Question about KDS K717s 17" LCD Monitor
KDS K717s LCD screen goes white
I'm not sure why but when the monitor is turned on, every pixel goes right to white.  I figure it's probably a short in a transistor, but i'm not sure which one it could be.  Any info would be greatly apreciated, and thank you ahead of time  :)
  • 3 more comments
  • Anonymous Nov 12, 2007
    Screen is completely white
  • jbhigh Dec 08, 2007
    same problem.
  • jwiz Feb 17, 2008
    Screen goes white on start up. After using switch many times it will come on normally. Any ideas?
  • Anonymous Jun 30, 2008
    goes white
  • Anonymous Sep 13, 2008
    My monitor worked fine for 3 years, then tonight it went all white. Doesn't matter what I do. I tried it on a different PC and got the same result (wasn't sure if it was the monitor at first). It alternates between off and all white during the boot, then settles on all white.
Most repair shops would start with replacing the controller board.
Posted on Jun 18, 2009
Um which logic board be that then? inverter, lcd, gfx or mobo???
Posted on Jul 12, 2008
  • 180 Answers
Trouble at the logic board.
Posted on Apr 24, 2008
SOURCE:
Kds K-92bw After about 5 min the screen goes blank..turning the unit off than back on the screen looks great for a while about 3 min than goes black..seems to be a caused by heat
This issue is most likely caused by a capasitor doing bad. There is no easy fix. It must be disembled and the power supply repaired. If done properly, it should cost somewhere between $ 50 to $125. But it may do it again as the Pwoer supply is a known issue for this monitor. Sorry.
Sep 21, 2011 | KDS K717s 17" LCD Monitor
Kds 700p monitor
Power supply filter caps will be he first thing to check, look for leaking/bulging tops.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
May 11, 2010 | KDS K717s 17" LCD Monitor
After 15min the monitor cuts off. KDS k717. Iturn it off for a few min and turn it back on and it does it again
power converter/supply bad defect contact manufactuer and ask for warrenty replacement
Mar 13, 2009 | KDS K717s 17" LCD Monitor
When i turn on the monitor the screen goes all white
This is usually either a problem with the controller board or the actual LCD inside the display.
You should be able to find one of these monitors with a bad power board on eBay for cheap and just replace the guts of yours with the parts (minus the power board) from the 'new' one.
It would likely be better to just buy a new one if you are out of warranty.
Sorry about that.
Jan 01, 2009 | KDS K717s 17" LCD Monitor
Crazy buzzing
most probably you have bad capacitors in the powersupply of the invertor board, check for bulged tops of the capacitors and replace them
Jul 09, 2008 | KDS K717s 17" LCD Monitor
The white screen tells me that the display cable (inside your monitor) may be unattached or broken.
The color bands if they are vertical or horizontal lines tell me that your display cable needs to be replaced.
So overall replace your display cable. If this doesn't entirely fix the problem your logic board (inside the monitor) needs to be replaced.
Feb 21, 2008 | KDS K717s 17" LCD Monitor
Kds k717s lcd monitor
That have to do some servicing in the power section at the main board.
Feb 28, 2007 | KDS K717s 17" LCD Monitor
KDS K717s 17" LCD Monitor Logo
325 people viewed this question
Top KDS Computers & Internet Experts
Thomas F. Schneider
Siul Oyaratgam
Steve Allison
Steve Allison
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
