Question about Bose AE2w Around-ear Bluetooth Headphones
Left speaker not working - Bose AE2w Around-ear Bluetooth Headphones
I just picked up a JVC r33 receiver. Only three speakers work both left and right B speakers work. And only the left A speaker works. IS there a web site to trouble shoot?
Try one of the speakers that you know works in the left B to see if it works. If it does, then you know you have 1 dud speaker which could be only a broken wire or bad connection. If the good speaker doesn't work, try checking all the connections and balance positions to see if the speaker left B output is actually set correctly.
Apr 08, 2015 | JVC Audio Players & Recorders
Left speakers do not work
As power amps are just two amps joined together all you need do is identify the left channel and compare it with the right. Ignore any parts common to both channels. The first thing to do is a visual check. If something looks broken burnt, or odd compared with the right channel then you have probably found the culprit. I suspect you could have a power output failure. It might be that the output devices are separate transistors. They might need to be replaced.
By the way just follow either the internal speaker leads or the connections to locate the right and left channels.
Nov 10, 2017 | Yamaha HTR-6130 Receiver
Pioneer DEH-P47DH Front left speaker not working, if i press audio button, i get no option to adjust balance, just fader. left rear speaker works and plays as loudly as right rear speaker. Huh? bad...
Are you sure you wired up the head unit correctly? It is fairly uncommon for a audio output amplifier to blow out leaving 3 working speakers and 1 not working. So more than likely it is bad wiring or a blown speaker. Best bet would be get a digital multimeter and ohm out the speaker and see if it has continuity and is the same as the adjacent speaker. You could also try swapping the left/right channel wiring and see if the front right speaker stops working when connected to the left speaker output or vice versa.
Nov 12, 2013 | Car Audio & Video
Creative SBS 370 2.1 - left audio channel is not working
This is coz of one carbon track of dual potmeter gone bad due to prolonged use.
Jan 28, 2013 | Creative Labs SBS 370 Computer Speakers
My left speaker doesn't work but my right speaker does. The cord to the left speaker is plugged in all the way.
Open the "Volume Control" applet & make sure the "Balance" setting is set in the middle of the scale. This way sound will go out through both speakers.
Nov 09, 2009 | Altec Lansing MX5020 Computer Speakers
Left Speaker not working
if you swap the speakers and the dead one moves,than it is the amp that is missing a channel,in your case,it is the speaker.
if you try the good speaker in both speaker outputs,it should work on both to confirm the dead speaker theory.
there may be a broken wire in the speaker from shipping.
Sep 04, 2009 | Bose 3·2·1 II System
My right speaker does not work, but left does
tell me how to connect vose speakers to my desktop computor
May 03, 2009 | Logitech X-230 Computer Speakers
DENON PMA520 Amp. Suspect left channel not working as set bias to all left and get nothing out of left speaker. Right speaker working. Tried interchanging speaker connections and get same result from...
you have malefunction in your left output stage-but can i ask you did you forget to press left speaker button in your amp (if you have one in your amp).
Jul 27, 2008 | Denon Audio Players & Recorders
Left speakers not working
tell me what sound card you have
Nov 24, 2007 | Logitech X-530 Computer Speakers
Left Speakers not working on A or B channel
Have you tryed yet to switch the right speaker where the left one is? If it works then you know the speaker is bad. If you move the left speaker over to the right channel and it works and sound now comes out of the left speaker, you know there is a fault in the amp somehwre. If your not a tech and have not had any solid state equipment repair experience, then your going to have to have the amp serviced by a trained tech.. Good Luck
Oct 30, 2006 | Pioneer VSX-454 Receiver
Bose AE2w Around-ear Bluetooth Headphones Logo
37 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
