Question about Car Audio & Video
Does anyone own a Sundown SAZ-3000D What is the RMS at one ohm maxx at one ohm? and this is all at 12v
  • Perry Babin May 11, 2010
    Try posting this question on the db-r dot com forum. They specialize in Sundown amps.
  • Muhammad
    Muhammad Jun 10, 2017
    oh no but i have seen the sundown sa v8 in this review and man it is amazinghttp://loudnoisycar.com/sundown-sa-8-v3-...
    Novelist:
  • 149 Answers
Google sundown saz-3000d it will take u to the website-specs are listed there
Posted on May 20, 2009
I need 4 ohm speakers for my Warrior IS600 Amplifier
It is rated as a dual 300 watt amplifier, shich strongly suggests a Class D peak value for each amplifier.
In theory- 100 watt RMS 4 ohm speakers should be adequate.
Sep 20, 2012 | Audio Players & Recorders
How many watts is my jl audio 2150 amplifier
It depends on whether you have the M2150, A2150, or E2150.
M2150 Class A/B Two-Channel Full-Range Amplifier Specifications:
Rated Power 14.4 V Stereo: 70 W RMS x 2 @ 4 ohm, 110 W RMS x 2 @ 2 ohm
Rated Power 14.4 V Bridged: 140 W RMS x 1 @ 8 ohm, 220 W RMS x 1 @ 4 ohm
Rated Power 12.5 V Stereo: 45W RMS x 2 @ 4 ohm, 75W RMS x 2 @ 2 ohm
Rated Power 12.5 V Bridged: 90W RMS x 1 @ 8 ohm, 150W RMS x 1 @ 4 ohm
THD at Rated Power: 12.5V: <0.08% THD, 20Hz-20kHz, 14.4V: <1% THD, 20Hz-20kHz
S/N Ratio: >104 dB referred to rated power (A-weighted, 20Hz-20kHz noise bandwidth)
Frequency Response: 10 Hz-25 kHz (+0, -1dB)
Damping Factor: >200 @ 4 ohm per ch. / 50 Hz, >100 @ 2 ohm per ch. / 50 Hz
Input Range: 200mV, 8V RMS
E2150 Class A/B Two-Channel Full-Range Amplifier Specifications:
THD at Rated Power: <0.08% @ 4 ohm 20Hz-20kHz
Frequency Response: 10Hz-25kHz (+0, -1dB)
A2150 Class A/B Two-Channel Amplifier Specifications:
Rated Power 12.5 V Bridged: 150W RMS x 1 @ 4 ohm
THD at Rated Power: <1% @ 4 ohm 20Hz-20kHz
Mar 23, 2011 | Car Audio & Video
I want to know if the f 15d is strappable?
From what I understand, the F15d is the same inside as the Sundown SAZ-1500d which is strappable (daisy-chain) via RCA's. So, I would venture a guess that it is in fact strappable.
Jan 11, 2011 | Solid Audio Car Audio & Video
Can i hook this amp to a 2 channle out put stereo?
Sure. Specs are listed below. I think it's designed for regular 2-channel input, isn't it?
Front Channels: 100 W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
  • Rear Channels: 25 W RMS x 2 @ 1.5 ohm-4 ohm(11V-14.5V)
  • Subwoofer Channel: 250 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
  • THD at Rated Power: <0.03% @ 4 ohm (F&R), <0.05% @ 4 ohm (Sub)
  • S/N Ratio (F&R): >108.5 dB below rated power S/N Ratio (Sub): >95 dB below rated power
  • Frequency Response (front and rear): 5 Hz-30 KHz (+0, -1dB)
  • Frequency Response (sub channel): 5 Hz-500 Hz (+0, -1dB)
  • Damping Factor (front and rear): >200 @ 4 ohm/50 Hz
  • Damping Factor (sub channel): >500 @ 4 ohm/50 Hz
  • Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
  • Differential-Balanced Input Topology: (3 pairs of inputs)
  • Front Crossover: fully-variable (50 Hz-5 KHz), selectable- slope BP or HP (12 or 24 dB per octave)
  • Rear Crossover: fully-variable (50 Hz-5 KHz), selectable- slope HP (12 or 24 dB per octave)
  • Sub Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
  • Preamp Output: 2-channel (full-range or LP)
  • Bass EQ: Variable boost up to 15db
  • Infrasonic Filter: defeatable 24dB/octave at 30 Hz
  • Left minus Right Ambience Circuit: ambient effect for rear channels
  • Front and rear speaker output connections: accept up to 8ga. wire
  • Dual mono subwoofer output connections: accept up to 8ga. wire
  • +12V and Ground connections: accept up to 4ga. Wire
  • Dimensions: 19.7"L x 9.25"W x 2.36"H
  • Dec 02, 2010 | Jl Audio 500/5 Car Audio Amplifier
    Will this amp power two 12" subs?
    Yes. The Kicker xs50 competition amp will l ! Pushs my old school autobahn aw1206t's very nicely and beats my 2 sundown sa15's senseless. Wire down to 1 ohm and bridge. People may say yeah rite. Ok. Thats ok.
    Dec 07, 2009 | Kicker XS50 Car Audio Amplifier
    Sound storm ssl- cr4000.1 and 5000.1 any good
    Never owned one but i just scoped out a 5000.1 a pair of them on u-tube running them on 8 lanzar 15's and ewwwww dogggyy!!!! they sho nuff moving some air-ya might want to go to "amp guts" too and check out what its made of- a lot of amps are the same chipboards just different covers on the outside-its crazy.
    May 14, 2009 | Soundstorm CR5000.1 Car Amp
    Powers up and shapes the sound but no boost?
    the power source you are using is too low you need power source that has a 20-25 amp out put dc find a bigger power source and not the ampriage
    Mar 27, 2009 | Pyramid 903G 10-Band Car Equalizer
    Sub woofer wiring
    If you have a 500a2 and two 4 ohm single voice coil speakers, you have only one option. Connect one speaker to each channel.
    Dec 30, 2007 | Rockford Fosgate Punch 500a2 Car Audio...
    Kole Q1-3000D Power Supply caps Keep blowin
    you need a fuse of 300amps or higher with 1/2aut cable power supply connected to an after market altenator. also make sure the subs are wired properly.
    Nov 12, 2007 | Kole audio Q1-3000D Car Audio Amplifier
    Amp Will Not Stop Overheating
    You say you have 2 p312d2 subs. Ok so the d2 stands for dual 2homs (2 X 2homs voice coils per sub) , conecting in parallel the 2 voice coils of only one sub will create 1hom load to the amp, and if your amp is 2homs stable per chanel that means you are lowering too much your homs causing the overhwating to it.
    Sep 25, 2006 | Ultra Linear UL-2200D Car Audio Amplifier
    Car Audio & Video Logo
    130 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
