Question about Bushnell BackTrack Handheld GPS Receiver
How to connect usb cable to my bushness backtrack
Auto trans shift cable bushing for 2005 chevy trailblazer
The only true fix is a replacement cable available from dealer or online.
Mar 10, 2014 | Products Shift Cable Bushing Kit: Products...
Where to get a charger for bush mp 3 player
You can charge the MP3 player with the supplied USB cable. Connect the USB cable to the MP3 player and then plug it into the USB port on your computer.
Jan 04, 2013 | Audio Players & Recorders
New Bushnell Backtrack won't turn on.
I have the same problem with my Backtrack. I unlock back battery cover, unscrew some screws. Then I take the screen, check connection - it's ok. Then I try to close power switch with screwdriver. It started, but doesnt worked. There are some symbols on the screen. It's all I can do. My BackTrack still won't worked. For comments: greenspot@mail.ru
May 28, 2012 | Bushnell BackTrack Handheld GPS Receiver
None of the keys work.Unable to type the password for user to open the windows Kindly help V A Ganesan
hello friend...hope so your problem is regarding logging in windows...any kind of operating system can be reset or hacked with an linux operating system installed in just an usb
so first download this operating system to your pc from the below link
http://www.backtrack-linux.org/backtrack/backtrack-4-r2-download/
then download this software to install your operating system to get into your pendrive
http://www.pendrivelinux.com/universal-usb-installer-easy-as-1-2-3/
regarding the usage of the above software, u can refer the same page itself
then when all is done change your BIOS settings to boot from pendrive(as primary booting device)...
then watch this video link to reset your SAM file to reset your password
PIECE OF CAKE:-)
"feel free to ask further help...am here to guide u based on computers:-)"
Jul 25, 2011 | ASUS K50IJXA1 156Inch Versatile...
How do you replace the linkage for the manual transmission
There is a shifter cable set you buy from a parts store. Get a repair manual at a book store or buy one on eBay for about 5 dollars. This is an involved process and you will need tools and a lift or a good set of jack stands.
Before you plunk down a few hundred on the cables, pull out the console and take a close look at the bushings which connect the shifter to the cable ends. There is a frequent problem with those bushings and a bushing repair kit can be had on eBay for less than 20 bucks. It just could be that a bushing repair could set you straight as opposed to the time and cost of a new set of cables.
Apr 19, 2011 | 1996 Saturn SL
I need the backtrack driver
Click HERE to see available drivers for Engenius Eub9603 ext 802.11n usb adapter.
Dec 31, 2010 | EnGenius EUB9603 EXT 80211n USB Adapter...
How do i get files off of my Maxtor Portable USB-Powered Hard Drive?
I hope you gave enough explanation
but I can help
1. Use another computer
2. Use a bootable CD / DVD preferebly LINUX such as SUSE, FEDORA, UBUNTU or even BACKTRACK and get all your stuff out of your Maxtor.
3. Insert another hard drive and install OS on it then connect your Maxtor and get your stuff out of it
Dec 28, 2010 | Computers & Internet
The sound isnt being played through my bush cht2dvd home theatre kit when im watching tv only when im watching a dvd its connected to my tv with a scart cable, Help please.
Hi Hoggy - do you still have the problem?
One way I found to solve the problem - if you have a Sky box (I actually have Sky+), connect the AV cable between the back of the Sky box and the Bush system. Then using the 'source' button on the front of the Bush - select AV1 (or AV2 depending on which AV sockets you plugged in to).
(Of course - will only work when watching a channel on the Sky box)
Steve (stevemweiner'at'gmail'dot'com)
Dec 25, 2009 | Audio Players & Recorders
Linux does not recognize my wireless card
you have to installed the linux support driver of your usb adapter
Mar 12, 2009 | Computers & Internet
Bushnell BackTrack Handheld GPS Receiver Logo
24 people viewed this question
Top Bushnell GPS Experts
Martin Murray
Are you a Bushnell GPS Expert? Answer questions, earn points and help others
