Question about GE Washing Machines
Ge washer wsere526foww not filling with water
jsrock516
  • 5911 Answers
SOURCE: GE washer keeps filling with water.
It sounds like you have a bad fill valve assembly. Normally the valve opens and closes by an electrically activated solenoid which is usually controlled by a pressure switch. However...IF the diaphragm that closes on the valve is broken, has a hole in it, cannot close all the way due to an obstruction, or if your water pressure is too low, the valve will remain open and water will leak by. Since you didn't mention any problems with the hot water side of the valve, I would suspect that water pressure probably isn't a problem. Turn the water off and remove the hoses to the fill valve on the back of the washer. Inspect the cold water side for any obstructions and/or check for any damage to the valve itself. If you don't find anything obvious, replacing the fill valve will probably correct your problem. I hope this helps.
Posted on Sep 10, 2007
jsrock516
  • 5911 Answers
SOURCE: Ge washer wont stop filling with water
The usual culprit for a washer that will not stop filling is the pressure switch. The switch is located inside the operator console behind the load size, or water level knob (this knob has different names based on the washer model). Before assuming the pressure is defective, however, inspect the pressure switch and ensure the small plastic air hose is still attached to it. It is common for this small air hose to come loose or develop small cracks or breaks. Without the hose installed, the switch cannot detect the appropriate pressure in the wash tub and will not shut off. The result: as washer that continually fills and will overflow. What appears to be a significant problem may only be a loose hose and few minutes of your time. Please inspect the switch, check the entire length of the hose for cracks and make sure the electrical connection(s) are intact and not corroded, then get back to me. I hope this helps you.
PS Make sure you UNPLUG the washer before servicing!
Posted on Dec 20, 2008
SOURCE: GE washer won't fill with cold water
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
Posted on Jan 19, 2009
honeymokey
  • 3113 Answers
SOURCE: washer wont stop filling even when its washing. GE
Replace water inlet valve, it's stuck open. You may try removing hoses to valve and see if something is holding it open
Posted on Jun 29, 2009
SOURCE: My GE washer won't fill with water; will agitate
The hitachi machine bring an error message C1B1. Please assist
Posted on Aug 01, 2009
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
Gfwn1100lww ge front loader washer wont fill with
check your water lines could be clogged or not even turned on at the valve behind it, also might be not enough pressure in line to make it work
Sep 25, 2013 | GE GFWN1100LWW Washer
Front load GE washer will not fill with water
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 03, 2010 | GE WSXH208A Front Load Washer
Water comes out verryy slowly when using cold wash GE large capcity washer
check the fill hose washer located in the washer cold water fill hose,they get clogged with lime and such,and when you replace the washer run hot water thru the hose to clean it out thoroughly,
Apr 24, 2010 | GE Profile WPRE6100G Top Load Washer
I have a GE washer, approximately 4-5 yrs. old. The model # is WSERE526FOWW. It seems to have multiple malfunctions. First, it started overfilling. I checked the tube that goes from the tub to the pressure...
Unplug the washer.
1. Remove the front panel. Take the tube off the pressure dome on the side of the tub.
Clean the hole in the pressure dome with a piece of wire. Soap scum and lint will stop it up.
2. Check the lid switch to make sure it is mounted tightly and get good contact from the lid plunger.
3. The timer may have loose connections. Unplug and replug the timer connections.
Jan 07, 2010 | General Electric WSERE526FWW Top Load...
GE top loader washer water keeps running will only cut off at faucets"
If disconnecting power does not stop the water fill, replace the washer's inlet water valve. It is the part the fill hoses screw onto on the back of the machine.
May 20, 2009 | GE WBSE3120B Top Load Washer
Jan 17, 2009 | GE Profile WPRE6100G Top Load Washer
Ge top load washer WSERE526FOWW
Dishwashers usually run on 115-volt or 120-volt power. The water they use comes directly from the water heater, and wastewater is drained into the sink's drainpipe. The dishwasher is not connected to the cold-water supply. For best dishwashing results, set the temperature control of the water heater to no less than 140 degrees Farenheit. Water cooler than this usually doesn't get the dishes clean, unless your dishwasher is a newer model that preheats incoming water. The water shutoff for the dishwasher is typically located below the adjoining sink.
Sep 11, 2008 | GE Washing Machines
Washing Machines Logo
23 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
