Question about Meiko DV 80.2 Dishwasher
Unit locked in service mode - Meiko DV 80.2 Dishwasher
  • 1,144 Answers
Press the "0" key at any time to exit programming mode.
Per Service Manual.
Posted on Oct 07, 2017
How can I clear locking mechanism?
Only fix is to enter service mode and when you exit it should remove the stored code and allow you to restart unit. If not and you are certified you can call the Tech Line for more assistance. 1-800-662-3587. They will ask you for there account number before helping you. First enter service mode, allow auto test as it will test door locks, fill, drain, and spin functions. When you exit after this test it should allow you to restart the unit as normal. Good Luck
Apr 08, 2016 | Maytag MAH21PDD Commercial Front-Load...
The operation of remote control is prohibited
Enter into its service mode, and check whether external commands have been locked. If locked. open it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Even though it is locked to external commands, codes to use [service mode entry procedure] should work. If it too so not work, check and replace the infra-red sensor inside the TV. Contact any service technician.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Oct 09, 2014 | Sharp AQUOS LC-70LE845U 70" HDTV
Ricoh c8 problem solution
hi sir help me rico sp 100su c8 error whats the problem
May 19, 2014 | Ricoh Aficio SP 100SU e Laser...
Please call service
The most likely cause is either the fusing unit located in the right side door (orange in color) or a main motor lock. To determine what the trouble is, you need to enter the maintenance mode. On the control panel, press the "program * 6 keys in order. Press the right arrow key until service mode is displayed and press enter. If the display says heater error you have a bad fusing unit. If it says Rx motor, then the main motor is locking up. Check the drum and toner cartridge for motor lock problems.
Aug 01, 2012 | Muratec - MFX-1300 Copier
I have a durabrand DBTV1024 and it is locked and i dont have the remote that goes with it...please help me to get this tv
Hello
You can't unlock the V-Chip setting without entering into its service mode. This is actually a skilled work, and cannot be done without its remote control. If you have the remote control, entering into the s
This unit provided with the following SERVICE MODES so you can repair, examine and adjust easily.
To enter the Service Mode, press both set key and remote control key for more than 1 second.
Then set volume to minimum and press "0" digit on the remote control to unlock V-Chip and to set a new password.
From this proceedings, you can know that, without its original remote control, the set cannot be unlocked. Try to get it from the nearest Duraband authorised service center or from any electronic spare part shops at your town. OK.
ervice mode do the following>
Sep 30, 2011 | Durabrand DWT2704 TV
How can i reset my samsung wa75b9 washingmashine. The green lights are flashing and dont want to anything.
1st thing to do press the child lock mode in 10secont until to remove blingking to your washing machine,the child lock botton is in the panel you see the small face of the baby,follow the arrow whre exactly the child lock some model are two btton you need to press some is one only, if this one is not stop blingking its means some of your part is worn out,especially the main board of the unit.ask the service center how much the coz of the parta and consider the buy new unit of your unit is old.
Dec 24, 2010 | Washing Machines
"Control Locked" on panel
Try unplugging the unit from the wall for a few seconds, then plug in. If still locked, contact an appliance service company. You may have an issue with the door lock mechanism.
Apr 13, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Lock won't disengage
Try putting it into CLEAN MODE and wait about 3 minutes.... then cancel the clean mode. Sometimes this will release the relay if its stuck.
If that doesn't work, you have a problem with the latch relay and you need service on the unit. You can try and remove the latch assembly yourself, but it can be tricky, and you may create more problems than you fix.
Jul 19, 2008 | Ovens
Error U99 disc stuck in machine
Neat Things
I have also discovered a number of special things you can do using special key presses. These have not been documented in any of the user manuals. As an aside, one time I was trying to manually set the clock. There is an automatic clock setting mechanism, but it's never correct. Even if it is, if the program you are recording starts 1 second early, it looks like it started at "8:59 pm" instead of "9:00 pm". The way I set the clock is 30 seconds before the top of the minute (At exactly 30 seconds after 9:00, my clock goes to 9:01). This way, you will have a ±30-second window at the top of the hour to get the time-stamp correct. At any rate, I was trying to set the clock manually, but that function was "grayed out". I tried the "Reinitialize Settings", but that didn't help. I tried to change the TV-Guide settings, but that didn't help either. I tried to switch between cable and TV, but that didn't help (and somehow even that became grayed out). I called Panasonic Tech Support. I was told that my system RAM had gotten corrupted and I had to send the unit in for service! This made no sense to me. I asked her if there wasn't a way to clear the RAM back to some starting point. I was told there wasn't, and please send the unit in for service. Well, as it turns out, there IS a way to do that! (See Commands) Another time, I (somehow?) managed to make the DVD Drive tray "Lock". If I tried to eject a DVD, it would display "LOCK" and refuse to open. At least this time, when I called tech support, I was told what to do - but it really should have been in the manual.
Commands
To toggle the disk eject from "LOCK" to "UNLOCK": With the unit ON, press and hold "Power" and "Stop" for 5 seconds.
To eject a disk if the unit won't operate (U99, etc.): With the unit OFF, press and hold "Power", "Stop" and "Channel Up" for 5 seconds.
To initialize ALL parameters to factory defaults: With the unit OFF, press "Skip Rev" ( |<< ) and "Time Slip" and "Open/Close" for 5 seconds.
To enter "Service Mode": With power off, press "Stop" and "Time Slip" and "Open/Close" for 5 seconds. "SERVICEMODE 00" is displayed.
What follows are the more useful commands you can perform. You use the remote to key in a 2 number value. You can usually return back to the "Service Mode" by entering "00". If you get stuck, hold the power key for 10-12 seconds or until the unit shuts off. Try to avoid unplugging the unit while in service mode. In fact, because losing power while writing to either the hard disk or a DVD-R or DVD-RAM can lose everything, I use a small "UPS" (Battery backed-up Power Source) to power my units. This way, if the AC Mains go out, I don't damage anything…
Oh, and DO NOT experiment with any number combinations that aren't documented here. If you do, you may wish you hadn't…
00 = Return to Service mode start.
02 = Display Firmware Versions. The display will show the following for 3 seconds each:
1. DVD Region Code (should be Region 1 for USA)
2. Main Firmware Version (0950DL, or something like that)
3. Timer firmware Version (0110DC, or something like that)
4. DVD Drive firmware version (J125, or something like that)
5. ROM checksum (I think) - It should be all zeroes.
The ROM checksum will remain. You can get back to Service Mode with 00.
41 = The number of hours the laser in the DVD drive has been active.
51 = All display segments are turned on. Use 00 to exit.
61 = Date the unit was manufactured. YYYYMMDD
To exit Service Mode, hold the power key for 10-12 seconds until the unit shuts off.
Jun 20, 2008 | Panasonic Televison & Video
Vchip was accidentaly set by guest and password was forgotten
For Panasonic:
Parental Lock Feature
Combo's, Screen will say VCR Lock Activated.
During stop or power off, hold the stop/eject button on the unit for at least seven seconds.
Combo's, Another method
With unit on and no cassette inside, hold the rec/time button on the front of unit for 7 seconds.
CTV's Lock Mode
Only the on/off button will work,the others have no effect. Press the action and power buttons at the same time on the front of the set for 10 seconds or so.
LCD TV's, Lock Mode
If customer forgot Parental Lock Code, unit must be re-initialized.
Press and hold the Volume down button on the front panel, press the OK button on the remote for 5 seconds.
DVD's Lock Mode
Setting Method
The sales demonstration lock function is set by simultaneously pressing the "POWER" button of DVD Player on the remote control unit and the "STOP" button on the main unit. ("LOCKED" is displayed when the lock function is engaged.)
Release Method
The function can be released using the same procedure as for setting. If the remote control unit is not at hand, the function can be released by using the same method as for player initialization (pressing the "PAUSE," "SKIP/SEARCH<<"and "OPEN/CLOSE" buttons simultaneously).
VHS-DVD Recorder (DMR-ES40V), Forgotten Ratings Password
From the Owners manual: Open tray, Keep Pressing Rec and Play/X 1.3 buttons on the remote for 5 or more seconds.
Another servicer found resetting to defaults worked well.
(VCR>DVD Dub) + (Open/Close) + (DVD Rec)
Bill
Apr 01, 2008 | Panasonic CT-27E13 27" TV
Dishwashers Logo
85 people viewed this question
Top Meiko Dishwashers Experts
jdthefixer
Dennis Boxerman
ray gallant
Are you a Meiko Dishwasher Expert? Answer questions, earn points and help others
