Question about RCA L32WD26D HDTV/DVD Combo
How do i diagnose a faulty capacitor in a RCA HDTV?
    New Friend:
  • 3 Answers
How do i take off a faulty capacitor
Posted on May 14, 2016
  • RCA Master
  • 10,291 Answers
If it is an electrolytic capacitor look at the top of the capacitor. It should be flat. If it is bulging up replace it. some will change the color of the plastic wrapper too. Other styles of capacitors need special test equipment like an ESR meter to locate a failure.
Posted on Jan 06, 2014
How would i diagnose a faulty capacitor on a RCA HDTV model L32WD26D?
Most of the time you can see that the capacitor has a domed top or the sides are bulged out. Fluid might also be leaking out.
Dec 28, 2013 | Refrigerators
We have 52
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 05, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a RCA 32" Flat Screen TV that shut off and
The sound was came from the clicking of the relay. This kind of symptoms is an indication of out-of-regulation condition on the power supply section. This is caused by faulty electrolytic capacitor. It will dropped the supply voltage and will trigger that kind of symptoms.
Faulty electrolytic capacitor mostly has a physical indication of fault like bulged/dome at the top and can be easily identified. See sample picture of faulty electrolytic capacitor below.
capacitor with bulged/dome at the top.
Check these parts on the power supply section. Once found, replaced it with same capacitance and working voltage which is printed on its body itself. Click this LINK for more info regarding electrolytic capacitor.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qualified TV Technician to isolate the faulty parts.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 05, 2011 | RCA L32HD31 32 in. LCD HDTV
Well i have a new fluid lcd tv it turns on but it's a black screen but their is sound (music, t.v. shows, ect.) what do yuu think the problem is??
Hi ,
Power on the unit in the dark room then shine with the flashlight directly in the screen, you will barely see the images. This is because your backlight is not functioning. The following reason is the caused.
1. Power supply - missing B+(supply voltage) coming from this board feeding the inverter board. This is caused by faulty transistor, dried/leaky electrolytic capacitor, open fusible resistor.
2. Inverter board - even the B+ is good from the power supply, if the fuse, driver transistor, driver transformer is faulty no output to the backlight resulting to black picture.
3. Busted backlight - even inverter board is good but if this is busted resulting to black picture also.
Diagnosing the fault is technical and if you don't have necessary tools and test instrument and can't fix it yourself, I would advice you to look for an experienced technician to isolate the problem.
Hope I helped you.
Have a nice day!
Mar 11, 2011 | RCA L32WD12 32 in. LCD HDTV
Hello i have a rca hd52w59 and i unplugged it for about a week now i cant get it to come on. i hear it come on but it shuts itsself off
You are not the only one I can tell you that. I had the same problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Dec 09, 2010 | RCA HD52W59 HDTV Projection Television
Tv turned off by itself now TV button goes on but immediately turns off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Solutions?
Hope this helps
Aug 24, 2010 | RCA HD52W59 HDTV Projection Television
My rca 52" rear projection HDtv continues to need autoconvergence
The convergance board or faulty capacitor will have to be replaced.
Jul 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hi my tv doesn't come on either i've actually had this problem back in 2006 problem was diagnosed as a lost of power supply tv power light blinks thre times but never shows anything on the screen. was sent...
Most likely its the CP150, CP120 and CP114 capacitors. You can get the replacement capacitors plus instructions at the following link under RCA parts and it cost about 10.00 shipping included
http://servicemanuals.vstore.ca/
Jul 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hd dlp rca scenuim
the 5 blink error is caused by faulty capacitors on the power board. There is a kit called the ATC336 power supply repair kit which contains the replacement capacitors and instructions that will usually repair that. You can get the repair kit at the following link.
Sep 27, 2008 | RCA HD50LPW175 50" HDTV
RCA D52W20 52 in. Rear projection hdtv problems
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
Jun 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA L32WD26D HDTV/DVD Combo Logo
78 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
