Question about Sanyo Optical Pick Up Laser Lens Sf-hd65 For Dvd Player
Sf-hd65 plays only dvd - Sanyo Optical Pick Up Laser Lens Sf-hd65 For Dvd Player
How to connect to DVD the projector optima
Depending on the DVD player you can either use an HDMI or Component Cable
May 30, 2010 | Optoma HD65 DLP Projector
Colour is very lacking in contrast
This could possibly be the colour wheel or the texas instruments dlp chip.
Apr 17, 2010 | Optoma HD65 DLP Projector
No Disc Error in Philps FWD17 with DVD and MP3-CD playback system
The problem with the system Philips FWD17 shows NO DISC for certain CDs which wont play. With regard to DVDs it doesnt recognise them at all. The disc spins and then stops showing NO DISC
I have replaced the lens with the same type and model SF-HD65. It still doesnt detect DVDs
Please advise.
Regards,
Gerry
E-Mail gerardf1960@gmail.com
Feb 22, 2010 | Philips HTS3400/37 System
New beamer optoma hd65,message: no source found
adjust the resolution to match. also, make sure the monitor port is activated.
Nov 04, 2009 | Optoma HD65 DLP Projector
My optoma hd65 projector worked fine for 2 months, now it will not detect hdmi signal from a motorola cable box or sony dvd player. Any idea's??
hi i am running a scart lead from my sky to my projector with a s-video lead going in the back of my projector but am only getting black and white picture!! can you help
Jun 06, 2009 | Optoma HD65 DLP Projector
My Optoma HD65 Projector stops starts working and
Possible cause is overheating.
Do you hear the fan working?
What happens when you use the lowest level light output?
Does it run longer?
Also possible cause is a faulty temp sensor.
AC wire connection may not be firmly pressed in socket.
Mar 01, 2009 | Optoma HD65 DLP Projector
Playing dvd's at 1080 resolution on my xbox 360
What kind of cord you using to connect to the projector? U need to be using at least a compent cable, a/v cords or s video wont work.
Dec 11, 2008 | Microsoft Xbox 360 Console
Playing dvd's at 1080 resolution with xbox 360
The 360 will upconvert DVDs to 1080P only through a VGA cable or an HDMI cable.
How do I find the finalize button?
http://merchant.satisfusion.com/sf/library/manuals/owners/DZGX20A_DZMV730_780A.pdf
https://merchant.satisfusion.com/sf/WarrantyCenter/registration/secure/Hitachi/Manuals/ModelNumberManualLinks.jsp?masterModelOID=SF-1111147462-119740&random=1201015492537
Jan 22, 2008 | Hitachi DZ-MV730A DVD Camcorder
Won't play
Fixed it! I got a new laser/optical pickup (SF-HD65) and replaced the old one. Replacing it wasn't too hard, just a little fiddly. Once it got it all back together, I fired up the unit with the case open and could easily see the red glow of the laser through the spinning disk. This didn't happen with the old pickup. Every disk I put in (originals and burnt stuff) was detected.
Even though the new laser worked, I can't be 100% sure the 24 pin ribbon cable / flat flex cable (ffc) connecting the laser to the mainboard isn't dodgy (I didn't try the old laser again). It's very flimsy and I may have somehow managed to re-seat the connectors better or bend the cable enough to make a contact over a break. If I get the "no disc" error again I'll replace that with the same or similar. For all out there it has the following written on it Kotobo E188165 AWM 20798 80C 60V VW-1. It's about 25 cm long, has 24 pins.
Regardless, I'm happy I didn't send the player to landfill. For $15 + shipping, replacing the optical pickup was cheaper than buying a new player that plays as many formats.
T1mb0
May 11, 2007 | Philips DVP5140 DVD Player
Sanyo Optical Pick Up Laser Lens Sf-hd65 For Dvd Player Logo
15 people viewed this question
Top Sanyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
