Question about Orion St90 & St80 Replacment R&p Focuser
I am looking for spares of st 80 Machine
01 off timing belt: L08UC004190 01 off timing belt: L08TR000550 02 OFF Lubricqting pump :G06DG002450 02 off Lubricqting pump :G06DG000190
04 rodeo 3.5 di no power till full throttle
Your fuel pump may be bad. But have you checked the cam positioning sensor or map sensor. But one more thing, I would check the timing belts, if anything is one tooth off it will cause lots of problems. If you need parts. Look up Tom's Truck Parts on the internet. I have rebuilt 2 1995 Isuzu Rodeos and they have everything you may need.
Aug 27, 2014 | 2004 Isuzu Rodeo
I have a kenmore 80 series washing machine. During the second cycle it stopped working. It won't drain or spin. What should I do?
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 10, 2011 | Kenmore 24902 Top Load Washer
Wont drain water
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Sep 05, 2009 | Washing Machines
Kenmore Series 80 washer doesn't always spin, only 1/3 of time.
First of all check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely,if it's frozen or stiff,replace it. If the pump belt is broken or looks quite worn, replace it but be sure to check the pump pulley before you change the belt.
Sep 05, 2009 | Kenmore 24902 Top Load Washer
My kenmore series 80 washing machine won't drain water. We have checked the hose and that is clear, what should we check next?
Check the following.
2. Water Pump
Jun 25, 2009 | Kenmore Washing Machines
Kenmore 80 Series draining problem
Check the following before replacing the timer.
2. Water Pump
Jun 01, 2009 | Kenmore Washing Machines
01 civic timeing belt went, are the valves ok?
It is an interference engine and I always change the water pump when I replace timing belts because it's cheap insurance and you don't want to go there again if it goes out in a couple of months after you replace the timing belt.
Feb 03, 2009 | 1996 Ford Taurus
Orion St90 & St80 Replacment R&p Focuser Logo
35 people viewed this question
Top Orion Optics Experts
deton8 von Splosion
Tony Parsons
Tony Parsons
Are you an Orion Optic Expert? Answer questions, earn points and help others
