Question about Canon Pixma MG5220 InkJet Printer
Mg5220 orange light
Steady orange light
The printer has power. We are unable to turn it on. The orange light comes on but we are not able to reset. We also get a message that the printer is offline.
Do not know what kind of printer it is but usually orange lite means out of paper, jam or no toner cartridge. to gen on line go to control panel click on printers, find you printer and right click the mouse. you should see a drop down menu and one will say "use printer online".
Sep 30, 2013 | Canon Pixma MG5220 InkJet Printer
How do I replace my Ink cartridge in my Canon MG5220 Printer?
Hi
  • Remove the orange tape on the new cartridges completely.
  • Remove the protective film completely too.
  • Twist the orange protective cap horizontally to remove it and be careful not to block the L-shape air hole.
  • Open the cartridge compartment.
  • Tilt the cartridge and insert it under the label and against its matching color.
  • Push the mark on the ink tank firmly until it clicks in place.
  • Use the same procedure for the other cartridges.
Hope it helps.Thanks!
Feb 29, 2012 | Canon Pixma MG5220 InkJet Printer
The color ink cartridge that is " blinking " is
Don't buy Canon as they absolutely ROB you for the ink!! They are worse than ****** dealers! At least HP allows you to use non (rip-off) OEM cartridges without all the hassle! My printer will be thrown out after the ink runs out as I will not be ripped-off by Canon again!
Apr 30, 2011 | Canon Pixma MG5220 InkJet Printer
I have a NEC VT470 Projector. The power light is steady orange and the status light blinks red 6 times.
steady orange means projector in standby mode
red light 6 times is a lamp error.
either the lamp is old and wont start up or the ballast power pcb is not working.
can you hear the sparking of the high voltage trying to strike the lamp.
if you can then the lamp may be dodgy.
can you borrow one to test it out
Mar 02, 2011 | NEC VT470 Multimedia Projector
Toshiba satellite A100 dead. orange steady battery light with mains connected and power button lights shift key and 2 function lights - that's it.
It will turn GREEN when the battery is fully-charged.
Is there a problem with the battery not accepting a charge?
Remove the battery, to see if the computer will start without it.
Do these 2 lights just "blink" once, and then go out?
Does a "power" button stay lit?
Have you hired a professional computer technician to trouble-shoot?
Sep 17, 2010 | Toshiba Satellite A100-S8111TD Notebook
Power light is steady orange and lamp light is red but there is a new bulb in it. NEC VT676
Mar 02, 2010 | NEC VT676 Multimedia Projector
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Linksys wireless broadband router and wireless access point
Hi I would love to help you with all the resources and knowledge I have, however, this would require online chatting kind of. You either reach me using the live chat feature of Fixya or just add my msn id in your messenger : sandeepbakshi@hotmail.com. Whenever I am online, I would assist you. Again, if the above given suggestion is not possible, please give me the following details: 1. exact model no (on the bottom panel) 2. firmware version (if possible) 3. no. of hard wired PCs (directly connect) 4. No of wireless computers 5. ISP 6. any other device connected to the router 7. status of internet on the hard wired PCs 8. status of wireless computers 9. The status of lights on the router (dont forget to specify the labels on top of the lights to make things clearer) thank you
Mar 10, 2007 | Linksys Wireless-G WRT54G Router
Canon Pixma MG5220 InkJet Printer Logo
42 people viewed this question
old marine
old marine
