Question about Philips Lands Phones
Telephone socket fine (tested) but phone keeps searching & saying "out of area""
SE275
    Problem Solver:
  • 8 Answers
If you've made sure that the jack is good,by plugging in a known working phone and ensuring that it works, try swapping the line cord between the 2 phones, if that doesn't do it, make sure the line cord is plugged into the correct jack on the back of the cordless phone, there often are 2 of them. good luck.
Posted on Dec 29, 2013
2 Suggested Answers
  • 65 Answers
SOURCE: phone says searching
The battery may be weak. Or it is too far from the base. Try exchanging the two. take the handset near the base and see if it will link.
Posted on Jan 29, 2008
Address for 01267275412
Who called me? ' United Kingdom's Free Reverse Phone Lookup
who-called.co.uk/
  1. Cached
  2. Similar
Got an unwanted call ? next unknown number ? - Check out who is calling to you and secure against spammers and scammers.
United Kingdom Reverse Lookup 44, Phone Number Search
www.searchyellowdirectory.com/reverse-phone/44/
  1. Cached
  2. Similar
United Kingdom +44 Reverse Lookup - UK Phone Number Search. Simply enter a United Kingdom number in the correct international format, Reverse Lookup: +44 + Area Code + Local Number ... for instant results!United Kingdom Yellow Pages ... · ‎Jersey · ‎28 · ‎1252
UK Reverse Phone Lookup ' Reverse Phone Directory ' White pages UK
www.whitepages.co.uk/reverse-telephone-lookup/...uk/reverse-telephone-lookup.html
  1. Cached
  2. Similar
Reverse Phone Lookup allows users to find the identity of someone by searching with just a telephone number. Whitepages used to offer this service but has ...
United Kingdom Reverse Phone Number Lookup & phone country ...
www.gsmcamp.info/United%20Kingdom/reverse-phone-number-lookup/44/GB
  1. Cached
This United Kingdom reverse phone number look up service extends its search criteria not only to cell phones but also helps in identifying callers who use ...
United Kingdom Reverse Phone lookup 44, Number Search
www.searchpeopledirectory.com > Country List > Reverse Phone
  1. Cached
  2. Similar
United Kingdom reverse phone lookup +44 phone numbers. FREE United Kingdom mobile number search for people, area codes, calling codes, time zones, ... Google
Dec 12, 2016 | Computers & Internet
Why will my uniden phones not dial out, all units will not dial out. Phone jack works, but when I try to dial, with each digit pressed I only get a dial tone. Phone will receive calls, but I cannot dial...
I have not seen this in a long time. 'Way back in
the 1970's a similar problem would occur when the
telephone company accidently reversed the 'tip and
ring' wires.
This was only a problem with the
then-new "push button" (tone) dialing, the standad
rotary dials worked fine. The fix was to reverse
the red & green station wires in the "B-block"
(on the baseboard) to undo the central office goof.
Maybe it still happens? Try reversing the red &
green wires in the modular socket you are plugging
the base ('main unit') into.
Feb 18, 2015 | Uniden Cordless Phone
I have a 6.0 kx-tg385sk phone system I used my cell phone to transfer phonebook from it to panasonic base unit it was working fine - I disconnect my cell fron it. Now I dail from my new phonebook and it...
Your local telephone company may require the usage of 1 and the area code or just the area code. Please check with your phone company and see how the information was transferred to the telephone.
Mar 08, 2014 | Panasonic Lands Phones
Every time I print or receive a fax, it kicks me off of the internet.? PLEASE HELP!! Thank you :)
Try it:1..Telephone line straight away to system modem line in socket.. from modem line out socket to printer line in socket(marked as box symbol)dont insert tele phone line in phone symbol socket.. 2..Telephone line straight away to printer line in socket.. from extension socket(marked as phone symbol) to system modem line in socket...Note:dont split telephone line like branch.. Describe this issue with telephone operator because of both fax & internet will work in digital signals, result conflict may happen..
Jan 31, 2012 | HP Laserjet CM2320nf All-In-One Color...
Printer kicks me off internet
I have an HP 2510 printer. I cannot use it to fax because once I plug the phone jack into the printer I get a busy signal. If I plug the jack into a phone, it works fine. How do I get the printer to...
Hi irwinbadin,
HP fax products are designed so that other telephone equipment can be connected on the same line as the fax. The unit must be connected first using a two-conductor fax/phone cable like the one that shipped with the HP product. Using a four-conductor telephone cable may cause problems receiving faxes or calls.
There are two different types of phone cables. There are two-conductor phone cables like what originally shipped with the HP fax product and there are four-conductor cables. HP fax products are designed to work with a two-conductor phone cable. Look at the end of the cable and verify that it has only two copper leads or wires. Replace any four-conductor cables with a two-conductor cable. Only two-conductor phone cables should be used to connect the all-in-one to the phone line.
Figure 1: The difference between a two-conductor phone cable and a four-conductor phone cable
Step one: Connect the phone line to the fax
The fax will have two or three sockets (or jacks) for phone lines. Some of these may have a removable plastic plug in them. These sockets will be labeled with text, To Wall Jack , or with a graphic of the wall jack. See Figure 1 below.
Plug the two-conductor telephone cable that came with the HP product into the telephone wall jack. Then, plug it into this socket as shown below.
In areas with above ground telephone lines and electrical storms (lightning), it is a good idea to purchase a telephone line surge suppressor and connect it between the telephone wall jack and the fax. This will help prevent damage to the fax from a lightning-caused power surge on the phone line.
Step two: Add other phone-line devices
To connect other telephone devices, use the other socket (or sockets) on the fax. These are identified by text or with a graphic of a telephone and/or computer.
Connect a caller ID unit between the fax and the telephone.
Use the information below that matches the devices you need to connect.
Fax and telephone
Connect a single-line telephone to one of the added sockets on the fax. The telephone will share the same phone line as the fax. See the illustration below.
Fax, answering machine, and telephone
When a telephone answering machine and telephone are connected, connect the answering machine to the fax and then connect the telephone to the answering machine as shown below.
Fax and computer modem
To use a fax and a computer modem on the same phone line, connect the fax to the computer modem. The modem socket on the computer may be labeled Line or Wall jack .
Fax, computer modem, and telephone
To use a computer modem and a telephone with the fax, connect the computer modem to the fax. Then, connect the telephone into the second phone line connector on the computer modem or the third fax socket (if it is available). The image below shows how to connect a computer and a telephone to a fax with two sockets.
Fax, modem, answering machine, and telephone
The image below shows how to connect a computer modem, answering machine, and telephone to a fax. Connect the computer modem to the fax, then connect the answering machine to the computer, and finally, connect the telephone to the answering machine.
If the fax has three phone line sockets instead of two, some of the devices can be connected to the other phone socket on the fax.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2011 | Office Equipment & Supplies
I have cell phone nokia 2220s slide has internet but the server nync is not working is say in the phone that is must call service provider so what is the number phone?
  • Visit Telecodata.us, a website that provides centralized information on telephone numbers, exchanges and companies (see References).
  • Click "Area/Exchange" under the Common Lookup heading.
  • Type the area code and the exchange (first three digits) of the phone number in the search fields and click "Search."
  • Review the search results. If only a single company is listed for the area code and exchange you entered, that company services all numbers for that exchange. The search results will indicate which set of phone numbers belongs to each company if multiple companies are listed. For example, in area code 718, phone numbers that begin with 208-0 are serviced by AT&T Wireless, while numbers that begin with 208-3 belong to Verizon Wireless. Or call the phone company that the purchase from and they will give you the number.
  • Jun 12, 2011 | Cell Phones
    My new vtech cordless phones says noline what can that be ?
    Welcome to FixYa!
    It means that there is no telephone line connected.
    • Check the telephone cable if it is properly connected in your phone and on the wall socket.
    • Check if the telephone cable from your phone to the wall socket is not damaged.
    • It also possible that the telephone line from your wall socket to the post is damaged or cut off.
    Here's some other useful screen messages: jas247_96.gif
    Jun 01, 2011 | Vtech Cordless 6041 Phone
    HP Printer C4340 All-in-One. Workd fine but I can't get fax function. Test Report says failure on correct cable but I've tried all options. HELP!
    u have chk the telephone cable is it on on correct socket line u have to plug in the wire from the came from the telephone exchange & other is phone u have plge your pone in second socat
    Jul 28, 2008 | HP Computers & Internet
    Lands Phones Logo
    73 people viewed this question
    Top Philips Lands Phones Experts
    Are you a Philips Lands Phone Expert? Answer questions, earn points and help others
