Question about mohawk home Framed Rooster Kitchen Rug
Cannot find the Mohawk home Framed Rooster Kitchen Rug-who has it? I need one that is 30-36 inches wide.
My stove is 23 inches long and 29 inches wide. what is that in cubic feet?
add in the height to question , then multiply all 3 numbers together .
L X W X H = cubic inches divide that number by 12 to get feet .
Nov 26, 2015 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Is there a Dyson vacuum that Will work on high pile Mohawk carpet?
Patty,
I am not sure about any of the Dyson vacuums being able to handle that carpet. I work at an Oreck store on the weekends and I know that we have had several customers come in with the same question as yours and we recommend the Oreck Magnesium RS or any of the Miele vacuum cleaners. They have been tried out on Mohawk carpet and have been found to work well. Hope this helps!
Apr 16, 2015 | Dyson Vacuums
My ceramic tile in my kitchen is higher than my
They sell metal floor molding in Home Depot or lowes. It bridges the gap, so no one trips. It comes in various lengths, and is usually about 2 inches wide. You can screw it down in place on the floor of the living room. People usually use them to bridge a gap between carpet and wood floors between doorways.
Oct 11, 2014 | Vacuums
Where can I buy imperial washable area rugs in gray
If you are looking for washable area rugs in grey color then the following link can help you a lot :
Buy Grey Rugs Online Shop Rugs by Colors
Stylishhomerugs.com is one of the leading suppliers of home rugs, area rugs and outdoor rugs. Contact us for a wide range of stylish rugs online.
Mar 04, 2014 | Jcp Home Collection Imperial Washable...
You are framing a rectangular print that is 10 inches wide and 34 inches long. this wall space has an area of 640 square inches. what is the width of the frame so that the framed print fits perfectly in...
If we assume the width of the frame is X. Then the one dimension of the framed picture will be 2X + 20 and the other dimension of the picture will be 2X + 34. We know the total area of the framed picture should be 640 in^2. Therefore:
(2X + 10) * (2X + 34) = 640
If you multiply this out you get:
4X^2 + 88X + 340 = 640
Subtract 640 from both sides:
4X^2 + 88X - 300 = 0
Divide both sides by 4:
X^2 + 22X - 75 = 0
Use the quadratic equation to solve for X, with A=1, B=22, C=75
X = [-22 +/- sqr(22^2-4*(-75)] /2
This reduces to:
(-22 +/- 48) / 2
The negative solution doesn't make sense in this case. Therefore: X = (-22 + 28) /2 = 6/3 = 3
Therefore the width of the frame should be 3 inches.
Feb 16, 2011 | SoftMath Algebrator - Algebra Homework...
Screen has borders when watching tv
This is common issue of the channels that use 4:3 format while TV is designed for 16:9. To get it disappear, you just go to picture option, choose WIDE FIT, this fuction will widen the picture to whole screen. Of course, you have to accept the picture is blur a bit.
Aug 14, 2009 | Samsung LN32B360 32 in. LCD HDTV
Rooster tail is not shooting high
If the waverunner is performing normally as far as throttle response and top speed, then the rooster tail not shooting as high as it used to indicates there is a restriction in the nozzle for the rooster tail, not a problem with the ski. Unbolt the rooster tail nozzle from the steering nozzle and inspect it for debris.
Jul 13, 2009 | Yamaha 12V Air Pump
Whirlpool Range RF367 Error Code F1E1 appears when attempting to turn on oven.
Hi Rooster,
This it the proper solution for your problem:
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
I would need the complete model number to give you a price and part number for the ERC. Just let me know if I can help you more.
Mike Anderson (Owner)
Anderson Appliance
(865)945-3808
Aug 31, 2008 | Whirlpool RF367 Electric Kitchen Range
mohawk home Framed Rooster Kitchen Rug Logo
365 people viewed this question
Top mohawk home Home Experts
Donni Steen
Tom Chichester
Are you a mohawk home Home Expert? Answer questions, earn points and help others
