Question about Vtech DECT 6.0 Cordless Phone with Digital Answering System
Phones ringer turn
The phone is not ringing. It shows the ringer off. What can I do to turn it on?
    Problem Solver:
  • 8 Answers
Press and hold the arrow that is pointing up towards the earpiece and see if that fixes it.
Posted on Dec 29, 2013
SOURCE: phone doesn't ring on incoming calls
i cannot fix the number of times for the ringer on my vetch phoneset
Posted on Oct 19, 2008
AvioriX
  • 689 Answers
SOURCE: lowering ringer volume on handset v tech 5.8 digital phone
You didn't indicate exact model of your phone. However I have indicated the procedure used for common Vtech's 5.8Ghz phones
Ringer volume
• With the handset or base in idle (off) mode, press MENU then
press ▲ or ▼ until RINGER VOLUME is shown
• Press SEL. You will hear a sample of the ringer
• Press ▲,▼ or a digit (0 through 6) You will hear a sample of
the new ringer volume and the volume bar will be increased or
decreased each time the setting is adjusted At the lowest setting
the ringer will be turned off and the display will show:
- OR -
• With the handset or base in idle (off) mode, press or of the
volume control will directly go to ringer volume menu
• Press ▲ or ▼ to adjust the ringer volume
Good Luck
Posted on Nov 11, 2008
SOURCE: my phone doesn't ring when someone calls and the
I have a vetch phone-3 on incomeing calls it only rings one time an thats it
Posted on Sep 20, 2009
SOURCE: my vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
Does your handset have a PROG button? Press that, then press the VOL+ button until you come to RINGER VOL: OFF. Press SELECT button, then use the ^ (VOL+) key until you get the desired volume level. Press SELECT again, then OFF. You're good to go.
Posted on Dec 18, 2009
  • 945 Answers
SOURCE: hi, how do you turn the ringer on of vtech 5.8 GHZ
http://www.retrevo.com/d/ds/progress?doc=415c14b0b538f65e013116610ddd5a8a
Click on the above for your manual and go to p7.
Hope it helps!
Posted on Jan 01, 2010
How do I reenable the ringer on my ATT 993 phone. The phone does not ring
Make sure to look on the phone itself, and see if there might be a button on the unit, or base station, that turns the ringer on/off.
Feb 21, 2015 | AT&T High Quality ATT 993 2 LINE...
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
The phone does not ring. How do you turn the ringer back on? The phone model is a hybrid system kx77020.
There's a ringer adjustment on the side of the phone. Does it ring in another jack? Does another phone ring in this jack? Panasonic system ringing is controlled by system programming, usually 408-410 or somewhere near there. If the phone works in another jack or another phone works in this jack, then you need to either turn on the ringer or turn on ringing at that port.
You may have to find the programming in the manual, or call your service tech.
Carl
Sep 03, 2010 | Panasonic KX-T7730 Corded Phone
Panasonic KX-TD7896 Phone phone no longer rings only vibrates
Is there an 'M' on the display? If so, that means it is in 'meeting mode.' All you have to do is press and hold the star key (*) and that will take care of it.
Nov 19, 2008 | Panasonic KX-TD7896 Cordless Phone
Panasonic cordless phone,
press menu,scroll down to ringer settings,hit select,scroll to ringer volume and hit select then press up the round button in the middle until you hear it make a "ring" sound. adjust your preferred volume and hit save.
Oct 16, 2008 | Panasonic KX-TG5632 Phone
Telephone ringer volume
make sure phone is off, then hit prog it will say directory arrow down with the volume key until it says ringer tone. it give 4 options for ringer tones then has off hit select and there you go
Jul 03, 2008 | Vtech 5.8GHz Analog Cordless Phone
How to turn on the ringer
While the phone is not in use, press the up arrow until you get the ringer volume you want.
Jun 28, 2008 | Uniden Cordless Phone
Uniden Phone
goto the name and hit store it will restore the name and when going threw the store process it should show you old parameters
or goto phonebook find name and edit its preferences for that name phone ringers are set ringers so when you pick one for gereral use thats going to be the general use ringer but special ringers is what i descriped in first part
menu handset setup then ringers for a general ringer you can change to a more pleasing ringer but over all cant turn off
May 10, 2008 | Uniden Cordless Phone
Vtech DECT 6.0 Cordless Phone with Digital Answering System Logo
88 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
