Question about JVC GR-D240 Mini DV Digital Camcorder
No image on my screen - JVC GR-D240 Mini DV Digital Camcorder
Can't print screen in netbook
Print Screen
Use this method to print screen.
Press and hold down the Alt key and the press the PrtSc key, this places the screen image into the Clipboard. .
Open a blank Word document and then Click on Edit - Paste.
The image is then places onto this page, you can up the image by holding down the Shift key and then place the cursor on the bottom corner of the image, then press the left mouse button and drag it down to the right, release the mouse button when you have d the image to your requirements.
NOTE - Holding down the Shift button will maintain the image in the correct proportion.
You can now print this image document and or add text before printing.
Sep 22, 2012 | HP Mini 110-1037NR Netbook
Print Screen on Gateway 820gm
You need a printer attached to your computer.
Print Screen
Press and hold down the Alt key and the press the PrtSc key, this places thescreen image into the Clipboard. .
The image is then places onto this page, you can up the image by holdingdown the Shift key and then place the cursor on the bottom corner of the image,then press the left mouse button and drag it down to the right, release themouse button when you have d the image to your requirements.
NOTE - Holding down the Shift button will maintain the image in the correctproportion.
Apr 04, 2012 | Gateway 820GM (827103045345) PC Desktop
FIX SCREEN RESOLUTION
Depending upon the screen resolution that has been set inDisplay, the image will be distorted on these large wide screen monitors.
Create a large circle image using a draw program such as Paint (hold down theShift key as you create the circle as it will draw a perfect circle).
Open Control Panel - Display - Settings tab and adjust the Screen resolutionslider, increase or decrease the screen resolution then bring the circle imageto the front and check the image, if the circle is still distorted then changethe screen resolution and check the circle again until you are satisfied withthe image of the circle. When you are satisfied then click apply.
Mar 14, 2012 | Dell OptiPlex GX260 PC Desktop
Wide screen stretches all my photos
Wide screen monitor distortionDepending upon the screen resolution that has been set inDisplay, the image will be distorted on these large wide screen monitors.
Dec 09, 2011 | Samsung Computers & Internet
I have a ProBook 4520s. I am trying to do print screen by preesing the fn and insert keys. Its not copying. The machine is 5days old.
Most cases, when you try to get a screen shot of your computer by using print screen, it only adds it to the clipboard.
1. Hold "Fn" key and press "Insert(prt scrn)".
2. Hold the Windows key and press "R".
3. In the dialog box, type "mspaint", without the quotations.
4. Once paint opens, hold ctrl (Control) and press "V".
The image of your screen should paste into paint.
May 23, 2011 | HEWLETT-PACKARD HP ProBook 4520s Notebook
The images on the monitor are stretched lateraly
Depending upon the screen resolution that has been set in Display, the image will be distorted on these wide screen monitors.
Create a large circle image using a draw program such as Paint (hold down the Shift key as you create the circle as it will draw a perfect circle).
Open Control Panel - Display - Settings tab and adjust the Screen resolution slider, increase or decrease the screen resolution then bring the circle image to the front and check the image, if the circle is still distorted then change the screen resolution and check the circle again until you are satisfied with the image of the circle. When you are satisfied then click apply.
Feb 24, 2011 | LG W2053TQPF 20 inch Monitor
I can view the images taken, but when I try to take an image the LCD screen does not show the image, screen is black
hey my camera just did the same thing, have you tried replacing the batteries - i thought it couldnt be the batteries because the playback screen still showeed up just not the one to take photos but i just put in newly recharged ones and it can take pics again so maybe try that :)
Apr 22, 2009 | Fuji Finepix S6500FD Digital Camera
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Samsung D900i Screen image sometimes reversed. Screen goes blank and image moves randomly
Hi
I can tell you how to solve the reversed image. With the camera running look on the side of phone where the up/down volume keys are. If you press up button you will notice image on screen change. I think the down button inverts the image? Up or down this should correct your inverted image problem.
With regards to people experiencing lines and blacked out screens this appears to be a phone fault.
Jul 15, 2008 | Cell Phones
JVC GR-D240 Mini DV Digital Camcorder Logo
15 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
