Question about Little Giant VCMA-15ULST, 1/50 HP, 65 GPH - Automatic Condensate Removal Pu
Condensate pump runs but does not pump
My Little Giant TP-15ULST (VCMA-15ULST?) condensate pump runs constantly without pumping down the full reservoir. If I tap vigorously on the top of the pump it seems to "prime" it(though I know it does not require priming. Anyway, it will then work for a few pumping cycles and then go back to running with no pumping. I opened up the pump and saw that the impeller was not connected to the shaft. Does it just connect by friction when water pushes up against it or is it supposed to have a firm connection? If so, what do I do? Glue it?
  • Scott Long
    Scott Long Dec 29, 2013
    Okay. I super glued the shaft to the impeller and filled the reservoir about ten times (I lost count) and it pumped it out every time. I will give my final assessment tomorrow after it has had mor cycles. Thanks for your suggestion! Super glue is second only to duct tape. :o)
    Problem Solver:
  • 8 Answers
I have only seen a couple but they were pressed on the shaft. Superglue might work.
Posted on Dec 28, 2013
  • Scott Long
    Scott Long Dec 30, 2013
    Thanks for the suggestion. After a day it is still working. It looks like the problem has been resolved.
    Prodigy:
    An expert who has answered 500 questions.
  • 517 Answers
This fix will not last to long as the soap and warm water will soften the super glue
Posted on Dec 30, 2013
Testimonial: "I suspect you may be correct. I guess time will tell. However, when I first posted this it went under washing machines so I reposted it. This pump is a condensate pump for my gas furnace. Therefore there is no soap or warm water. Do you have a better solution?"
2 Suggested Answers
  • 9 Answers
SOURCE: I have a Little Giant VCMA-15ULST, and it seems
one word -disposable
Posted on Jan 24, 2011
My Little Giant pump (554405) is connected to our furnace/cac collecting condensation. It's been working fine for about 5 years. Now it keeps turning on for about 2 seconds and stopping only to repeat...
There could be gunk in the bottom....then the float does not work right and the pump will not pump either...
remove the pipes and/or hoses and then the screws that hold down the top....clean the inside really well and reassemble... that may work,,,, but it may already be burnt up...
if cleaning does not work the replace the pump...you should be able to buy a new one at a HVAC supply house or some place like HD or Lowes...they will be in the 50.00 or less range...
Jan 11, 2011 | Little Giant VCMA-15ULST, 1/50 HP, 65 GPH...
This is happening to me, too: Model # VCMA-15ULS condensate removal pump switch suddenly began working backwards - it will go on when the float is down and shut off when the float goes up. What is the...
The switch goes bad and that happens sometimes...
I guess you could change the switch but for the price of a new one it isn't worth my time... I junk em and throw a new one in...
heatman101
Sep 17, 2010 | Little Giant VCMA-15ULST, 1/50 HP, 65 GPH...
Water is dripping rapidly from my VCMA 15ULS. Do I need to replace it? Or can it be fixed?
I assume the unit is overflowing, because the pump is not running. Check th hose connection and be sure the line bringing the water into the pump is inserted in the opening. Can you hear the motor run? You can remove the top, and be sure the float switch is working and that the pump inlet is not clogged with debris. Sometimes you'll get mold and dirt mixed with water clogging the inlet. If the motor doesn't run, and the switch works, then it probably isn't worth fixing as you can buy these from 35.00--50.00
Jul 04, 2010 | Little Giant VCMA-15ULST, 1/50 HP, 65 GPH...
Little Giant Condensate pump runs for 1 sec when res not full
Is there a check valve in the pumps discharge fitting? If there is it may be stuck open or broken allowing some of the water to return to the reservoir once the pump shuts off which then may lead to the brief cycle between full cycles.
If there is not one, install one to keep any water from backing back into the reservoir and that should stop the short runs.
Aug 06, 2009 | Plumbing
Little Giant VCMA-15ULST, 1/50 HP, 65 GPH - Automatic Condensate Removal Pu Logo
238 people viewed this question
Top Little Giant Electrical Supplies Experts
 Kenneth
Kenneth
Mike
ken skalski
Are you a Little Giant Electrical Supply Expert? Answer questions, earn points and help others
