Question about Bosch 800 Plus Series SHE9ER55UC 24 Dishwasher, Stainless Steel
Stops mid cycle and resumes after I push on the door handle
My dishwasher will now consistently stop mid cycle with the floor light still ON. I think it is a problem with the latch sensor. When I push on the door handle, the cycle will resume. Sometimes it makes it to the end of the cycle, and other times it will stop again and I need to repeat the gentle nudge on the handle.
    Sergeant:
  • 236 Answers
Rather than a problem with the latch sensor it just might be that something is preventing the door from fully closing properly. Check that there are no obstructions stuck on the door/frame seals and that the seals are in good order. Perished seals can prevent the door from closing evenly and this may cause the problems you are experiencing. Also check that the door itself is not warped or out of alignment, this will also cause such problems.
Posted on Dec 31, 2013
  • 116 Answers
SOURCE: Leaking water on floor during drain cycle
First the source of the leak needs to be identified. pull the machine out from under the counter and remove the left side panel exposing the blue float assembly. Turn the machine on and observe the fill cycle. if water comes out anywhere on the fill mechanism then the inlet valve needs to be replaced. once the machine has filled and begun to cycle cancel the program and drain the unit. observe closly where the leak is happening. a leak during drain usually indicated a leaking drain hose.
Posted on Mar 11, 2007
textonor
  • 130 Answers
SOURCE: Bosch Dishwasher Door Leaking Steam
Pull the seal that is on the tank 1/2 way out then close the door. This will make sure the door is tight to the seal. This happens sometimes that the seal becomes flattened. I have been using this trick on Bosch dishwashers since this series came out in 1997.
Posted on Jan 06, 2008
  • 409 Answers
SOURCE: Bosch SHY56A Dishwasher
if the door doesn't shut, the push buttons should not work. that way you are not running your d/w with the door open. check the door latch, as it seems to be malfunctioning. if the d/w still does not work, replace the door latch.
Posted on Sep 13, 2008
here2helpBSH
  • 27 Answers
SOURCE: Bosch Dishwasher SHX46A latch stuck in down possition.
look at the latch via the hole in the door where it closes to the tank? is the latch faced away from the tank? if so, then grab a paper clip and fold it so you can hook it around the latch then just pull outward towards the tank. you might need to hold that paper clip with some pliers. if it happens more than once then you will need to replace that door lock.
Posted on Mar 19, 2009
  • 3 Answers
SOURCE: Diswasher Pump won't stop running
Introduction: This may work for your problem, but only if you're finding that you cannot get further water to flow into your machine. If your machine fills, OK, then this ISN'T a solution to your problem.
I have a Bosch SHV. My sink drain backed up, and the water accumulating in the sink then migrated to the dishwasher, through the drain pipe, causing the dishwasher to fill up and, it turned out, overflow a little. When I turned on the dishwasher, the water drained, but no new, clean water came through the hot water pipe. The drain just kept running, but nothing else happened.
Here's what happened. Under the main chamber of the dishwasher, by three inches or more, is a white plastic tray. It sits almost at the floor, and it may not be obvious that it's a tray capable of holding water. The overflow water spilled into that tray, which in turn caused a float in the far left side of the tray to lift (the way a toilet float lifts when the water fills in a toilet tank) and shut off the water intake valve (like the toilet float shuts off the toilet water flow). So long as that valve is closed, your machine will not run.
STOP: disconnect power supply at this point for safety.
To see the white plastic tray and thereby fix the problem, you'll need to take off the BLACK TOE-KICK (attached on my unit by two star-head screws at its bottom) and, possibly , the OUTER PANEL OF THE DISHWASHER DOOR (in my case, a custom wood panel (attached by a few screws through the inner side of the door, two screws that are accessed by popping off little--smaller than a dime size--covers on the sides of the doors, and then the door panel lifts up and out). (I took the outer panel off, but I can't remember if I would have had to reach into the white tray without doing so.)
Once you do that, you can see the white plastic tray. It doesn't come out--at least not without removing the entire machine--so try this. You can take your fingers and feel over and into the tray. You'll probably feel the water--I did. Look at the far left of the tray with a flashlight. Back there you'll see a flat, round, 3-inch diameter piece of white plastic sitting at the bottom of the tray. To its center is a generally U-shaped lever looking device, which, at its far left end, is connected to a red stick pointing up into the machine. When water goes into the tray, the float rises, causing the U-shaped lever to rise, causing the red stick to raise, which (though I couldn't see it) causes an electrical signal to run to, and shut, the valve for your water intake.
I took paper towels, and then a narrowly cut sponge, to sop up the water in the tray. I then took my shop vac and, using it as a blower, blew what little water was left right out. You might be able to use a hair dryer, but first sop out what you can or it'll take forever. Once you've done that, put everything back together and plug your dishwasher back in. My buttons are at the top panel. To reset, hold down the two buttons marked for clear drain for three seconds and release. You should be able to start up then. It took 15 seconds before the water started to run, but it did and the machine works fine again.
Interesting note: The valve that stopped the water from flowing in automatically opened once I got the water out of the tray. You don't need to reset the valve.
Good luck.
Montpelier Man
Posted on May 09, 2009
Model MDB7749AWB. Why does it stop mid-cycle?
Defective washer control board is the most common fault.
Mar 15, 2017 | Maytag Dishwashers
Service number kuds301xbl2
I would find the electrical breaker for this unit and shut it off for a minute, then re set the breaker thus resetting your unit.
Apr 28, 2013 | Maytag MDBH975AWS Stainless Steel...
I have a Maytag Quiet Series 100 dishwasher. There is an icon with a "3" in it just to the left of "heat dry." I just noticed this "3" light is on and the dishwasher won't start when I push the...
The "3" means hold for 3 seconds to child proof it. When it's on, none of the functions work. When you hold it again for 3 seconds, it turns off and your buttons will work again.
Aug 06, 2010 | Dishwashers
Dishwasher starts to work but after 30 seconds stops and two lights start flashing on pannel
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.Service manual below, if the above doesn't help. http://appliancejunk.com/ge/dishwasher/31-9137.pdf
Jun 24, 2010 | Hotpoint 24 in. FDW60 Free-standing...
It has the green light lflashing where it start but nothing happens
Jun 01, 2010 | Dishwashers
Inlet drain light on and no drainage
Apr 02, 2010 | Miele 24 in. G646SC Plus Free-Standing...
Whirlpool quiet partner III
Hello bckp,
Welcome to Fixya
If your dishwasher does not run or stops during a cycle
Is the Start/Resume indicator flashing? Opening the door or
interrupting the power stopped the cycle. Close the door and
press START/RESUME.
Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
open the door after the last cycle. Open and close the door,
then press START/RESUME.
Is the door closed tightly and latched?
(NOTE: On models with a dual-digit display, the control
displays “- -” during a cycle if it believes the door is not
latched.)
Is the right cycle selected? Refer to the “Cycle Selection
Charts.”
Is there power to the dishwasher? Has a household fuse
blown, or has a circuit breaker tripped?
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
Is the water shutoff valve (if installed) turned on?
It is normal for certain cycles to repeatedly pause for several
seconds during the main wash.
If the dishwasher will not fill
Check the overfill protection float that is able to move up and down
freely? Press down to release.
Let me know if any of these procedures helped you?
Huuum
Please remember to leave a rating.
Oct 04, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
DU1100 Stops mid cycle.
main control cpu unit failing
May 09, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
STOPS RUNNING IN MID-CYCLE
Try placing something like a chair with books or heavy objects on it in front of the door. Tip it with objects under the front legs and place objects on its seat until the pressure closes the door and the dishwasher starts. Put additional objects on the seat to insure vibration doesn't make the door pop open. If the cycle completes, the problem is probably the door switch. If not, the problem may be with the timer switch. If it's the timer switch the dishwasher will probably stop at the same position each time.
Nov 30, 2007 | Dishwashers
Bosch 800 Plus Series SHE9ER55UC 24 Dishwasher, Stainless Steel Logo
343 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
