Question about Sharp LD-26SH3U 26 in. LCD Television
Sharp LD-26Sh3U menu locked
Every time i press menu, adjustment locked is displayed and won't let me do anything. How do i unlock it?
  • 110 Answers
RELEASING THE ADJUSTMENT LOCK
Perform this procedure using the buttons on the TV.
1: Turn off TV
2: While pressing the "MENU" button press the "POWER" button continue to press the buttons until "UNLOCK ADJUSTMENT" appears on the screen.
3: Press the "VOL >" button.
That's it you may have to turn the unit off then back on at the end of step #3.
Posted on May 18, 2009
I have locked my tv now power will not come on...mitsubishi vs60609
1. Select the "MENU" display by pressing the "MENU" button once.
2. Press the number buttons "0", "1", "7", "0" in sequence to select the "OPTION MENU" display.
3. Press the "ADJUST" button to select "INITIAL."
4. Press "ENTER."
NOTE: At this time channel 3 is automatically selected.
Select initial settings. Come to V-Chip lock option [6]. Here you can unlock the V-chip.
Oct 26, 2012 | Televison & Video
I have a Sharp LD-26SH3U 26. I have picture but no sound. I turned it off to go to work & when i came home it took awhile to even get picture, then the picture came on, but no sound.
A couple of thoughts here--you may have suffered a power loss while away--unplug set for a while and then power back to see if it helps.
As far as the sound it is unlikely but possible the speakers may have got switched off somehow--check in audio or setup menu to see if this is the case.
Apr 17, 2012 | Sharp LD-26SH3U 26 in. LCD Television
Sharp Aquos RC Control Lock and Operation Lock Out
When all else fails read the owners manual page 35:
"• To unlock the buttons on the remote control by using the
touch sensor panel of the main unit (see page 25):
1 Press MENU to display the MENU screen, and then
press VOLl/k to select "System Options".
2 Press CHs/r to select "Operation Lock Out", and
then press INPUT.
3 Press CHs/r to select "Off", and then press INPUT.
4 Press MENU to exit.
• To unlock the buttons on the TV, press MENU on the
remote control, and then select "Off" in "Operation Lock
Out".
Apr 05, 2012 | Televison & Video
Unlocking the remote and panel for Sharp Aquos LC-46LE832U 46 in. HDTV LCD TELEVISION
When all else fails read the owner manual page 35:
then press INPUT.
Out".
Took 5 minutes to find the manual for this unit. GOOGLE
Apr 05, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
The remote and control panel are locked on my 52" LED LCD tv.
Hello
To unlock the remote control function do the following.
On the front pane touch control pad
press VOL[--/+] to select "System Options".
2 Press CH [UP/DOWN] to select "Operation Lock Out", and
then press INPUT.
3 Press CH UP/DOWN] to select "Off", and then press INPUT
Out".
OK.
Feb 16, 2011 | Sharp LC52LE810UN 52 in LCD TV
"OSD LOCKED" box on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
Dec 07, 2010 | Dell Computers & Internet
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
Lock appear on Tv. Screen Blue. Sound audible
You Probably Need To Go Into Parental Controls And Change The Settings If You Forgot Your Code Go To Your Brand Name's Site And Find Your Tv User Manuel And Go Under Parental Controls
Hope This Helps = ) Tophee
Jul 16, 2009 | Sharp LD-26SH3U 26 in. LCD Television
Philips 109s20 crt monitor
Here's the link for the product support page; http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=109S20&scy=us&slg=AEN&grp=PC_PRODUCTS_GR&cat=CRT_MONITORS_CA&sct=CRT_MONITORS_GT19_SU Click "User Manuals" on the left. or here is a direct link; http://www.p4c.philips.com/files/1/109s20/109s20_dfu_eng.pdf Check page 28: "The Main Menu displays OSD MAIN MENU LOCKED . Pressing the front control panels hasno effect. How can I unlock this function? Press and hold the OSD menu key for about 10 seconds until picture displays "OSD MAIN MENU UNLOCKED"" Hope this helps :)
Sep 03, 2007 | Philips Brilliance 109S Monitor
Sharp LD-26SH3U 26 in. LCD Television Logo
386 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
