Question about Sony FD Trinitron WEGA KV-32HS420 32" TV
Sony kv-32hs420 screen mode doesnt work
Current screen display chops off sides of content. When I try to change the display to 16:9 (or other), the selections under the setup screen are grayed out and I cannot select them (nor will my remote adjust the screen size).
    Top Expert:
  • Sony Master
  • 41,875 Answers
Display ratio usually is a setup choice but bear in mind that old movies and old TV programs will display in 4:3 ratio. Remotes usually have no control over screen size.
Posted on Dec 28, 2013
SOURCE: setup codes for a sony kv-20fs12
i have sony kv 14 gmr1mk r2ks always shorted and the other 1 appear like a lightning in midle of screen.. kv 21gmr1mk when adjust the brigth and contras it shut down the picture and blinking..can u help me how to troubleshoot this problem? what remedy you sudgest..thank you...
Posted on Jan 25, 2008
jerryg50
  • 1689 Answers
SOURCE: Video input permanently displayed
If there is no "input video" button on the control panel of this series of set, as like the older Sony sets had, you need to order the original remote from the Sony service center, or Sony parts directly. Universal remotes (any that I know of) will not access this menu in your Sony set.
Jerry G.
Posted on Jul 12, 2008
  • 6 Answers
SOURCE: Sony KV-32HS420 will not come on has blinking standby light
Get out your original remote and hold the "Setup" button at the same time as holding the On/Off button on the TV set. It just worked for me!! Thank goodness. I was just about to bring it for repair but there's a snowstorm. Here's the link I got this from: http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=http--esupportsonycom-perl-tutorial-displaypltutid297templateid1regionid1KSMFlag7370&sliceId=&docTypeID=DT_TUTORIALS_1_1&dialogID=53101564&stateId=0%200%2053105132
Posted on Dec 31, 2008
SOURCE: my television screen size keeps changing when on
rolled it off a cliff.
Posted on May 29, 2009
  • 668 Answers
SOURCE: 6 horizontal lines
I would look for a Vertical circuit failure. Most likely is the vertical output IC and or open resistor off the hv transformer. Definitely look for any loose solder connections around the Vertical output IC.
Hope this helps,
Skyassoc
Posted on Jun 17, 2009
Stand by timer sony triniton color tv Model kv-32hs420
How many times the standby button blinks before going OFF at one time switch ON?
Apr 17, 2012 | Sony FD Trinitron WEGA KV-32HS420 32" TV
My tv doesnt get any stations already scaned it its dtv ready it is a sony
Check the tuner. Check all supply voltages to it. It is a skilled job. If all voltages are OK, replace the tuner.
Sony FD Trinitron WEGA KV-32HS420 32" TV.....Turns
Sounds like a diode may have burnt up or if your really lucky it might just be the fuse.!!! You might want to get a secound opinion .But if you know what to look for , which is any component on the motherboard that appears as if had caught fire sader it out amd replace with exact same component which can be ubtained at radio shack.GOOD LUCK TOO YOU!!!!!!!!!
Dec 23, 2010 | Sony FD Trinitron WEGA KV-32HS420 32" TV
My Sony kv-32hs240 turns on and after one hour
Sounds like you've got a short in your house electrical lines. Try using a surge protector (AKA power strip) between the power cord and wall outlet. If you've already got a surge protector, try replacing it.
Oct 29, 2009 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Hi, my name is Nicole. My KV-36HS510 Sony TV is being broadcast with the picture size reduced quite a bit. Playing DVD's is fine, the pic fills the whole 36". However on cable TV it is chopped on the...
press "menu"
the setup screen should open
scroll through the options to "16:9 enhanced"
you should find 2 options ("on" and "auto")
choose "auto"
that should do it
enjoy.....
Sep 12, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony KV-36XBR800 Video mode stays on screen all the time
Very easy fix.....just press the "display" button on the remote control so that the on screen display is turned off when you are watching TV.
Jan 29, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony triniton tv widescreen
It's called the aspect ratio - and on the WEGA design I think you've got a button on the remote labled picture mode.. If not or that doesn't work go into the menu and look for aspect or aspect ratio and rest that to 16:9...
Bill
Dec 29, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Standby mode
hi there, try to check first the power supply section. test some parts. ty
Dec 29, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony FD Trinitron WEGA KV-32HS420 32" TV Logo
80 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
