Question about Swingline Office Equipment & Supplies
Swingline 790 - Swingline Office Equipment & Supplies
E4 error code
Here is a list of all swingline laminators manuals.
Find the type you have and just look in the manual if they have error's fixing instructions. Plus it is always great to have the manual:
http://www.swingline.com/swingline/us/us/s/2691/manuals.aspx
Feb 20, 2013 | Swingline Fusion 5000L 12" Laminator
Cant find staples for swingline 101 tacker
Hi, Last time I bought them from amazon, here: Amazon com Swingline Heavy Duty Staples 1 4 I hope this helped. Have a nice day
Feb 12, 2012 | Tools & Hardware - Others
How do you open swingline tot 50
Here's a video that shows how to open an older Swingline Tot stapler:
Vintage Swingline Tot Stapler Demonstrated
Nov 15, 2011 | Tools & Hardware - Others
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
We have a swingline model #690 - after loading with new staples, it does not staple. It is plugged in and makes a sound like it's stapling but does not release a staple.
1. Make sure you have the correct staples for the machine. The type appears to be:
Swingline 50050 Cartridge Staples, Chisel Point, 1/2"" Crown, 3/16"" Leg, 5000 Per Box High-quality Swingline cartridge
2. Check the cartridge to make sure there are no visible jams.
3. Contact the manufacturer at http://www.acco.com/swingline/, or
Repair Service/Technical Support:
Phone: 800.790.7787
Apr 18, 2011 | Swingline Portable Electric Stapler
Swingline 270 (69270) Staple ends are left mostly open Also, stapler makes a significant popping noise with each use
Swingline, now owned by ACCO, should have a service manual that would tell you how to clear jams - here's the url - http://www.acco.com/contactus.aspx#swingline. If not, you can also send them your question directly so they can help you resolve the issue.
Jan 27, 2011 | Office Equipment & Supplies
My Swingline Optima Power Ease will not staple, nor can I open it to try to find out why. There are staples in there, but it feels like there are no springs
This happened to me as well. I am not sure what causes this but heres what I did to fix it.
Just grab the top part of the stapler ( where it says Swingline) and pull up, like you are trying to seperate the top and bottom. You will hear a click and your stapler should work fine.
Sep 14, 2010 | Staples Swingline® 36115 Staple Guns Tools...
Cant find replacement brads for swingline
the problem was not with a stapler it was with an electric brad nail gun made by swingline , after researching this, my swingline (printed right on the gun) turned into a "powerfast electric nailgun model 32003" which will take arrow replacement 1" brads .
May 04, 2009 | Staples Swingline® 36115 Staple Guns Tools...
23 people viewed this question
Top Swingline Office Equipment & Supplies Experts
Paul Bade
Stitch85
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Swingline Office Equipment and Supply Expert? Answer questions, earn points and help others
