Question about Candy Dishwashers
WONT DRAIN AND SHOWS E1 ERROR CODEE - Candy Dishwashers
    Scholar:
    New Friend:
  • 53 Answers
First, use manual and or the device web site to understand the issue. Is their debris in air gap or in the bottom of the DW, where the drain is screened?
1. The air gap is usually located on top of the sink. Lift off the pretty cover, and unscrew the top cap nut. Is there rice and debris there? Remove it then. Reassemble and check it out.
2. The DW drains to the bottom of the unit where the pump is. This area is screened off so that the pump doesn't get clogging debris in it. is their leaf lettuce and stuff covering this? Remove that debris. Some times this area can only be accessed by removing the bottom spinning spray head. It comes off with a nut, possibly this nut is reverse thread. Reassemble when done looking for debris.
3. Is the drain line between the DW pump (located under the DW) and the waste pipe kinked? This line is a plastic corrugated line about 7/8" around the outside. It is a pumped waste and won't work if it is kinked, so unkink it.
4. Is the float stuck. This is a device on the bottom of your DW that tells the DW how much water is in the bottom of the DW basin. It looks like a mushroom. Gently move it up and down. Does it move freely or is it stuck? Unstick it.
Good luck.
Posted on Jan 11, 2014
  • GERR
    GERR Jan 15, 2014
    Thanks,
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    What is the error mean f1 E1 on my may tag front loader washing machine
    Barbara, F1 E1 error is your washer doesn't think the drain pump is working properly.bad CCU or pump.
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    have E1 and F1 error code fleshing and wate Sears PartsDirect
    http://forum.appliancepartspros.com/washer-repair/443358-f1-e1-error-fault-code.html
    Appliance Repair Forums
    Error code F1E1 null ShopYourWay
    Central Control Unit CCU Maytag MHW6000XW Washer
    Mar 07, 2016 | Washing Machines
    My LG dishwasher when I turn it on it drains the water, then it fills it up with water, about 1 min. later gives me the code E1 and drains the water again...
    LG Dishwasher Displaying Fault Code E1 LDF7810BB/01 LEAKAGE ERROR // Excessive pump motor RPM due to water leakage
    The manufacturer has assigned this error or fault code to indicate that when the drain pump is running it is not experiencing the back pressure it expects. This is usually an indication that there is a water leak in the drain system. Check all hoses and connections. Check under the dishwasher for any major leak. If all checks out, be certain there is a proper loop in the drain hose to prevent siphoning. Finally, if the problem persists, the drain pump itself might be defective.
    Sep 25, 2015 | LG Dishwashers
    I have a whirlpool duet model wfw70hebw. The washer stopped and I can't unlock the door. Have error code E1 F9
    Try unplugging for 30 seconds and plug back in. See if you are able to reset the controls after that.
    Jan 24, 2015 | Whirlpool Washing Machines
    Washing machine E1
    You have not included the make and model of your washer so that makes it pretty hard to answer for sure. A google search shows that several makes have an error code of E1 and it refers to a slow drain. Attached youtube video link is for a whirlpool washing machine and might help. If not repost with the make and model of your washer.
    Washer Repair Drain Pump Error F9E1 Maytag 2000 Series Whirlpool Duet...
    Aug 16, 2014 | Washing Machines
    What is E1 error code
    The E1 error code indicates a water inlet error. Do you still have your manual to test for this?
    Jun 20, 2014 | Kenwood KDW243A Builtin Dishwasher
    E2 error code aw-8990st toshiba wash
    Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
    E1: Water doesn't drain in time or not at all
    E21: Lid open
    E23: Lid not locking
    E31: Load imbalance
    E32: Check E1 and/or E31
    E5: No water coming in
    You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times.
    Hope this helps
    Jan 25, 2014 | Washing Machines
    How do you fix the error code E1 on the unit?
    air conditioner wont come on E1 shows up on panel
    Sep 07, 2011 | Haier hwr10xc6 Air Conditioner
    E1 Error code - no leaks - new pump - new pc board in Dec. 09
    The most common reason for an E1 error on an LD dishwasher (that does not have a leak, including directly under the dishwasher) is the drain hose between the dishwasher and the drain does not have a rise in it between the DW and the drain. Either install a proper AirGar valve or attach the hose to the bottom of the counter top so that it raises 30" between the DW and the drain. When that raise does not exist, the laws of physics tell you that you WILL have a siphoning effect from the DW into the drain, causing the LG to report error code "E1", which is true because of the water leaving the DW during all the wash and drain cycles.
    Good Luck!
    Apr 03, 2009 | Dishwashers
    Dishwashers Logo
    194 people viewed this question
    Top Candy Dishwashers Experts
    Charles T Nevin
    Charles T Nevin
     Evgeniy_Getz
    Evgeniy_Getz
    Are you a Candy Dishwasher Expert? Answer questions, earn points and help others
