Question about LG VX9800 Cellular Phone
Lock code 228 four unlock - LG VX9800 Cellular Phone
Unlock code
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
Jul 11, 2010 | Sagem My411x Cell Phone
Need to be unlocked
If the lock code has not been changed then it should just be the last four of the cell phone number. If that doesn't work then the phone will need to be re-programmed and that will reset the lock code to default mode. If you have Verizon you can dial *228 send and option 1 to re-program the phone.
Nov 12, 2009 | LG Xenon GR500 Cell Phone
I have a 13 year old daughter, andhave taken her phone away from her. She locked the phone, and I need to see what is on it. How can I unlock the phone? It is a LG VX8300. Thanks
Sometimes, the last four digits of the phone number will not work as the unlock code, especially if your daughter has changed the code. Even if the phone is locked, dial *228, then press 1 when prompted by the automated system. When it tells you: "Your phone has been programmed successfully", press "Done" or "OK". Once the phone has powered off, then back on, (it will do this automatically) the lock code for the phone will be changed to the last four digits of the phone number. For example, if the phone number is (315) 123-0101, your lock code, after following the above instructions, will now be "0101". Also, you do NOT need to know the lock code that your daughter had for this to work. After the phone has powered back on automatically, you will be able to use the phone normally. *228 does not delete text messages, contacts, etc, but it WILL give you access to a phone which has been locked, without requiring you to know the code that she has set.
Jun 24, 2009 | LG VX8300 Cellular Phone
Forgot my lock code
The default lock code for any Verizon Wireless phone is the last four digits of your phone number. If you've changed the lock code, then you have two options:
1. LG phones can be reprogrammed even when locked, so dial *228 and press Send. When you hear the woman's voice choose option 1. When the call ends the phone will reboot and your lock code will be changed back to the last four of your phone number.
2. Bring the phone into a Verizon Wireless store, where they can read the lock code off the phone using their computers.
In the case of the original poster - if your phone isn't activated at all, as in it is not currently active on any phone number, then go with the second option. You could, if you really wanted to, call Customer Service and have them put that phone onto your phone number, then when you activate it (*228, send, option 1) the lock code will be the last four of your phone number.
Sep 26, 2008 | LG VOYAGER VX10000 Cellular Phone
Unlock lg chocolate vx8500
Hi everyone
There's good news and bad news. The good news is that you might well have forgotten that the default password on the phone is 00000000 (that's eight zeroes). The bad news is that if you've changed it to something else and that's what you've forgotten, you might well need to take the phone in to a service center to have them help you break it back open.Please put a good rating on my profile.
Kind regards
Dustin Ellse
Jun 05, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Unlocking LG VX4400
I heard *228 might work..but it might be an activation code..not a reset code. I'm going to try it.
May 27, 2008 | LG VX4400
Verizon LG vx9900 unlock codes
last four digits of your phone number. i just locked it and i tried that and it worked.
Feb 18, 2008 | LG enV VX9900 Cellular Phone
Unlock LGVX8300 passcode
Try dialing *228, then pressing 1. This reprograms the phone to factory defaults, making your security (lock) code the same as the last four digits of your phone number. For example, if your phone number is (315) 123-0101, then after following the above instructions, your passcode is now "0101". *228 is accessible EVEN when the phone has been locked. This method does NOT delete contacts or change your phone number. All of that information remains the same as before you dialed *228. Also, you do NOT need to remember your old passcode for this to work.
Nov 21, 2007 | LG VX8300 Cellular Phone
LG VX9800 Cellular Phone Logo
14 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
