Jvc tv stuck on sleep mode - Televison & Video
5 Suggested Answers
redcrx
  • 7 Answers
SOURCE: JVC tv "stuck" on sleep timer
I think you would have to turn off the sleep timer mode completely or increase its ON time span, say to 4 hours or so
or the lenth of time you have the TV on for. If that does not fix it then it sounds like a STANDBY MODE fault problem.
Hope this helps.
Posted on Feb 06, 2008
  • 162 Answers
SOURCE: my averatec lap top os stuck in sleep mode
Hi. I suggest you try pressing the power button to wake it up or you could also try power draining it and turting it on. To powerdrain your computer you must remove first the battery and unplug the ac adapter then press and hold the power button for 20 seconds, after that you must place back the battery and plugin the ac adapter then turn on your computer. Hope This Helps
Posted on Jun 03, 2010
solomonarefa
SOURCE: Tv shuts itself off randomly (sleep mode problem)
MY tv is JVC POWER IS ON DISPLAY BLUE SCREEN DISOLAY BUT NO IMAGE AND REMOTELY OR MANUALLY CAN NOT ADJUSTED
Posted on Sep 24, 2014
  • 34148 Answers
SOURCE: how to disable sleep mode on jvc tv mdel LT40C755A
You may have to return to the initial set up procedure to disable it
Posted on Aug 09, 2016
Testimonial: "Sorry I did not install it and do not know the procedure. I know there is a sleep? or not sleep button but I cannot find it or how to proceed."
How to disable sleep mode on jvc tv mdel LT40C755A
Aug 08, 2016 | JVC Televison & Video
I need to know the service mode of JVC TV flat screen
With TV powered ON press: [DISPLAY] and [VIDEO STATUS] on the remote at the same time.
-or- Press the [SLEEP TIMER] key and set the SLEEP TIMER for "0" MIN. While the SLEEP TIMER information is still on screen, press the [DISPLAY] key and [VIDEO STATUS] key of the remote control unit at the same time to enter the SERVICE MENU.
Exit the service menu by twice pressing the [EXIT] key on the remote.
Mar 18, 2011 | JVC AV-32S575 32" TV
Jvc model av36f702 it jumps of evry time im trying to put it on with the remote . i tink the timer is set to 0 secones .can i reset the tv.
press display button & it shows the following
07
NOW 12:20 PM
SLEEP TIMER OFF/on
ON/OFF TIMER EVERYDAY
ON TIME 7:00 PM
OFF TIME 10:00 PM
• The current channel or AV input (Channel 07)
• The current time (12:20 pm)
• Sleep Timer status/minutes remaining (The Sleep Timer is off)
• On/Off Timer status (Set to turn on everyday at 7:00 PM, off at 10:00 PM)
• Each Press of the DISPLAY button changes the display mode:
Press the SLEEP TIMER button & set it to OFF
Dec 22, 2010 | JVC AV-36F702 36" TV
I have a sony kv 25dxr tv it stuck on sleep mode how do i take it off the remote does work can I reset the tv and how
Unplug,replug the tv like an hour later.The tv should reset itself back to the factory setting.Just don't know,it will get rit of this sleep mode setting thought.U can try website like Remotes.com to buy an exact remote to the original.
Oct 21, 2010 | Sony Televison & Video
How to turn the sleep mode off
Enter in the user mode select the sleep mode time and select the time OFF(15-30-...minutes).
Sep 02, 2009 | JVC LT-32P679 32 in. LCD TV
JVC AV48WP74 Service mode
Press SLEEP TIMER and, while the indication of (SLEEP TIMER 0 MIN) is being displayed.
press DISPLAY and VIDEO STATUS on the RC simultaneously. Exit: EXIT.
Jul 04, 2009 | JVC AV-48WP74 48" Rear Projection...
This is wierd the kids played with your remote and you cannot get it out of sleep mode. Well here is somthing to try. You would take back cover off but here is the disclaimer (HIGH VOLTAGE INSIDE CAN CAUSE INJURY INCLUDEING DEATH) iF YOU NOT QUALIFIED OTAKE IT TO A TECH IF ITS SOMETHING MNOR IT WILL BE DONE WHILE YOU WAIT AND WILL NOT CHARGE YOU OUT THE YANG FOR A FEE. But if you inclined chekc the power supply unit and see if it is giving the correct current to the TV if not replace it.
May 22, 2009 | JVC AV-20220 TV
Hope this helps.
Feb 06, 2008 | JVC AV-27320 27" TV
TV DEAD
No not sleep mode as in sleep mode it only will turn off power and when the power goes out the sleep mode resets. your problem is most likly in the standby power supply or maybe even in the main supply. If you know how to use a multimeter and about the powersupply circuitry in these sets you should be able to find the fault. If you havent a clue where bto start a tv set is not a place to be experimenting around inside of. Have it looked at by a trained tech
Aug 24, 2006 | JVC AV-36D302 36" TV
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
