Question about Averatec 6110EH1 (AV6110EH1) PC Notebook
When I push the power button, the lights flash and the fan starts but nothing else happens. I tried to put in a bootable CD...nothing. It seems like it don't even get to the bios.
  • 2 more comments
  • hardan May 18, 2009
    I have another screen plugged in and have nothing.
    I pulled the hard drive and installed it in a thinkpad and I got a disk read error, ran a hard drive test and it says the hard drive is fine. The last time it did turn on it asked if I wanted to use safe mode or the last known good config. I used the last known. I will pull the ram and try that. I tried putting in a bootable cd. the cd light blinks but the cd will not run.
    Cleaned rams and re-installed. Same thing.
  • hardan May 21, 2009
    It is like nothing on the computer gets power except the fan and lights. IS there a fuse somewhere?
  • hardan May 22, 2009
    No beeps.......the three lights at the top flash and then the fans starts. Nothing else. Just has the one fan. It is an Averatec 6100A series, AV6110-EH1.
Try connecting the 15pin dsub to a monitor. You will be able to tell if it is a screen problem if you get video on the monitor
Posted on May 18, 2009
  • Bill Brady May 21, 2009
    Do you get a series of beeps when you try to start up? The beep codes will let you know what has malfunctioned in some cases. Other than that it seems to be a motherboard / RAM / CPU issue. Do you know if any of the fans have failed? Unfortunately it may be too late. What motherboard / cpu /ram do you have? Or make and model number if it was an off the shelf unit.
  • 4 Answers
Please check your RAM first. Clean your RAMs and try booting again. Still if you are facing the problem then it would b the hard drive issue.
  • eju143eju May 18, 2009
Toshiba satellite 1005 s157 laptop powers on and then turns off
it could be your ac converter in your laptop.. best bet would be to check the memory, take both the batteries out and try restart it without batteries.. if non of this works i believe it might be your ac con...
success
Jun 18, 2012 | Toshiba Satellite Computers & Internet
How do I know if the power supply is bad on gateway gt5676 computer? I push power button and nothing happens. I unplug it and the green light flashes on the power supply( Bestec ATX 300 12 EB3). Plug it...
u can buy power supply testers, just a device you plug the power supply into, or try a new power supply. but if nothing is happening no fans etc theres a good chance its just the power supply.
Jun 17, 2012 | Computers & Internet
I have a fujitsu e8410 which will not start up properly, when i push the start button it shows power but then the fan comes on and the cap num and shift lock leds flash and nothing else. can you help?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 31, 2012 | Computers & Internet
My computer won't start. Power supply (ttgi 450ss) has a blinking green light and the power supply fan starts when plugged in. Motherboard (asus m2npv-vm) has a green light illuminated between the pci...
See if you plugged in the 4 pin power connector on the motherboard besides the main power connection on the power supply (usually black colored and its a plastic 4 pin connector)
Try another power supply if all else fails. If new power supply does not work with this unit then its a motherboard which is blown and motherboard needs replacing.
Hope this helps
Mar 16, 2010 | TTGI SUPER FLOWER 450W quad fan switching...
Tower turns on fan runs lights on BUT NOTHING >>>>>>>
If the CD drive door won't open, odds are that at least you know the drive is without power. Have you had the case opened up at all? With what you've described here your computer needs the tender, loving care of a technician.
Sep 20, 2009 | 3G Technology GM-171B 17" Flat Panel LCD...
My laptop (Compaq Presario v2000) won't seem to boot up
Remove the battery. Plug power cord in. Turn on machine. Does it boot? Replace battery.
gurutim
Mar 17, 2009 | HP Compaq Presario V2000 Notebook
Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Dec 23, 2008 | Maytag MDB7100AWB Dishwasher
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
Turns on, yet not on?
Have you read the manual ?
Aug 15, 2017 | RCA CDS4100 Digital Camera
Averatec 6110EH1 (AV6110EH1) PC Notebook Logo
110 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
