Question about Scotsman Refrigerators
Scottsman cu2026ma slow to make ice
    Novelist:
    Champion:
  • Scotsman Expert
  • 373 Answers
Check the condenser coil to make sure it is clean. machine needs to be in a cool spot the warmer the entering air the slower it will make ice. also check the hot gas valve make sure its not letting hot gas to pas through to do this check the temperature of the copper line going to the valve at the valve and then check the temperature of the copper on the other side of the valve should be a little cooler.
Posted on Sep 26, 2014
I'm trying to get my ice maker to produce ice. Power comes on, condenser coil is clean, fan is moving air. Green light on the control panel, and water is running. But after running a few minutes, t
Scottsman Ice machine? I just learned this trick. You need CLR or something like that to remove hard water deposites. open the front then top and the right side. on the bottom in the back on the right side there is a wire going into what looks like a rubber boot. Gently tug on that plug and you will pull out the electric eye sensor. Clean that with CLR, then gently wash and reinstall. The emitter is located where the control panel is in the back on the bottom. You can't see this very well but you can feel it. Same thing gently tug on the wire and the boot pulls out. Then Clean with CLR and wash off with clean water and reinstall. What is happening is this the light or sensor is dirty so it thinks it's already full of ice.
Jan 12, 2015 | Refrigerators
Scottsman SCE170A-1B how can i have to make ice faster
The only way to make ice faster for this machine is done with cooler ambient room temperature and colder water temperature from supply water before it reaches water sump tray.
Jun 06, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
How things work
i think this is a scottsman commercial ice mach.
it works by the control board and the little timer motor loacted on the circuit board. at the end of the freeze cycle the timer activates the fill valve to let fresh water in for the next cycle. it stops when the cam on the motor lifts against the micro sw located on the timer motor.
May 27, 2014 | Kenmore Refrigerators
Scottsman cu2026
does the water overflow?,, if its not pumping, its not being told to pump by level indicator or the pump is bad(common issue)
Apr 07, 2014 | Scotsman Ice Machine - 290lb...
Scottsman ice maker putting black oily substance in the ice. What needs to be checked??
you need to call a refrigeration mechanic because the worm gear seals and transmission needs to be reseald.
Jan 24, 2014 | Scotsman Modular Flaker Ice Machine Water...
Scottsman prodigy icemaker max harvest time codes-common causes.
my prodigy periodically flashes 2 which indicates slow harvest what does this mean?, is it common for time to time to flash 2, how do I correct it
Mar 14, 2012 | Scotsman Prodigy Air Cooled Cuber C0330SA...
Problem with Scottsman Ice machine. Not sure of model, but about a 600lb. Refrigeration light is on (steady glow, not flashing), not making ice. Air filters on either side have been replaced with new...
wave your hand infront of bin eyes if the bin full light doesnt blink the machine is not reading the ice fall during harvest and will cause it to kick out. basically it thinks its not making ice.
Sep 18, 2011 | Scotsman Ice Maker 600LB CM3 30inW...
Ice machines compressor runs extremely hot.
This looks to be a Scottsman Ice machine so could be that your condenser fan motor isn't running or you need to clean the condenser which either of these could cause the compressor to be extremely hot. If it is over producing ice then you could try to turn down the bin level. If this doesn't fix your problem with over production then you may need to replace the bin level thermostat which can be located at the bottom of the machine. It is the one that has the knob on it. The other thermostat behind the control cover is the cube size control which routes to the back, top of the machine. The bin level control routes around under the bottom between the compressor and the case, then up and into the back of the cabinet. The silver colored scoop holder inside the machine to the right is where the bin level thermostat registers it's temperatures. It's not just a scoop holder. Let me know if you need more help. Thanks.
Jan 15, 2009 | U-Line Icemaker
MV450 SCOTTSMAN ICE MACHINE
Personally I think the prices that you paid for the new TXV and dryer are VERY far out of line.Get what information you can off of the TXV power assembly and valve body along with the manufacturer of the valve and I will see what I can find out for you. If it is the power assembly that is rusted out and leaking there are kits for replacement parts on most valves.
Oct 23, 2008 | Scotsman Cooled Modular Contour Cuber Air...
Refrigerators Logo
35 people viewed this question
Top Scotsman Refrigerators Experts
t-stat
Level 1 Expert
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Scotsman Refrigerator Expert? Answer questions, earn points and help others
