Question about Master Heaters Master Forge Medium Perfect Flame Grill Cover
Master forge girll 60000 btu 5 burner manul - Master Heaters Master Forge Medium Perfect Flame Grill Cover
Where do we bring for warranty, grill purchased in O.C. FL on 6/22/14
The warranty is provided by Master Forge so you have to register your purchase with the company.
Oct 07, 2014 | Master Forge GGP-2501 BBQ Grill Burner...
Fridgidaire stove clock not keeping correct time
Clock logic can not be changed replace the whole board
just lets you change the time will not let you slow it or speed up
Nov 14, 2013 | Frigidaire FGGF3054KF Gallery Series...
Master forge grill won't light with 2nd propane
Here's the problem and how to solve it. When you opened the valve on the tank, you did it as you normally would. However, the new OPD Valve tanks will often shoot a heavy load of gas to the regulator and lock it up.
To hopefully solve the problem, do the following:
1. Turn the tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow), until the valve is fully open.
Then light the burner farthest for the tank first. Did the burner light and does the flame height
look correct? If so, light the remaining burner(s) the same way. Do all the flame heights look
correct? If so, you solve the problem. Remember to always open the tank valve Very, Very
Slowly.
If that didn't solve the problem, you will need to replace the Grill's Hose/Regulator Assembly. You can pick one up at any hardware store or home center that sell grills and accessories for about $30.00. Take you old one with you for comparison purposes.
Hope this helped you troubleshoot and solve the problem. Please let me know and Happy grilling!!
Jun 28, 2011 | Grilling
I need a ignitor for a reddy heat 60000 btu heater
Master Parts www.mhttp://masterdist.net/ has what you need. Be sure to have your correct Model Number handy, when ordering.
Hope this helped you. Please let me know. Thanks.
Jun 04, 2011 | Heating & Cooling
Have 60000 btu radiant heater tried to hook up wrong kind therostat shorted something out any one what happend and where to get parts'
THIS IS A BRAND MARKETED BY ETHER GRAINGER OR MC MASTER CARR. CHECK THEIR WEB SITES FOR PARTS AVAILABILITY. hard to tell what burnt out without having unit n front of me.
Jan 12, 2010 | Dayton (3E386) Heater
I have a intertherm furnace 60000 btu inlet,
Souns like the thermocouple is gatting weak and needs replacing!
Dec 20, 2009 | Heating & Cooling
Can you telll me how many BTUs is has?
There is a UL plate on the heater it should strate the BTU's on it I did find this for you Berkeley Forge G-PH001PSS Open Flame Gas Patio Heater. Patio, Alimentation: Gas, Open Flame, 12000 BTU
Oct 12, 2009 | Berkeley Forge G-PH001PSS Open Flame Patio...
Creating an Audio CD with a 7 min. pre-gap
Try to record a 7 minute of silence...and put it as a "track 1" ....
Mar 20, 2009 | Plextor PlexWriter CD-RW Burner
Need allpro igniter
You should call Master Parts, they may have the part your looking for. You can contact them at 800-446-1446 or online at www.masterparts.net. I hope this helps...
Mar 03, 2009 | All-Pro Forced Air Kerosene Space Heater...
Master Heaters Master Forge Medium Perfect Flame Grill Cover Logo
64 people viewed this question
Top Master Heaters Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Master Heaters Grilling Expert? Answer questions, earn points and help others
