good it just clicks
if your battery has 12 volts and you can hear click noise , try to locate the click noise. If that is coming from the starter location then the starter mtr is not working.a voltage check at the starter mtr with the key in the start position will verify the problem. if 12 volts is not present at the starter mtr thethe start switch or wires could be the problem
Feb 14, 2011 | 2006 Dodge Charger
1988 trooper (4 cylinder gas engine)
Replace starter solenoid contact under the solenoid copper looking piece of metal. You might can buy one from a place the rebuilds alternators and starters locally.
May 20, 2009 | 1988 Isuzu Trooper 2 Door
CF86 Code Card GM-Chevy Nova RS Logo
Top HPC Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a HPC Vehicle Part and Accessory Expert? Answer questions, earn points and help others
