Question about Jandy In-Ground Plus HP Pump
Pump starts and stops after few minutes
My Jandy plus 1HP pump used for my pool starts and runs for few minutes and then stops.
Stops for a few minutes and then starts again
  • 990 Answers
Sounds like your motor is overheating, This is a sign of windings going bad and sorry to say you will probally have to replace the motor.
Posted on Aug 25, 2009
Hello , I have a 5yr old pool complete with Hayward Filter and a 1hp pool filter motor and 2 hp spa air injection motor connected to an air switch the in ground pool is 32K gallons. Problem is with spa air...
ALWAYS FREE.. SO IT SEEMS THAT YOUR NOT GETTING AIR, THESE BLOWERS HAVE FOAM IN THEM AND CAN ,AFTER A FEW YEARS GET CRISPY AND BREAK UP AND PLUG THE AIR PUMPS SUCTION PORT. THE FOAM IS USED AS A AIR FILTER AND A NOISE REDUCER , WHEN THESE BLOWERS GO BAD 90% OF THEM CAN'T BE REPAIRED ! = JUNK.. TO SEE IF YOU HAVE A RESTRICTION IN YOUR LINE OR LINES ,USE A SHOP VAC TO **** AND BLOW THE LINES IN AND OUT.. THESE BLOWERS ARE HELD IN USUALLY WITH ONE SCREW AND ARE EASY TO REPLACE ONE MORE CHECK 4 YA IS, THERE MIGHT BE A CHECK VALVE INLINE ON THE BLOWER , IT MAY BE BAD . BEST WAY TO CHECK IS TURN THE BLOWER ON FIRST , THEN TURN THE WATER PUMP ON.. HEY IF'N I WAS OF HELP GIVE ME A REVIEW OR A THUMB.. JAY YOUR LOCAL POOL PUMP WHISPERER IN FLORIDA
Nov 15, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
Pump motor not operating
The pump is defective and will need to be repalced.
May 16, 2010 | Intex 1000 Gallon Swimming Pool Filter...
Jandy/Stealth Pool Pump motot
Hi .. If ypou are gtetting air in the basket, then ytou have a leak somewhere in the system. start by closing off the skimmer, bottom, cleaner one at a time and see when the air stops gettingt in. Is there enough water level to cover the skimmer? have you checked the seal on the strainer at the pump? you might be able top hear hissing if it is at the pump.
May 02, 2010 | Jandy Stealth 2 HP UR Pool Pump SHPM2.0...
My well pump starts and stops
look up the info on the motor, it could be a start/run capacitor. low voltage will cause the pump to run hot. You really need to make sure the wiring is good and sixed correctly and the capcitor is ok
Aug 30, 2009 | Jandy In-Ground Plus HP Pump
Hayward 1hp super pump stops working
Your motor has a thermal protection switch in it the reacts to an overheating condition. Once the motor cools enough it will turn back on. You may be able to have the motor rebuilt for about half the cost of new if it is not damaged to severely. Take it to a local electric motor repair shop for service. If it is damaged beyond repair, you can shop around for a new one. If you would like a quote, contact us at www.arrowpools.net with your pump model number and we can quote it.
Jul 12, 2009 | Hayward Pool Products HAYWARD 1 HP 2 SPEED...
Pool pump starts and stops
The thermal cutout is turning it off, then it turns on after it cools. When it runs does it pump water? The pump may be dragging from a bad bearing or a clogged impeller. Make sure the suction filter is clean. I would suggest hiring a pro pump company to diagnose the problem further.
Please mark helpful if it was. Thanks
Jul 08, 2009 | Jandy In-Ground Plus HP Pump
Pump starts and stops frequently . pump will start but not run. Sounds like it will not get up to speed before it stops.
That sounds like the pump is cycling. Is there air in the pump basket or is it full of water? If there is air in the basket, you have a leak somewhere. Could be the lid has a crack, or the o-ring, under the lid has gone bad.
The pump motor may be going out on you also. If it is hot to the touch, there is a safety feature in the pump that will shut it off before it becomes too hot.
Jun 30, 2009 | Sta Rite Sta - Rite 1hp Dura - Glas...
Pool pump starts & stops on its own outside of programmed run
There are several potential problems:
  • freeze protection circuit causing pump to start - could be a bad outside air temperature sensor.
  • It is possible the new relay is bad.
  • There could be a short in the control wires to the relay
  • old programming shadow stuck in memory (not likely since you changed the boards)
Yes, the starting and stopping can harm your pump.
Jun 04, 2009 | Pentair 1hp Whisperflo Pool Pump In -...
Jandy pool pump will not prime it is a Jandy plus HP model PHPM 2.0
make sure pool is full of water
check skimmer weir doors and make sure not stuck in up position
fill pump basket with water and try to prime
if that doesn't work
replace diffuser oring
http://www.jandy-downloads.com/pdfs/PHP_Manual.pdf
May 25, 2009 | Jandy PHP High Head Pump 2 HP Up rated
Jandy In-Ground Plus HP Pump Logo
1,055 people viewed this question
Top Jandy Garden Experts
Dennis Key
Dennis Key
john h
Are you a Jandy Garden Expert? Answer questions, earn points and help others
