Question about Vehicle Parts & Accessories
Vibration at low speed in fourth gear - Vehicle Parts & Accessories
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Going to slow... shift up
Posted on Dec 28, 2013
2002 pontiac grand am had 1st and 2cnd gear slippage.i replaced the filter and fluid but now i do not have 3rd and fourth gear it will just not change to the gear
Perform ODBII scan. Look for speed sensor fault. Trans has to read speed to know what gear to engage. Could also be a governor problem. Try shifting from low to high gear manually
May 20, 2017 | Pontiac Cars & Trucks
My 2005 Pontiac Bonneville GXP will not shift into 4th gear I was to it was a fourth gear band but is that the only problem that will cause itI'notto shift into 4th gear
Which transmission does yours have 4T65-E or 4T80-E ?
4T80-E
No Fourth Gear
Checks
Causes
1-2 Shift Solenoid Valve
Inoperative
Debris
Pinched wires
3-4 Shift Valve Bore Plug
Misassembled
4th Band
Burned, slipping, missing
4th Servo Cover
Cracked
4th Servo Pin
Broken, seized
4th Servo Piston
Damaged
4th Servo Seals
Rolled, cut or damaged
4T65-E
Slipping or No Fourth Gear
Slipping or No Fourth Gear Checks
Cause
DEFINITION: A large engine RPM increase is noted in fourth gear, Drive range, with little or no vehicle forward speed increase. First, second, and third gear operation are normal. Shifts into fourth gear are soft or do not occur. Fourth gear ratio is 0.705:1.
Automatic Transmission Fluid Level
Low fluid level
Transmission Main Line Pressure
Low transmission main line pressure
Oil Filter Assembly
• The oil filter assembly (100) is missing, plugged, or damaged.
• The oil filter seal assembly (101) is missing or is damaged.
Control Valve Body Assembly
• The 3-4 shift valve (362) or the 4-3 manual downshift valve (360) is stuck or binding.
• Debris is found in the passages of the control valve body (301) or of the control valve body spacer plate and gasket assembly (396)
Case Cover Assembly
Distortion or damage occurs at the manual valve (404) or at the case cover (401), causing PRN oil leak.
Driven Sprocket Support Assembly
A plugged third clutch oil passage in the driven sprocket support assembly (609)
Fourth Clutch Assembly
• The clutch plates (500-502) are worn, damaged, or misassembled.
• A missing or not seated fourth clutch spring retaining ring (601)
• A damaged spring assembly (602) or piston (603)
• Worn or damaged fourth clutch piston seals (604, 605)
Third Clutch Sprag Assembly
• The sprag (720) was misassembled or backwards on the inner race (661).
• A damaged third clutch sprag assembly (653, 661, 719-721)
Dec 06, 2015 | Pontiac Cars & Trucks
No power when I shift into fourth gear and a bad vibration
What gear are you in. Usually in 4th gear you should be at least going 60 mph. If not your lugging the motor. I would check the front motor mount for the vibration too.
Sep 05, 2013 | Harley Davidson Motorcycles
2006 Dodge 2500 Diesel. The RPM gauge will show 3000rpms at 30MPH, basically the gauge is reading erratically.
Are you sure you are not in too low of a gear? Please tell me this is not so. If you are in fourth or fifth gear at low cruising speeds and RPMs do not match the audible sound of your motor, then you could possibly have a bad engine speed/reference sender (Crank and/or Cam), or faulty instrument cluster or ECM/BCM.
Sep 08, 2011 | 2006 Dodge Ram
I am experiencing a vibration (at low speeds) thru
First of all you must check the gear box oil level,secondly see if the the gear box mountings if they are good,if the is cracking on it,it must be replace.
Feb 03, 2010 | 2007 Honda CR-V
The automatic gear have a delay in changing the speed number four in model 94 VR6
Maybe a stupid suggestion, but check the oil amount in the gearbox. It must be done with the motor running. I did´nt know that and checked it motor off when the level on the dipstick was fine. When I checked it motor running it was too low. I filled it up and the gearbox works fine...
Aug 30, 2008 | 1994 Volkswagen Corrado
Gear change vibration
These cars usually have a two piece drive shaft. There is a center bearing in the middle of the driveshaft for support and dampen vibration. It could also be the front rubber coupling where the transmission tailshaft and driveshaft meet. If both are fine try loosening the bolts on the rear transmission mount. Your mounts may be out of alignment allowing for unusual angles between the transmission and driveshaft. Good luck.
Aug 04, 2008 | 2003 Mercedes-Benz E-Class
Power Steering pump appears to be leaking but is full????
Just guessing. Could it be a warped brake disk? That would cause vibration. And vibration in steering might conceivably cause splashing out the power steering reservoir. You would know if the disk were warped by a shudder when you brake at hight speeds.
Jun 17, 2008 | 2000 Buick LeSabre
Vehicle Parts & Accessories Logo
15 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
