Question about Home Security
Sentry 1635 safe
I can't open my sentry safe 1635 after changing the battery. After entering the 5 digits code, an error sign appeared. What should I do?
  • 10 Answers
SOURCE: defalt code for sentry safe 5 digits
You'll need to go here:
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
There is no "default code", but they do keep the serial number and code on file, for just this purpose.
Posted on Feb 18, 2008
SOURCE: Sentry Model 1610 Won't Open
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
Posted on Aug 21, 2008
SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Posted on Mar 23, 2009
  • 736 Answers
SOURCE: sentry 1610 safe. cannot open
there are either 4 AA batteries or in some cases one 9 volt battery that has to be replaced .. in some models you slide off the area under the keypad to get at the battery .. .. as the battery ages it has enough current to operate the display but not enough to operate the unlocking mechinism .. once you have it open make sure the mechinism works freely .. if not it may need some non gumming lub .. dont use WD 40 for this ..
Posted on Sep 19, 2009
Testimonial: "I think this advice was directly helpful. However, I couldn't wait for the answer. Somehow, the same code worked if I tried one more time. "
  • 76 Answers
SOURCE: Need factory code for Sentry Safe Model 1610 -
If you need your lost combination, you must send a notarized letter stating you are the owner of the safe. The link below will tell you everything that you will need to get your combination back:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Posted on Jul 06, 2010
Can't open safe!
If it still doesn't open after you replace the batteries then it is probably do to it being Jamed. I'd suggest tapping it with a bit of force but if it still doesn't open to go and see if someone can fix it.
Aug 12, 2016 | Sentry Safe Fire-Safe Home/Office Safe
How do I change the combination on SENPL048E sentry portable security safe
Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
  • Delete any existing codes by pressing the "P" key and entering the factory code, followed by "00000." On older safes, press the "PROG" key and entering your factory code twice to delete old codes.
  • Press the "PROG" or "P" key again on your Sentry safe's keypad.
  • Enter your safe's five-digit factory code.
  • Enter a five-digit code of your choosing within 5 seconds. This is your user code. While the factory code cannot be changed, your user code can be changed as often as you like, and that should be your primary code to open the safe. Only you should know your safe's factory code.
  • Mar 24, 2016 | Home Security
    I have lost the combination for my safe model V330 my model number V330 Sentry safe
    • Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
    • Retype the user code to verify it is working, and then close the safe.
    Mar 19, 2016 | Sentry FIRE-SAFE Combination Safe DS3431,...
    How can i drill a hole into my keepsafe wall safe to open it?
    Keep the drill motor in the toolbox, you'll likely just ruin the safe.
    Go here instead: https://www.sentrysafe.com/CustomerCare/Lost_Your_Combination
    There are 3 possible ways to unlock and access
    the safe:
    1. Factory code
    (Found on the first page of the factory guide) You can
    always open the safe by entering the pre-set 5-digit
    factory code. This code cannot be deleted.
    2. User code
    If you prefer to employ your own code, you can
    program the safe to open using a 5-digit user code
    of your choice.
    3. User pin
    If you wish to give someone else temporary access
    to the safe, you can program a 5-digit user pin that
    can later be erased.
    Programming the user code
    NOTE: One (1) user code is allowed.
    To add:
    1. Press the Prog key , then enter the 5-digit
    factory code.
    2. Enter the 5-digit user code of your choice.
    To delete:
    1. Press the Prog key.
    2. Enter the 5-digit factory code twice.
    Programming user pin
    NOTE: One (1) user pin is allowed.
    To add:
    1. Press the Prog key 2 times.
    2. Enter your 5-digit user code.
    3. Enter the 5-digit user pin of your choice.
    To delete:
    3. Enter 0, 0, 0, 0, 0.
    NOTE: If your safe does not appear to be working,
    please check batteries before calling Sentry
    Customer Care.
    Jul 26, 2014 | Sentry KeepSafe Combination Fire Safe 12...
    Change the combination to a Sentry 2260 safe. I have original combination and all I just need to change the combination.
    Safe and vault techs would advise you
    1. Press the Program key.
    2. Press it a second time.
    3. Enter your 5-digit User Code. The green LED remains ON.
    4. Enter the 5-digit Password of your choice (any combination
    except 00000.) After 5 digits are entered, the green LED
    turns OFF.
    (To enter a new Password, repeat these steps. To erase the
    Password, press Program twice, enter your User Code and then
    enter 00000.)
    Jun 08, 2009 | Sentry Fireproof Safe
    S3517sentry safe need to reset
    Press: Program 2x, enter a digit user-code (green led remains on), enter the 5 digit user pin (of your choice except 00000). After 5 digits entered, the green LED turns off.
    May 11, 2009 | Sentry Fireproof Safe
    I have a different model but I had the same problem. Called customer service and they had me push up on the handle and enter the code. That didn't work but then they had me tap the safe with a rubber mallet 5 times above the panel and 5 times to the right of the panel. That worked for me. Hope one of those works.
    Oct 09, 2008 | Sentry Fireproof Safe
    here is the customer service phone number for you. I am sure they will be able to help you. 800-828-1438
    Jul 02, 2008 | Sentry Fireproof Safe
    Home Security Logo
    344 people viewed this question
    Top Home Security Experts
    Lawrence Oravetz
    Are you a Home Security Expert? Answer questions, earn points and help others
