Question about Dei Directed Viper Python 514n Soft Chirp Siren
What do the 2 small black wires connect to on a DEI 514N
Wiring diagram for ce 0890 remote start
On some remote starters, there is print on the back of the remote starter itself. It is hard to see with it being black raised text on a black box. If not there, sorry DEI Viper is pretty protective on their installation manuals.
Nov 28, 2014 | Remote Start System
I changed the battery in my 1998 Mazda Protege and now my remote unlocker/starter doesn't work. The red light comes on when i push a button, but no response from the vehicle. How do I fix this?
1. Locate the valet switch for your system. It's a small black push button, connected to a pair of wires that are gray and black. There's no telling where the installer placed it, or if he even left it connected. But if it's there and you find it:
2. Put your key in the ignition and turn it to the "on" or "run" position (not to "start").
3. While the key is on, press the valet switch once and release it, then press it again and hold it.
4. Press the "lock" button on the key fob.
5. Release the valet switch and turn the key off.
6. Test the key fob to see if it worked.
Jul 07, 2011 | DEI Python 1400XP Remote Start/Keyless...
Replacing a pull chain 3-way ceiling fan light switch
OK .. the thick black and white are the power for the fan , are there also white wires on the lamp sockets ..??
The thick black wire should connect to the black wire on the switch.
The small black wires connect to the red and blue wire on the switch .. two small black wires each .. that should give you a position for 2 lights , and 4 lights, on the step switch .. but there should be white wires from the lamp sockets connected to the thick white from the fan .
please respond .
Please Vote !!
May 24, 2010 | Westinghouse Electric Westinghouse...
I just bought a two-way car alarm system but dont have the wiring manuel for it.ITS a Huatai model no:ht-800,FCC ID:st9ht-800 i wanted to know if you have the wiring manual for it or kno where could i get...
Most every aftermarket alarm is manufactured by DEI. If you go on the DEI website ( www.directed.com ) you should be able to find some wiring diagrams that will help you out.
May 17, 2010 | Honda Accord Cars & Trucks
I am having problems wireing the 556 VW bypass for a Honda. Any suggestions?
I think you mean the 556UW, there isnt really anythign special about it, you only need to use the red black and blue wire on teh 556UW. red for power,black for ground and the blue will go to the blue or blue/white status output from the remote starter.
Oct 19, 2009 | Directed Dei Valet 561r Remote...
I have a 471t model remote starter, it fires up
Could be one of a couple of things. Tach not programmed properly or wire not connected correctly. Or the immobilizer bypass is not programmed or working properly.
Oct 18, 2009 | DEI Valet Keyless Entry System
I want to have my valet model 561r removed it is malfunctioning my car is reviving up and dying on turns it also will no longer start the car
Not possible. The DEI's brand Valet has nothing at all, anywhere close to or connecting to the accelerator or acceleration of ANY VEH.
Oct 11, 2009 | Directed Dei Valet 561r Remote...
I have a DEI 471T remote start/lock. The parking
There is a white wire coming from the alarm, there should be a blue 15 amp fuse in that wire, close to the brain for the alarm. It sounds like you have blown that fuse.
Aug 10, 2009 | Directed Dei Valet 561r Remote...
What fuses does it take? Have it in my car but there are missing fuses also have other dei products in my car that are wired but missing fuses. Please help!
I'm still digging but I have some info for you. DEI- 530 is a Window automation system. DEi- 529 Is a window roll up module. DEi-520 is a battery back up.
May 04, 2009 | Honda Civic Cars & Trucks
Dei Directed Viper Python 514n Soft Chirp Siren Logo
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
