Question about Technical Pro HP500BT Wireless Bluetooth Headphones
How do i pair HP500BT with device
How do i pair HP500BT with ipad
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Technical Pro Master
  • 1,001 Answers
    New Friend:
After charging, turn on headset by pushing the power button until the charging led turns red and flashes. continue to hold the button until the light flashes red and green. Go to your phone or device bluetooth settings page and search for devices, it should show up as TPRO HP500BT. Select device and select to Pair with this device. The light should start flashing red really fast, then it should be paired!
Posted on May 13, 2014
Can I pair my Bluetooth earphones to my iPad?
How to pair Bluetooth headphones to IPAD?
Most headsets have a power button or a switch to turn the device on. Press the "Pairing" button on your Bluetooth headset, if necessary. Select your headset from the Devices list on the iPad's Bluetooth window. Enter the passkey or PIN for your headset, if prompted.
Does the iPad Pair With Bluetooth Headphones? ' Chron.com
smallbusiness.chron.com/ipad-pair-bluetooth-headphones-62883.html Search for: How to pair Bluetooth headphones to IPAD?
Dec 05, 2016 | Radio Communications
Cannot get bluetooth keyboard to connect
Make sure the keyboard does not have a pairing relationship with another device in the room.
If there are any devices listed on the iPad, in Bluetooth settings, tap 'I' and forget Device.
Place the keyboard in pairing mode with a 5 second depress on power from the 'off' or no power state.
Type the keys on the keyboard that the iPad wants for the pair.
Aug 13, 2015 | Apple iPad Air
I forgot how to connect my DG Bluetooth Keyboard Case to my iPad. Can you help please?
It should be just like pairing an audio Bluetooth device. Turn the iPad's Bluetooth on and the keyboard as well, the iPad will look for an available device, it should pop up in the iPad, tap it to pair, if its ask for a pairing number, it should be noted in the box that came with the keyboard or in the instructions, that should be it.
Mar 10, 2015 | Computers & Internet
I can't pair my shb4000 with my ipad
If your headset is compatible with the iPad, it should be paired like Apple describes on it website.
Follow the instructions
Using Bluetooth headsets and keyboards with iPad
Dec 27, 2014 | Philips SHB4000WT Bluetooth Stereo Headset
How do I pair my iPad as the second device
Make sure that the headset is not paired with the iPhone (turn off Bluetooth on your iPhone temporarily). Follow the same procedure you used to pair the iPhone, but this time with your iPad.
Dec 26, 2014 | Radio Communications
How do I pair my I Pad with my new Philips portable speaker using bluetooth ( can connect fine using a cable)
If your portable speaker is Bluetooth-enabled, here is the general procedure:
1. Press and hold the function control button on the speaker until you see red and blue lights flashing in rapid succession on the speaker (the speaker is now in "pairing" mode).
2. Turn on Bluetooth on your iPad and then tap on Scan. iPad will begin scanning for nearby Bluetooth devices. When you see a name similar to that of your speaker, tap on it . You will be asked for a passcode/passkey to pair the iPad with the speaker. Enter '0000' or '1234' (without the quotes).
3. Once the passkey is accepted, the two devices are now paired. The light on the speaker should become a steady blue.
4. On the iPad, tap on Connect. If the iPad connects to the speaker, you will see Connected. You are done. Play some music from the iPad to see if you can hear it coming through the speaker.
You should have this procedure detailed in the set up guide that came with the speaker. Please note that pairing is required only for the first time you try to connect the two devices, to get them "acquainted" to each other. After that, all you need is to connect the iPad to the speaker every time you want to listen to your iPad through the speaker.
Nov 30, 2014 | Philips Audio Players & Recorders
How to pair bluetooth keyboard with ipad mini?
Hi Douglas.
1. Switch on BlueTooth on your keyboard.
2. Enable BlueTooth on your iPad.
3. Search for devices on your iPad.
4. Press button if available on keyboard to get discovered.
5. Select keyboard when shown in devices list.
6. Enter pairing code sometimes 0000 or 1234.
7. Use and enjoy.
Hope this helps!
Here is the Apple site instructions:
Here is another that explains how to do it on a MAC, might give you some clues as well:
Bluetooth How to set up your Apple Wireless Keyboard
Here is a good independent site, maybe start here:
iPad How to pair connect any bluetooth keyboard
If you prefer to watch how to do it on YouTube:
How to Connect Pair Bluetooth Wireless Keyboard to your iPad
Nov 18, 2014 | Mini Cars & Trucks
I CAN'T PAIR WITH ipad OR PHONE
Among the convenient features of the Apple iPad is the ability to pair the iPad with Bluetooth devices.
Bluetooth devices allow the iPad to interact with wireless accessories including headsets and keyboards.
Like most things related to the iPad, connecting an iPad to a Bluetooth device a quick process.
Refer to the device's instruction manual for directions to make the Bluetooth device discoverable.
Typically, this involves holding down a button for a few seconds.
To pair an iPad and a Bluetooth device, the Bluetooth device must be discoverable.
Turn the iPad's Bluetooth capability on.
Go to the settings menu on the iPad by tapping the "Settings" icon on the iPad home screen.
Tap "General" from the left panel and then "Bluetooth."
Once you are in the Bluetooth screen, slide the "On/Off" switch to "On" to turn on Bluetooth.
Select the device you wish to pair with the iPad from the list of discoverable Bluetooth devices that appears on the screen.
Depending on the device, a password may be required.
Refer to the Bluetooth device's product manual for this password.
Hope this helps.
Nov 23, 2012 | Computers & Internet
Cannot pair S305 to iPad 2
If you have the headset paired w/ another device, you have to "forget" it on that device and then try to pair w/ the iPad.
I was having the same issue w/ new iPhone 4, but this solved it for me. It is a bit annoying to have to forget and unpair every time you want to switch devices, but oh well.
Apr 02, 2011 | Motorola Mobility S305 Bluetooth Headset
Can my motorola hH695 be paired to my iPad?
Hi, this instructions works on some iPads, you can try it on yours.
How to Pair A Bluetooth Device With The iPad
Among the many convenient features of the Apple iPad, the ability to pair the iPad to any Bluetooth device is very convenient.
Bluetooth devices allow your iPad to interact with devices ranging from headsets to computers without the use of wires.
Like most things related to the iPad, connecting an iPad to a Bluetooth device is easy. Follow these simple steps to do so.
Instructions
Things You'll Need:
* iPad
* Bluetooth Device (headset or other)
First, in order to pair the iPad to a Bluetooth device you need to make sure the Bluetooth device is discoverable. Refer to the instruction manual for the device (which you can find online usually if you lost it) on how to do this.
Typically, it just involves holding down a button for a few seconds.
Next, you need to turn the iPad's Bluetooth capability on. Go to Settings by touching the Settings App icon that looks like gears.
Within Settings, select General and then Bluetooth. Once you are in the Bluetooth screen, press the on/off switch to turn Bluetooth on. Make sure it reads "on".
Once you turn on Bluetooth, you should see the discoverable Bluetooth device show up on the screen as part of a list. Select the device you wish to pair with the iPad.
Depending on the device, it may prompt you for a password. Refer to the Bluetooth device's product manual for this password.
Tips & Warnings
A white Bluetooth icon on the top of the screen indicates a device is connected to the iPad
A gray Bluetooth icon on the top of the screen indicates Bluetooth is on but no device is connected.
Jan 09, 2011 | Motorola Mobility H695 Bluetooth Headset
Technical Pro HP500BT Wireless Bluetooth Headphones Logo
505 people viewed this question
Top Technical Pro Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Bapco
Are you a Technical Pro Audio Player and Recorder Expert? Answer questions, earn points and help others
