Question about Ovens
How do I clean beko oven door inside panel?
There are stains on the glass inside my Beko oven door cavity which I can't get at, so even though the oven is clean the stains/marks are still visible. Can the inside glass be taken off to allow access to the stained glass?
    Top Expert:
  • Ovens Master
  • 34,789 Answers
Oven door glass is a "sealed" unit that accumulates stains over a period of use. It is not intended to be removed, unsealed, cleaned, resealed, and reinstalled.
Posted on Dec 28, 2013
2 Suggested Answers
mrmx2333
  • 56 Answers
SOURCE: See through oven glass window stained
this is common its called vapor lock look for screws holding in the glass if none are found there is a rope looking seal around it take a hook or pliers and remove it the glass will come out you can clean in between it and put it back fairly easily.
Posted on Dec 30, 2008
How to clean inside glass oven door
Taking the door off the oven and lay door on a soft surface so as to prevent scratching ,taking the door apart ( Carefully ), allow for a large work space, lay out your screws, the glass you are trying to reach is an inner glass, so obviously self clean is not going to help. Good luck!
Oct 02, 2014 | GE Profile JTP56 Electric Double Oven
Instructions for beko self clean oven
the self cleaning ability of self cleaning ovens is to do with the linings. If yours are getting stained, try putting an oven proof bowl with water in it whilst in use. That should help.
Aug 03, 2014 | Ovens
I have a Beko Electric Cooker, The oven is making intermittent rattling noises, which i think is the fan? How easy is it solve.
some models are acsessed inside the oven if you open the door and can see screws at the rear of the oven youre in luck otherwise it remove the rear cover of the oven and do it from there
Nov 13, 2013 | Ovens
Loose beko oven door ??
CHECK FOR A SLOT WHERE THE HINGE GOES INTO IT MABE YOU CANT SEE IT BECAUSE IT MIGHT BE CLOGED WITH FAT CLEAN WITH SOAPY WATER AND FIT THE PIN INTO THE SLOT AND IT SHOULD BE FIXED,
Nov 29, 2009 | Ovens
I have a whirlpool gbs307 oven and after completing a self-clean cycle and wiping it clean after it cooled, it won't heat at all. Any ideas?
HI,
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
thank you,
vijay
Sep 29, 2009 | Whirlpool GBS307PR Electric Single Oven
Beko oven door - permanently detached?!
Hi - in the end I found the cheapest local oven repairers and they ended up having to do a bodge job ... they admitted that Beko was a bad brand with lots of design problems, this being just one of them. By disconnecting and opening up the back he managed to get one of the hinges back on (with my help!), but for the other he had to resort to using bigger screws coming in from the front. Recently, after less than 18 months of use, the oven and one of the hotplates stopped working on the same night. I gave the whole thing up as a bad bet and ordered a more expensive Indesit I'm now completely happy with. I think with ovens you get what you pay for. I would never touch another Beko ANYTHING with a barge pole!
Jul 28, 2009 | Ovens
The inside glass needs cleaning on siemens
look for screws around the door, usally phillips, remove them then gently pry the door apart. popping the door off will make work easier.
Jun 27, 2009 | Ovens
Beko DCC4521w cooker grill element
it is done from the rear and inside cavity.Can be supplied approx £24.00+p&p,Check old element for continuity.
Sep 14, 2008 | Ovens
Stain inside double glass microwave door
most microwaves have screws on the top and bottom outer lip edges. or under the rubber grommet if it has this .
but this unit should have a 10 year warranty and they may cover this issue call them
http://products.construction.com/portal/server.pt/gateway/PTARGS_0_2_493_204_249_43/http%3B/205.142.52.224/swts_content_files/15315/211253.pdf
Feb 29, 2008 | KitchenAid KEHC379 Electric Double Oven
Ovens Logo
252 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
